red531 0 Posted December 21, 2017 Posted December 21, 2017 I am currenty having the problem that the content on my server will play fine on the server itself and through my android app, but when played through the apple tv there is no sound to go with the video. Any suggestions would be greatly appreciated, i have so far deleted and re-installed the server with no luck.
ebr 16335 Posted December 21, 2017 Posted December 21, 2017 Hi. Check the audio settings for the Apple TV itself. Make sure you haven't set it to Dolby Digital when your setup can't handle it or something like that. Try all of the different setting options there and see if they make any difference. If not, then we will need to look at a specific example. Thanks. How to Report a Problem
