maximilianh75 19 Posted December 22, 2017 Posted December 22, 2017 (edited) If this item I marked in red not selected then subtitles not display in movie Edited December 22, 2017 by maximilianh75
ebr 16310 Posted December 22, 2017 Posted December 22, 2017 Hi. The simple answer is probably that those subtitles require that type of conversion to display. So, if you don't allow that conversion to occur, they don't.
Luke 42204 Posted December 22, 2017 Posted December 22, 2017 Correct. Please make sure to read the help text underneath those check boxes. Thanks.
maximilianh75 19 Posted December 23, 2017 Author Posted December 23, 2017 Correct. Please make sure to read the help text underneath those check boxes. Thanks. Thank you and I'm supose that the way that the subtitle work but I m not sure and I wanna check with you
