hansbaer80 1 Posted December 27, 2017 Posted December 27, 2017 Hello, I have installed the latest FreeNAS. I am trying to import my photo library, which includes mostly CR2 raw image files. This does not work however. I get loads of error like the following: 2017-12-25 01:26:13.634 Info ImageProcessor: Getting image size for item Photo /mnt/Bilder/2017/12/10/PV4A1447.CR22017-12-25 01:26:13.663 Error App: Error in Embedded Information *** Error Report *** Version: 3.2.60.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -os freebsd -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 11.1.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.6.1 (Stable 4.6.1.5/ef43c15 Mon Jun 12 05:53:22 UTC 2017) Processor count: 8 Program data path: /var/db/emby-server Application directory: /usr/pbi/emby-amd64/lib/emby-server System.ArgumentException: Could not recognize image format. Parameter name: binaryReader at Emby.Drawing.Common.ImageHeader.GetDimensions (System.IO.BinaryReader binaryReader) [0x00076] in <b8cb098136cb407495cc0b227f217afc>:0 at Emby.Drawing.Common.ImageHeader.GetDimensions (System.String path, MediaBrowser.Model.Logging.ILogger logger, MediaBrowser.Model.IO.IFileSystem fileSystem) [0x0000f] in <b8cb098136cb407495cc0b227f217afc>:0 at Emby.Drawing.ImageProcessor.GetImageSizeInternal (System.String path, System.Boolean allowSlowMethod) [0x00000] in <b8cb098136cb407495cc0b227f217afc>:0 System.ArgumentException at Emby.Drawing.Common.ImageHeader.GetDimensions (System.IO.BinaryReader binaryReader) [0x00076] in <b8cb098136cb407495cc0b227f217afc>:0 at Emby.Drawing.Common.ImageHeader.GetDimensions (System.String path, MediaBrowser.Model.Logging.ILogger logger, MediaBrowser.Model.IO.IFileSystem fileSystem) [0x0000f] in <b8cb098136cb407495cc0b227f217afc>:0 at Emby.Drawing.ImageProcessor.GetImageSizeInternal (System.String path, System.Boolean allowSlowMethod) [0x00000] in <b8cb098136cb407495cc0b227f217afc>:0 Moreover scanning the library seems to block resources. The machine starts to slow down, and after I while I have to hard reset the whole server since it does not reply anymore. I have found this thread https://emby.media/community/index.php?/topic/24733-cr2-format/ and installed ufraw in the jail, but that does not seem to make any difference. Any ideas how this can be fixed?
Luke 42238 Posted December 27, 2017 Posted December 27, 2017 Hi, we're trying to read the image dimensions with something that doesn't even support cr2. We'll skip this for the next release and this should clear up the resource consumption issue. thanks.
hansbaer80 1 Posted December 27, 2017 Author Posted December 27, 2017 Thanks for the reply - great! Will this fix CR2 support or will this deactivate CR2 altogether? When can the new release be expected? BTW: A nice feature would be if you could exclude certain folders and files with some regexp pattern.
