erwinburgos 1 Posted December 21, 2017 Posted December 21, 2017 I am having lots of channels missing data, some pages are completely blank sometimes when i refresh the guide some of the channels that were missing data now show, but also some that had data now are blank screenshots and server log attached. Log (1).txt
erwinburgos 1 Posted December 22, 2017 Author Posted December 22, 2017 wow it's been a whole day and nobody can help with this. ;( to follow up, i removed SD and re-entered the settings, still does the same...
Luke 42237 Posted December 22, 2017 Posted December 22, 2017 I see in your log schedules direct is returning 0 programs for many of these channels, so either they just don't have data right now, or they are not mapped correctly. did you check the mappings?
cbollenbach 0 Posted April 20, 2018 Posted April 20, 2018 Hello, I did not want to start a whole new thread. I'm an experiencing the same as above and it is recent. I've had no problems with the set up for over a year. Channels appear to be mapped correctly but the guide does not populate completely. I refreshed my HD homerun prime channel line up just in case. Then refreshed schedule directs tv guide info multiple times as well as confirmed login credential and correct lineup. I am still missing a lot of data. Would you be able to help or at least let me know if its user error, a schedule direct problem, or an emby problem? Thank You See Attached Log.txt
cbollenbach 0 Posted April 20, 2018 Posted April 20, 2018 Hello, I did not want to start a whole new thread. I'm an experiencing the same as above and it is recent. I've had no problems with the set up for over a year. Channels appear to be mapped correctly but the guide does not populate completely. I refreshed my HD homerun prime channel line up just in case. Then refreshed schedule directs tv guide info multiple times as well as confirmed login credential and correct lineup. I am still missing a lot of data. Would you be able to help or at least let me know if its user error, a schedule direct problem, or an emby problem? Thank You See Attached I made a couple of other observations. I now have new channels in the 1000's after a rescan of the HDHomerRun Prime that are duplicates of my HD channels in the 400's There is guide info for the channels in the 1000's but not the 400's. Both show the correct channel name and play identically. Does anyone know of a way to hide channels either in EMBY or in the HDHomeRun Prime? Thanks
Luke 42237 Posted April 20, 2018 Posted April 20, 2018 Hi, have you tried using the mapping tool to ensure that your tuner channels are indeed mapped to epg channels from schedules direct?
cbollenbach 0 Posted April 20, 2018 Posted April 20, 2018 Hi, have you tried using the mapping tool to ensure that your tuner channels are indeed mapped to epg channels from schedules direct? I had browsed through the mapping tool and nothing appeared to be off. I looked closer and like stated before my providers has given me multiple Identical channels I.E. espnHD one on channel 402 the other on channel 1042. I'm not certain about the technical aspect of this theory but only one of the channels had guide data. SD was populating one of them so its job was done. That aside my work around was to favorite only one set of the identical channels on my HDHomeRun then to restrict channels marked as favorite. I refreshed the guide and it was fully populated and my scheduled recordings showed up again. Thank You for taking the time to look into this. I pieced together my solution from multiple threads throughout the forum. Keep up the good Team Emby
