Hoosiers317 18 Posted December 23, 2017 Posted December 23, 2017 I created two additional users/profiles. They work great, but I want to change the library order. They are not following the same order as my admin. I can't figure out how to change the user and adjust the library order for each one. Right now they are in alphabetical order, rather than a more logical way such as type of content.
Luke 42204 Posted December 23, 2017 Posted December 23, 2017 Each user gets to customize these things individually, so you will need to adjust the user settings for that user. thanks.
Solution Happy2Play 9802 Posted December 23, 2017 Solution Posted December 23, 2017 Select this on each user. 2
Hoosiers317 18 Posted December 23, 2017 Author Posted December 23, 2017 (edited) Each user gets to customize these things individually, so you will need to adjust the user settings for that user. thanks. Never mind Edited December 23, 2017 by jrcorwin
Hoosiers317 18 Posted December 23, 2017 Author Posted December 23, 2017 Select this on each user. Thank you!
