thinkfastsolu1 0 Posted December 22, 2017 Posted December 22, 2017 (edited) When i initially set up emby, I checked to use screen grabber and 80-90% of my tiles/icons or whatever, are just random shots of the movie, and I cant tell what they are. Is there any way to automatically delete all metadata, and start over new, and actually pull covers/images of the movies, so I can just look at the picture and know what it is? without having to go and do each individual movie? right now, all metadata is in the individual folders with the media. I have attached a file, red is the problem, green is how i want them. please help. Have a Merry Christmas! Edited December 22, 2017 by thinkfastsolu1
kanipek 230 Posted January 7, 2018 Posted January 7, 2018 Can't view your attachment currently. Is this metadata that was existing prior to your setting up Emby?
Happy2Play 9802 Posted January 7, 2018 Posted January 7, 2018 Well a Refresh metadata "Replace All metadata" at Library level and check replace images should do the trick assuming you have made the proper changes in Dashboard-Library-Metadata=Use drop down per content type.
kanipek 230 Posted January 7, 2018 Posted January 7, 2018 I would suggest the following: Movies use - Metadata downloader: TheMovieDb Image fetchers: TheMovieDb, FanArt Series use - Metadata downloaders: TheTVDB Image fetchers: The Tvdb, FanArt You can find those in the dashboard under library-->metadata Then you can do as @@Happy2Play suggests above
Luke 42204 Posted January 7, 2018 Posted January 7, 2018 hi @@thinkfastsolu1, we're sorry we missed this, but i would try the above suggestions. thanks !
