Hoosiers317 18 Posted December 21, 2017 Posted December 21, 2017 Hello, longtime Kodi and Plex user here running a server on macOS with an Apple TV 4K and a secondary Apple TV 4. I have two questions: 1. Does the tvOS app (beta or non-beta) support the format & framerate switching? 2. How do you gain access to the betas? Thank you!
ebr 16335 Posted December 21, 2017 Posted December 21, 2017 1. Yes the current app should support that now - as long as you are on tvOS 11.2. 2. You would need to PM me the Apple ID for the device. The current beta is about to go stable though.
Hoosiers317 18 Posted December 21, 2017 Author Posted December 21, 2017 1. Yes the current app should support that now - as long as you are on tvOS 11.2. 2. You would need to PM me the Apple ID for the device. The current beta is about to go stable though. Thank you!
