lakerfananthony 0 Posted December 2, 2018 Posted December 2, 2018 I too would like to know because I prefer the emby theater ui, I wish we had an official emby theater option on atv.
CBers 7554 Posted December 2, 2018 Posted December 2, 2018 I too would like to know because I prefer the emby theater ui, I wish we had an official emby theater option on atv. Really? IMO, the Emby Android TV app is the creme de la creme of all the Emby apps. 1
Guest asrequested Posted December 2, 2018 Posted December 2, 2018 (edited) Really? IMO, the Emby Android TV app is the creme de la creme of all the Emby apps. There would appear to be two distinct groups on this. I also find the Theater UI much better. The ATV UI is far too cramped. If I were to showcase emby, Theater is what I'd use. The word 'polished' is used frequently on here, so I feel that Theater is more 'polished', and easier to navigate. I just thought of the word that I should use.... symmetry. Theater has more symmetry. The ATV UI has very little symmetry. I like symmetry Edited December 2, 2018 by Doofus
clarkss12 304 Posted December 2, 2018 Posted December 2, 2018 There would appear to be two distinct groups on this. I also find the Theater UI much better. The ATV UI is far too cramped. If I were to showcase emby, Theater is what I'd use. The word 'polished' is used frequently on here, so I feel that Theater is more 'polished', and easier to navigate. I just thought of the word that I should use.... symmetry. Theater has more symmetry. The ATV UI has very little symmetry. I like symmetry What device/s do you use for your input? Does your Windows machine boot directly into Emby or how do you get Emby Theater to start? Once ET starts, which remote do you use to control it??
CBers 7554 Posted December 2, 2018 Posted December 2, 2018 There would appear to be two distinct groups on this. I also find the Theater UI much better. The ATV UI is far too cramped. If I were to showcase emby, Theater is what I'd use. The word 'polished' is used frequently on here, so I feel that Theater is more 'polished', and easier to navigate. I just thought of the word that I should use.... symmetry. Theater has more symmetry. The ATV UI has very little symmetry. I like symmetry The Android TV app is designed to fit in with the Android TV ecosystem. The ET UI would not fit, in the same way that the Android TV app wouldn't fit in the HTPC ecosystem. Horses for courses. 1
Guest asrequested Posted December 2, 2018 Posted December 2, 2018 What device/s do you use for your input? Does your Windows machine boot directly into Emby or how do you get Emby Theater to start? Once ET starts, which remote do you use to control it?? I've got it set to start with Windows. Then I just leave it open all the time. I use a harmony remote paired with a harmony hub, which connects to the computer via Bluetooth. 1
Guest asrequested Posted December 2, 2018 Posted December 2, 2018 The Android TV app is designed to fit in with the Android TV ecosystem. The ET UI would not fit, in the same way that the Android TV app wouldn't fit in the HTPC ecosystem. Horses for courses. Exactly. I know that Android is limited. It's definitely just a preference.
clarkss12 304 Posted December 2, 2018 Posted December 2, 2018 I've got it set to start with Windows. Then I just leave it open all the time. I use a harmony remote paired with a harmony hub, which connects to the computer via Bluetooth. Thanks
CBers 7554 Posted December 2, 2018 Posted December 2, 2018 Exactly. I know that Android is limited. Only for your needs, not mine. 1
Guest asrequested Posted December 2, 2018 Posted December 2, 2018 Only for your needs, not mine. I meant that Android can't do as much as Windows can do.
Jdiesel 1437 Posted December 2, 2018 Posted December 2, 2018 True but most people purchasing a Shield TV do so because they just want to consume their media and don't want a computer. Good thing there are options thatnfit everyones needs. 1
Guest asrequested Posted December 2, 2018 Posted December 2, 2018 True but most people purchasing a Shield TV do so because they just want to consume their media and don't want a computer. Good thing there are options thatnfit everyones needs. I agree. Choice is always a good thing.
Guest asrequested Posted December 2, 2018 Posted December 2, 2018 And I'm about to build a $700 HTPC because shield can't do what I want it to
CBers 7554 Posted December 2, 2018 Posted December 2, 2018 And I'm about to build a $700 HTPC because shield can't do what I want it to You must have money to burn 1
clarkss12 304 Posted December 2, 2018 Posted December 2, 2018 I meant that Android can't do as much as Windows can do. I hate to admit it, but the Shield does play more codecs???, than my Vorke V2 Windows miniPC (VORKE V2 Ultra Compact PC Intel Skylake I5-6200U Ubuntu16.04 8GB DDR3L 128GB Samsung SSD 802.11AC WIFI Gigabit LAN HDMI USB 3.1 Type C). I just acquired a 4k movie and have been testing it on all of my devices ( a lot of them ) using Emby. Only the Shield would play it natively (to my disappointment). My Vorke would not even play at 2 fps. I even tried to play it on my Main computer, and it would not play on that. I forget the specs of my Main computer, but I built it a couple of years ago, using mid range components. You must have a very powerful PC, that you are using as your Emby client.. Screen shots of My 4k TV running Emby Theater on my Vorke V2.
Guest asrequested Posted December 2, 2018 Posted December 2, 2018 You must have money to burn It's a combination of spare parts and cyber monday deals. I've been wanting to do this for a while.
Guest asrequested Posted December 2, 2018 Posted December 2, 2018 I hate to admit it, but the Shield does play more codecs???, than my Vorke V2 Windows miniPC (VORKE V2 Ultra Compact PC Intel Skylake I5-6200U Ubuntu16.04 8GB DDR3L 128GB Samsung SSD 802.11AC WIFI Gigabit LAN HDMI USB 3.1 Type C). I just acquired a 4k movie and have been testing it on all of my devices ( a lot of them ) using Emby. Only the Shield would play it natively (to my disappointment). My Vorke would not even play at 2 fps. I even tried to play it on my Main computer, and it would not play on that. I forget the specs of my Main computer, but I built it a couple of years ago, using mid range components. You must have a very powerful PC, that you are using as your Emby client.. Screen shots of My 4k TV running Emby Theater on my Vorke V2. 4k Movie.jpg 4k Movie.jpg Yeah, for tone mapping in mpv, you need a little more juice. My Beelink X45 plays everything perfectly, except 4k HDR. 4k SDR play just fine, but it struggles with the tone mapping for HDR. This is the main reason I'm building a new machine. I have a GTX 1050 sitting around, so I'm going to put it to work.
Guest asrequested Posted December 2, 2018 Posted December 2, 2018 (edited) @@clarkss12 on your vorke, make sure you've correctly chosen hardware acceleration. Try auto. By default, Theater is set to 'none'. Edited December 2, 2018 by Doofus
Guest asrequested Posted December 5, 2018 Posted December 5, 2018 I hate to admit it, but the Shield does play more codecs???, than my Vorke V2 Windows miniPC codecs that mpv supports. Pretty sure that's more than the shield, supports. Audio decoders: comfortnoise - RFC 3389 comfort noise generator dvaudio - Ulead DV Audio 8svx_exp - 8SVX exponential 8svx_fib - 8SVX fibonacci s302m - SMPTE 302M sdx2_dpcm - DPCM Squareroot-Delta-Exact aac - AAC (Advanced Audio Coding) aac_fixed (aac) - AAC (Advanced Audio Coding) aac_latm - AAC LATM (Advanced Audio Coding LATM syntax) ac3 - ATSC A/52A (AC-3) ac3_fixed (ac3) - ATSC A/52A (AC-3) alac - ALAC (Apple Lossless Audio Codec) als (mp4als) - MPEG-4 Audio Lossless Coding (ALS) amrnb (amr_nb) - AMR-NB (Adaptive Multi-Rate NarrowBand) amrwb (amr_wb) - AMR-WB (Adaptive Multi-Rate WideBand) ape - Monkey's Audio aptx - aptX (Audio Processing Technology for Bluetooth) atrac1 - ATRAC1 (Adaptive TRansform Acoustic Coding) atrac3 - ATRAC3 (Adaptive TRansform Acoustic Coding 3) atrac3al - ATRAC3 AL (Adaptive TRansform Acoustic Coding 3 Advanced Lossless) atrac3plus (atrac3p) - ATRAC3+ (Adaptive TRansform Acoustic Coding 3+) atrac3plusal (atrac3pal) - ATRAC3+ AL (Adaptive TRansform Acoustic Coding 3+ Advanced Lossless) binkaudio_dct - Bink Audio (DCT) binkaudio_rdft - Bink Audio (RDFT) bmv_audio - Discworld II BMV audio cook - Cook / Cooker / Gecko (RealAudio G2) dca (dts) - DCA (DTS Coherent Acoustics) dolby_e - Dolby E dsd_lsbf - DSD (Direct Stream Digital), least significant bit first dsd_msbf - DSD (Direct Stream Digital), most significant bit first dsd_lsbf_planar - DSD (Direct Stream Digital), least significant bit first, planar dsd_msbf_planar - DSD (Direct Stream Digital), most significant bit first, planar dsicinaudio - Delphine Software International CIN audio dss_sp - Digital Speech Standard - Standard Play mode (DSS SP) dst - DST (Digital Stream Transfer) eac3 - ATSC A/52B (AC-3, E-AC-3) evrc - EVRC (Enhanced Variable Rate Codec) wavesynth - Wave synthesis pseudo-codec flac - FLAC (Free Lossless Audio Codec) g723_1 - G.723.1 g729 - G.729 gsm - GSM gsm_ms - GSM Microsoft variant iac - IAC (Indeo Audio Coder) imc - IMC (Intel Music Coder) interplayacm - Interplay ACM mace3 - MACE (Macintosh Audio Compression/Expansion) 3:1 mace6 - MACE (Macintosh Audio Compression/Expansion) 6:1 metasound - Voxware MetaSound mlp - MLP (Meridian Lossless Packing) mp1 - MP1 (MPEG audio layer 1) mp1float (mp1) - MP1 (MPEG audio layer 1) mp2 - MP2 (MPEG audio layer 2) mp2float (mp2) - MP2 (MPEG audio layer 2) mp3 - MP3 (MPEG audio layer 3) mp3float (mp3) - MP3 (MPEG audio layer 3) mp3adu - ADU (Application Data Unit) MP3 (MPEG audio layer 3) mp3adufloat (mp3adu) - ADU (Application Data Unit) MP3 (MPEG audio layer 3) mp3on4 - MP3onMP4 mp3on4float (mp3on4) - MP3onMP4 mpc7 (musepack7) - Musepack SV7 mpc8 (musepack8) - Musepack SV8 nellymoser - Nellymoser Asao on2avc (avc) - On2 Audio for Video Codec opus - Opus paf_audio - Amazing Studio Packed Animation File Audio qcelp - QCELP / PureVoice qdm2 - QDesign Music Codec 2 qdmc - QDesign Music Codec 1 real_144 (ra_144) - RealAudio 1.0 (14.4K) real_288 (ra_288) - RealAudio 2.0 (28.8K) ralf - RealAudio Lossless shorten - Shorten sipr - RealAudio SIPR / ACELP.NET smackaud (smackaudio) - Smacker audio sonic - Sonic tak - TAK (Tom's lossless Audio Kompressor) truehd - TrueHD truespeech - DSP Group TrueSpeech tta - TTA (True Audio) twinvq - VQF TwinVQ vmdaudio - Sierra VMD audio vorbis - Vorbis wavpack - WavPack wmalossless - Windows Media Audio Lossless wmapro - Windows Media Audio 9 Professional wmav1 - Windows Media Audio 1 wmav2 - Windows Media Audio 2 wmavoice - Windows Media Audio Voice ws_snd1 (westwood_snd1) - Westwood Audio (SND1) xma1 - Xbox Media Audio 1 xma2 - Xbox Media Audio 2 pcm_alaw - PCM A-law / G.711 A-law pcm_bluray - PCM signed 16|20|24-bit big-endian for Blu-ray media pcm_dvd - PCM signed 16|20|24-bit big-endian for DVD media pcm_f16le - PCM 16.8 floating point little-endian pcm_f24le - PCM 24.0 floating point little-endian pcm_f32be - PCM 32-bit floating point big-endian pcm_f32le - PCM 32-bit floating point little-endian pcm_f64be - PCM 64-bit floating point big-endian pcm_f64le - PCM 64-bit floating point little-endian pcm_lxf - PCM signed 20-bit little-endian planar pcm_mulaw - PCM mu-law / G.711 mu-law pcm_s8 - PCM signed 8-bit pcm_s8_planar - PCM signed 8-bit planar pcm_s16be - PCM signed 16-bit big-endian pcm_s16be_planar - PCM signed 16-bit big-endian planar pcm_s16le - PCM signed 16-bit little-endian pcm_s16le_planar - PCM signed 16-bit little-endian planar pcm_s24be - PCM signed 24-bit big-endian pcm_s24daud - PCM D-Cinema audio signed 24-bit pcm_s24le - PCM signed 24-bit little-endian pcm_s24le_planar - PCM signed 24-bit little-endian planar pcm_s32be - PCM signed 32-bit big-endian pcm_s32le - PCM signed 32-bit little-endian pcm_s32le_planar - PCM signed 32-bit little-endian planar pcm_s64be - PCM signed 64-bit big-endian pcm_s64le - PCM signed 64-bit little-endian pcm_u8 - PCM unsigned 8-bit pcm_u16be - PCM unsigned 16-bit big-endian pcm_u16le - PCM unsigned 16-bit little-endian pcm_u24be - PCM unsigned 24-bit big-endian pcm_u24le - PCM unsigned 24-bit little-endian pcm_u32be - PCM unsigned 32-bit big-endian pcm_u32le - PCM unsigned 32-bit little-endian pcm_zork - PCM Zork gremlin_dpcm - DPCM Gremlin interplay_dpcm - DPCM Interplay roq_dpcm - DPCM id RoQ sol_dpcm - DPCM Sol xan_dpcm - DPCM Xan adpcm_4xm - ADPCM 4X Movie adpcm_adx - SEGA CRI ADX ADPCM adpcm_afc - ADPCM Nintendo Gamecube AFC adpcm_aica - ADPCM Yamaha AICA adpcm_ct - ADPCM Creative Technology adpcm_dtk - ADPCM Nintendo Gamecube DTK adpcm_ea - ADPCM Electronic Arts adpcm_ea_maxis_xa - ADPCM Electronic Arts Maxis CDROM XA adpcm_ea_r1 - ADPCM Electronic Arts R1 adpcm_ea_r2 - ADPCM Electronic Arts R2 adpcm_ea_r3 - ADPCM Electronic Arts R3 adpcm_ea_xas - ADPCM Electronic Arts XAS g722 (adpcm_g722) - G.722 ADPCM g726 (adpcm_g726) - G.726 ADPCM g726le (adpcm_g726le) - G.726 ADPCM little-endian adpcm_ima_amv - ADPCM IMA AMV adpcm_ima_apc - ADPCM IMA CRYO APC adpcm_ima_dat4 - ADPCM IMA Eurocom DAT4 adpcm_ima_dk3 - ADPCM IMA Duck DK3 adpcm_ima_dk4 - ADPCM IMA Duck DK4 adpcm_ima_ea_eacs - ADPCM IMA Electronic Arts EACS adpcm_ima_ea_sead - ADPCM IMA Electronic Arts SEAD adpcm_ima_iss - ADPCM IMA Funcom ISS adpcm_ima_oki - ADPCM IMA Dialogic OKI adpcm_ima_qt - ADPCM IMA QuickTime adpcm_ima_rad - ADPCM IMA Radical adpcm_ima_smjpeg - ADPCM IMA Loki SDL MJPEG adpcm_ima_wav - ADPCM IMA WAV adpcm_ima_ws - ADPCM IMA Westwood adpcm_ms - ADPCM Microsoft adpcm_mtaf - ADPCM MTAF adpcm_psx - ADPCM Playstation adpcm_sbpro_2 - ADPCM Sound Blaster Pro 2-bit adpcm_sbpro_3 - ADPCM Sound Blaster Pro 2.6-bit adpcm_sbpro_4 - ADPCM Sound Blaster Pro 4-bit adpcm_swf - ADPCM Shockwave Flash adpcm_thp - ADPCM Nintendo THP adpcm_thp_le - ADPCM Nintendo THP (little-endian) adpcm_vima - LucasArts VIMA audio adpcm_xa - ADPCM CDROM XA adpcm_yamaha - ADPCM Yamaha libopus (opus) - libopus Opus libspeex (speex) - libspeex Speex libvorbis (vorbis) - libvorbis Video decoders: aasc - Autodesk RLE aic - Apple Intermediate Codec alias_pix - Alias/Wavefront PIX image amv - AMV Video anm - Deluxe Paint Animation ansi - ASCII/ANSI art apng - APNG (Animated Portable Network Graphics) image asv1 - ASUS V1 asv2 - ASUS V2 aura - Auravision AURA aura2 - Auravision Aura 2 avrp - Avid 1:1 10-bit RGB Packer avrn - Avid AVI Codec avs - AVS (Audio Video Standard) video avui - Avid Meridien Uncompressed ayuv - Uncompressed packed MS 4:4:4:4 bethsoftvid - Bethesda VID video bfi - Brute Force & Ignorance binkvideo - Bink video bmp - BMP (Windows and OS/2 bitmap) bmv_video - Discworld II BMV video brender_pix - BRender PIX image c93 - Interplay C93 cavs - Chinese AVS (Audio Video Standard) (AVS1-P2, JiZhun profile) cdgraphics - CD Graphics video cdxl - Commodore CDXL video cfhd - Cineform HD cinepak - Cinepak clearvideo - Iterated Systems ClearVideo cljr - Cirrus Logic AccuPak cllc - Canopus Lossless Codec cpia - CPiA video format camstudio (cscd) - CamStudio cyuv - Creative YUV (CYUV) dds - DirectDraw Surface image decoder dfa - Chronomaster DFA dirac - BBC Dirac VC-2 dnxhd - VC3/DNxHD dpx - DPX (Digital Picture Exchange) image dsicinvideo - Delphine Software International CIN video dvvideo - DV (Digital Video) dxa - Feeble Files/ScummVM DXA dxtory - Dxtory dxv - Resolume DXV eacmv (cmv) - Electronic Arts CMV video eamad (mad) - Electronic Arts Madcow Video eatgq (tgq) - Electronic Arts TGQ video eatgv (tgv) - Electronic Arts TGV video eatqi (tqi) - Electronic Arts TQI Video 8bps - QuickTime 8BPS video escape124 - Escape 124 escape130 - Escape 130 exr - OpenEXR image ffv1 - FFmpeg video codec #1 ffvhuff - Huffyuv FFmpeg variant fic - Mirillis FIC fits - Flexible Image Transport System flashsv - Flash Screen Video v1 flashsv2 - Flash Screen Video v2 flic - Autodesk Animator Flic video flv (flv1) - FLV / Sorenson Spark / Sorenson H.263 (Flash Video) fmvc - FM Screen Capture Codec 4xm - 4X Movie fraps - Fraps frwu - Forward Uncompressed g2m - Go2Meeting gdv - Gremlin Digital Video gif - GIF (Graphics Interchange Format) h261 - H.261 h263 - H.263 / H.263-1996, H.263+ / H.263-1998 / H.263 version 2 h263i - Intel H.263 h263p - H.263 / H.263-1996, H.263+ / H.263-1998 / H.263 version 2 h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 hap - Vidvox Hap hevc - HEVC (High Efficiency Video Coding) hnm4video - HNM 4 video hq_hqa - Canopus HQ/HQA hqx - Canopus HQX huffyuv - Huffyuv / HuffYUV idcinvideo (idcin) - id Quake II CIN video iff (iff_ilbm) - IFF ACBM/ANIM/DEEP/ILBM/PBM/RGB8/RGBN indeo2 - Intel Indeo 2 indeo3 - Intel Indeo 3 indeo4 - Intel Indeo Video Interactive 4 indeo5 - Intel Indeo Video Interactive 5 interplayvideo - Interplay MVE video jpeg2000 - JPEG 2000 jpegls - JPEG-LS jv - Bitmap Brothers JV video kgv1 - Kega Game Video kmvc - Karl Morton's video codec lagarith - Lagarith lossless loco - LOCO m101 - Matrox Uncompressed SD magicyuv - MagicYUV video mdec - Sony PlayStation MDEC (Motion DECoder) mimic - Mimic mjpeg - MJPEG (Motion JPEG) mjpegb - Apple MJPEG-B mmvideo - American Laser Games MM Video motionpixels - Motion Pixels video mpeg1video - MPEG-1 video mpeg2video - MPEG-2 video mpeg4 - MPEG-4 part 2 mpegvideo (mpeg2video) - MPEG-1 video msa1 - MS ATC Screen mscc - Mandsoft Screen Capture Codec msmpeg4v1 - MPEG-4 part 2 Microsoft variant version 1 msmpeg4v2 - MPEG-4 part 2 Microsoft variant version 2 msmpeg4 (msmpeg4v3) - MPEG-4 part 2 Microsoft variant version 3 msrle - Microsoft RLE mss1 - MS Screen 1 mss2 - MS Windows Media Video V9 Screen msvideo1 - Microsoft Video 1 mszh - LCL (LossLess Codec Library) MSZH mts2 - MS Expression Encoder Screen mvc1 - Silicon Graphics Motion Video Compressor 1 mvc2 - Silicon Graphics Motion Video Compressor 2 mxpeg - Mobotix MxPEG video nuv - NuppelVideo/RTJPEG paf_video - Amazing Studio Packed Animation File Video pam - PAM (Portable AnyMap) image pbm - PBM (Portable BitMap) image pcx - PC Paintbrush PCX image pgm - PGM (Portable GrayMap) image pgmyuv - PGMYUV (Portable GrayMap YUV) image pictor - Pictor/PC Paint pixlet - Apple Pixlet png - PNG (Portable Network Graphics) image ppm - PPM (Portable PixelMap) image prores - ProRes (iCodec Pro) psd - Photoshop PSD file ptx - V.Flash PTX image qdraw - Apple QuickDraw qpeg - Q-team QPEG qtrle - QuickTime Animation (RLE) video r10k - AJA Kona 10-bit RGB Codec r210 - Uncompressed RGB 10-bit rawvideo - raw video rl2 - RL2 video roqvideo (roq) - id RoQ video rpza - QuickTime video (RPZA) rscc - innoHeim/Rsupport Screen Capture Codec rv10 - RealVideo 1.0 rv20 - RealVideo 2.0 rv30 - RealVideo 3.0 rv40 - RealVideo 4.0 sanm - LucasArts SANM/Smush video scpr - ScreenPressor screenpresso - Screenpresso sgi - SGI image sgirle - Silicon Graphics RLE 8-bit video sheervideo - BitJazz SheerVideo smackvid (smackvideo) - Smacker video smc - QuickTime Graphics (SMC) smvjpeg - SMV JPEG snow - Snow sp5x - Sunplus JPEG (SP5X) speedhq - NewTek SpeedHQ srgc - Screen Recorder Gold Codec sunrast - Sun Rasterfile image svq1 - Sorenson Vector Quantizer 1 / Sorenson Video 1 / SVQ1 svq3 - Sorenson Vector Quantizer 3 / Sorenson Video 3 / SVQ3 targa - Truevision Targa image targa_y216 - Pinnacle TARGA CineWave YUV16 tdsc - TDSC theora - Theora thp - Nintendo Gamecube THP video tiertexseqvideo - Tiertex Limited SEQ video tiff - TIFF image tmv - 8088flex TMV truemotion1 - Duck TrueMotion 1.0 truemotion2 - Duck TrueMotion 2.0 truemotion2rt - Duck TrueMotion 2.0 Real Time camtasia (tscc) - TechSmith Screen Capture Codec tscc2 - TechSmith Screen Codec 2 txd - Renderware TXD (TeXture Dictionary) image ultimotion (ulti) - IBM UltiMotion utvideo - Ut Video v210 - Uncompressed 4:2:2 10-bit v210x - Uncompressed 4:2:2 10-bit v308 - Uncompressed packed 4:4:4 v408 - Uncompressed packed QT 4:4:4:4 v410 - Uncompressed 4:4:4 10-bit vb - Beam Software VB vble - VBLE Lossless Codec vc1 - SMPTE VC-1 vc1image - Windows Media Video 9 Image v2 vcr1 - ATI VCR1 vmdvideo - Sierra VMD video vmnc - VMware Screen Codec / VMware Video vp3 - On2 VP3 vp5 - On2 VP5 vp6 - On2 VP6 vp6a - On2 VP6 (Flash version, with alpha channel) vp6f - On2 VP6 (Flash version) vp7 - On2 VP7 vp8 - On2 VP8 vp9 - Google VP9 vqavideo (ws_vqa) - Westwood Studios VQA (Vector Quantized Animation) video bitpacked - Bitpacked webp - WebP image wrapped_avframe - AVPacket to AVFrame passthrough wmv1 - Windows Media Video 7 wmv2 - Windows Media Video 8 wmv3 - Windows Media Video 9 wmv3image - Windows Media Video 9 Image wnv1 - Winnov WNV1 xan_wc3 - Wing Commander III / Xan xan_wc4 - Wing Commander IV / Xxan xbm - XBM (X BitMap) image xface - X-face image xl (vixl) - Miro VideoXL xpm - XPM (X PixMap) image xwd - XWD (X Window Dump) image y41p - Uncompressed YUV 4:1:1 12-bit ylc - YUY2 Lossless Codec yop - Psygnosis YOP Video yuv4 - Uncompressed packed 4:2:0 012v - Uncompressed 4:2:2 10-bit zerocodec - ZeroCodec Lossless Video zlib - LCL (LossLess Codec Library) ZLIB zmbv - Zip Motion Blocks Video libaom-av1 (av1) - libaom AV1 libvpx (vp8) - libvpx VP8 libvpx-vp9 (vp9) - libvpx VP9 bintext - Binary text xbin - eXtended BINary text idf - iCEDraw text h264_cuvid (h264) - Nvidia CUVID H264 decoder hevc_cuvid (hevc) - Nvidia CUVID HEVC decoder mjpeg_cuvid (mjpeg) - Nvidia CUVID MJPEG decoder mpeg1_cuvid (mpeg1video) - Nvidia CUVID MPEG1VIDEO decoder mpeg2_cuvid (mpeg2video) - Nvidia CUVID MPEG2VIDEO decoder mpeg4_cuvid (mpeg4) - Nvidia CUVID MPEG4 decoder vc1_cuvid (vc1) - Nvidia CUVID VC1 decoder vp8_cuvid (vp8) - Nvidia CUVID VP8 decoder vp9_cuvid (vp9) - Nvidia CUVID VP9 decoder
clarkss12 304 Posted December 5, 2018 Posted December 5, 2018 (edited) I acquired my Skyscraper movie in 4k to test my different devices on play back. I do have to eat my humble pie, since for over 3 years I have REFUSED to purchase an Nvidia Shield, since it just works, and I prefer to tinker. I actually purchased it when it was on sale 3 or 4 weeks ago, mainly as a basis of comparison. Well, that comparison has finally come home to roost. While testing this 4k movie playback on my devices, I found out that ONLY the NVIDIA will play that movie. Even my desktop computer that I built a couple of years ago, only has audio and a blank screen. My Vorke V2 ( Windows 10 microPC) will not play it either. I do have another newer device coming, but it has been floating around the country via the USPS. It has hit within 10 miles of me, but got sent back to Kansas (Wizard of OZ maybe), anyway that is another story. I had the file stored on my Synology DS216+II NAS, but after I started to play the video on my other devices and when I STOPPED the playback, my NAS would go NUTS, for at least half an hour. All my testing was done using Emby. So, to take my NAS out of the equation, I purchased an 8 TB powered external HDD. Now, the problems really begin. I was indecisive on which device to connect the HDD to, the Shield or my Vorke. Well, I connected the HDD to my Shield, but lo and behold, the Shield does NOT allow writing to it. Moved the HDD to my Vorke, but the only USB 3 port is on the FRONT of that device, so I chose to move the HDD to my Asus RT-AC1900P (awesome wireless router), since it has a USB 3 port. BUT, after transferring files, it was only transferring at USB 2 transfer rates. Called Asus to complain, but they bumped the issue up stream, so they will call my later. I do have other options, I have some devices with USB 3 ports running Linux, and a Zidoo X9S which would work very well as an SMB server for my HDD. Anyway, right now I am using my HDD connected to my Vorke V2, but I can't get ANY of my boxes using Kodi running Android or LibreELEC or CoreELEC to even SEE my HDD. I will need some help on this issue from people that know how to make the Windows 10 serve as an SMB or NFS server, so my Kodi boxes can see my HDD. My desktop computer hardware, audio works, but black screen... EVGA GeForce GT 730 DirectX 12 (feature level 11_0) 02G-P3-3733-KR 2GB 64-Bit GDDR5 PCI Express 2.0 Low Profile Video Card AMD FX-8350 Black Edition Vishera 8-Core 4.0 GHz (4.2 GHz Turbo) Socket AM3+ 125W FD8350FRHKBOX Desktop Processor Mushkin Enhanced Reactor LT 2.5" 250GB SATA III MLC Internal Solid State Drive (SSD) MKNSSDRE250GB-LT Mediainfo data for the 4k movie. Skyscraper 4k.txt Edited December 5, 2018 by clarkss12
Jdiesel 1437 Posted December 5, 2018 Posted December 5, 2018 (edited) If there is any truth to this post the Shield Experience Upgrade 7.2 should be a big one https://forum.kodi.tv/showthread.php?tid=304226&pid=2797665#pid2797665 I'm very excited about the auto refreshrate and colourspace switching as well as the scaling improvements. These were all areas that the Apple TV performed better in. Edited December 5, 2018 by Jdiesel
mastrmind11 722 Posted December 5, 2018 Posted December 5, 2018 If there is any truth to this post the Shield Experience Upgrade 7.2 should be a big one https://forum.kodi.tv/showthread.php?tid=304226&pid=2797665#pid2797665 I'm very excited about the auto refreshrate and colourspace switching as well as the scaling improvements. These were all areas that the Apple TV performed better in. I wonder if they'll address the CEC issues they introduced in 7.1. I'd imagine but :shurg:
phrostb 0 Posted December 5, 2018 Posted December 5, 2018 man i would love support for high-res 5.1 FLAC..
Jdiesel 1437 Posted December 5, 2018 Posted December 5, 2018 I wonder if they'll address the CEC issues they introduced in 7.1. I'd imagine but :shurg: What bug is that? I only use CEC for power on/off and haven't noticed any changes.
Guest asrequested Posted December 5, 2018 Posted December 5, 2018 I wonder if the HDR issue is fixed with 7.2? But that does look like it could be a big upgrade for shield.
