FrostByte 5453 Posted August 27, 2018 Posted August 27, 2018 (edited) If you are using nginx you can redirect http to https in the config The official Samsung app isn't available where you are yet. Luke and team mentioned they are working some last issues with 2018s before they can go worldwide with the app. Another option may be to add a device which supports https, Roku maybe Edited August 27, 2018 by FrostByte
CBers 7554 Posted August 27, 2018 Posted August 27, 2018 Do you have the ports forwarded on your router? 1
Darkjeje 11 Posted August 28, 2018 Posted August 28, 2018 If you are using nginx you can redirect http to https in the config The official Samsung app isn't available where you are yet. Luke and team mentioned they are working some last issues with 2018s before they can go worldwide with the app. Another option may be to add a device which supports https, Roku maybe I don't use nginx. So you think the official Samsung app are test in first for 2018 and later for older TV ? So I have to wait,... Do you have the ports forwarded on your router? Yes, of this side, all is good. 8096 & 8920 are forwaded. I have change this parameter "Secure connection mode" in "Expert" / "Advanced". I had "Required for all remote connections", and now I have Preferred, but not required". With the new parameter, when I test the connection with Chrome, I don't have any more the message : "This site is not secure This means that someone is trying to mislead you or stealing the information you send to the server. You must close this site immediately." Maybe this new parameter will allow emby samsung app to connect. I will test later. Thank you for your help !!!
CBers 7554 Posted August 28, 2018 Posted August 28, 2018 I don't use nginx. So you think the official Samsung app are test in first for 2018 and later for older TV ? So I have to wait,... Yes, of this side, all is good. 8096 & 8920 are forwaded. I have change this parameter "Secure connection mode" in "Expert" / "Advanced". I had "Required for all remote connections", and now I have Preferred, but not required". With the new parameter, when I test the connection with Chrome, I don't have any more the message : "This site is not secure This means that someone is trying to mislead you or stealing the information you send to the server. You must close this site immediately." Maybe this new parameter will allow emby samsung app to connect. I will test later. Thank you for your help !!! Do you have the "Allow remote connections to this Emby Server." option enabled ??
Darkjeje 11 Posted August 28, 2018 Posted August 28, 2018 Do you have the "Allow remote connections to this Emby Server." option enabled ?? Yes I have enabled this option !
Luke 42242 Posted August 28, 2018 Posted August 28, 2018 I would suggest checking out our Connection Troubleshooter: https://github.com/MediaBrowser/Wiki/wiki/Connectivity Please try the steps listed there and let us know exactly which ones succeed and which ones do not. Thanks !
Darkjeje 11 Posted August 29, 2018 Posted August 29, 2018 I would suggest checking out our Connection Troubleshooter: https://github.com/MediaBrowser/Wiki/wiki/Connectivity Please try the steps listed there and let us know exactly which ones succeed and which ones do not. Thanks ! All the steps are good. I don't have any problem to connect on my emby server with External Connections, except with the emby app for samsung TV 2013. I will test later with the new parameter view above
Luke 42242 Posted December 12, 2018 Posted December 12, 2018 New Samsung releases: https://emby.media/community/index.php?/topic/66442-new-samsung-releases/ Thanks everyone.
Luke 42242 Posted May 28, 2019 Posted May 28, 2019 Emby for Samsung Tizen 1.0.61 has been released for 2015-2019 models. Please try it out and stay tuned to the blog for release notes. Thanks !
Luke 42242 Posted June 30, 2019 Posted June 30, 2019 For those interested, Install from USB: https://emby.media/community/index.php?/topic/74969-samsung-tizen-install-from-usb/
