chezmorris 0 Posted January 16, 2018 Posted January 16, 2018 Hello Luke Thanks so much for your continued interest. Since the last log I have tried fiddling around a bit more. I have compiled a much shorter M3U list (with only about 20 channels as opposed to the 2000+ before) with the aim of also shortening the length of the attached log file. Grateful for any insight. Thanks. New Emby Log.txt
Luke 42244 Posted January 17, 2018 Posted January 17, 2018 Thanks. Is there actually a playback attempt in this log? i don't see one here.
Koml 0 Posted January 19, 2018 Author Posted January 19, 2018 After the new update it works perfectly Great work guys
kikinjo 294 Posted January 19, 2018 Posted January 19, 2018 I still have same issue even after update to latest version today. @@Koml can u please reply with details about streams format ? Is it format=ts or some other (from the m3u link), have 3 different providers in all formats, and still have same issue with spinning circle and emby theater unresponsive when i play a stream.
Luke 42244 Posted January 19, 2018 Posted January 19, 2018 After the new update it works perfectly Great work guys Thanks for the feedback !
Luke 42244 Posted January 19, 2018 Posted January 19, 2018 I still have same issue even after update to latest version today. @@Koml can u please reply with details about streams format ? Is it format=ts or some other (from the m3u link), have 3 different providers in all formats, and still have same issue with spinning circle and emby theater unresponsive when i play a stream. @@kikinjo, please see how to report a media playback issue. thanks !
Koml 0 Posted January 20, 2018 Author Posted January 20, 2018 #EXTINF:-1 tvg-id="" tvg-name="Discovery Channel FHD NO" tvg-logo="" group-title="Norway",Discovery Channel FHDhttp://portal.geniptv.com:8080/live/********/*******/6505.ts @@kikinjo
Cybolic 2 Posted November 14, 2018 Posted November 14, 2018 (edited) I believe I may be having the same issue (though the stream never starts). From the ffmpeg output it seems the URL to the playlist is passed instead of the selected stream. Downloading the M3U file and giving that filepath instead of the URL doesn't make a difference, but if I paste the command from the logs and replace the playlist URL with the playlist entry URL it seems to work. ffmpeg log (sensitive info replaced with fake capital variable names): /usr/bin/ffmpeg -i "http://${PLAYLIST_URL}&type=m3u_plus&output=ts" -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 139808000 -bufsize 279616000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -flags -global_header -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/14295dadb4be3c30f1eeba97d821bf30/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby/transcoding-temp/14295dadb4be3c30f1eeba97d821bf30.m3u8" -y "/var/lib/emby/transcoding-temp/14295dadb4be3c30f1eeba97d821bf30%d.ts" ffmpeg version n4.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 8.2.1 (GCC) 20180831 configuration: --prefix=/usr --disable-debug --disable-static --disable-stripping --enable-fontconfig --enable-gmp --enable-gnutls --enable-gpl --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libdrm --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libiec61883 --enable-libjack --enable-libmodplug --enable-libmp3lame --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libv4l2 --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxcb --enable-libxml2 --enable-libxvid --enable-nvdec --enable-nvenc --enable-omx --enable-shared --enable-version3 libavutil 56. 22.100 / 56. 22.100 libavcodec 58. 35.100 / 58. 35.100 libavformat 58. 20.100 / 58. 20.100 libavdevice 58. 5.100 / 58. 5.100 libavfilter 7. 40.101 / 7. 40.101 libswscale 5. 3.100 / 5. 3.100 libswresample 3. 3.100 / 3. 3.100 libpostproc 55. 3.100 / 55. 3.100 http://${PLAYLIST_URL}&type=m3u_plus&output=ts: Invalid data found when processing input I'm on Arch Linux, if that helps. Also, I don't see any m3u formats when I run ffmpeg -formats EDIT: Switching to the ffmpeg-full-nvenc AUR package fixes everything. Edited November 14, 2018 by Cybolic
Luke 42244 Posted November 14, 2018 Posted November 14, 2018 Thanks for the feedback about your ffmpeg build.
EODCrafter 181 Posted November 14, 2018 Posted November 14, 2018 (edited) EDIT: Switching to the ffmpeg-full-nvenc AUR package fixes everything. How did you accomplish this unless it's way to technical to share......I searched for that package and I do not understand any of the info it gives me. EDIT: Awesome, figured it out....Now Emby Theater Works on Ubuntu!!!!!!!.......Spoke too soon, worked once now back to black screen unless I use external player..... Edited November 14, 2018 by EODCrafter
Cybolic 2 Posted November 14, 2018 Posted November 14, 2018 How did you accomplish this unless it's way to technical to share......I searched for that package and I do not understand any of the info it gives me. On Arch Linux, the ffmpeg-full-nvenc package is a user-contributed package in the AUR (the Arch User Repository), it can be installed through the following commands: Using yay (my preferred helper): yay ffmpeg-full-nvenc If you don't have a helper installed, the manual process is: git clone https://aur.archlinux.org/ffmpeg-full-nvenc.git cd ffmpeg-full-nvenc makepkg -si You probably want to grab a cup of your favourite beverage first as compiling ffmpeg and its dependencies takes a while. 1
Cybolic 2 Posted November 15, 2018 Posted November 15, 2018 EDIT: Awesome, figured it out....Now Emby Theater Works on Ubuntu!!!!!!!.......Spoke too soon, worked once now back to black screen unless I use external player..... Have you tried the nvenc-enabled packages here? They might require you to have an NVIDIA card, but I don't think it's a hard requirement.
EODCrafter 181 Posted November 15, 2018 Posted November 15, 2018 Have you tried the nvenc-enabled packages here? They might require you to have an NVIDIA card, but I don't think it's a hard requirement. Err:35 http://ppa.launchpad.net/mc3man/trusty-media/ubuntu bionic Release 404 Not Found [IP: 91.189.95.83 80] Reading package lists... Done E: Repository 'http://dl.google.com/linux/chrome/deb stable Release' changed its 'Origin' value from 'Google, Inc.' to 'Google LLC' N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details. E: The repository 'http://ppa.launchpad.net/mc3man/trusty-media/ubuntu bionic Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details.
Cybolic 2 Posted November 15, 2018 Posted November 15, 2018 Woops, that repo was apparently pretty old. I see there's a new repo recommended in a few places for the version 4 release of ffmpeg from this year, maybe that'll fare better? https://launchpad.net/~jonathonf/+archive/ubuntu/ffmpeg-4 1
EODCrafter 181 Posted November 15, 2018 Posted November 15, 2018 Woops, that repo was apparently pretty old. I see there's a new repo recommended in a few places for the version 4 release of ffmpeg from this year, maybe that'll fare better? https://launchpad.net/~jonathonf/+archive/ubuntu/ffmpeg-4 Setting up libaom0:amd64 (1.0.0-3~18.04.york0) ...
EODCrafter 181 Posted November 15, 2018 Posted November 15, 2018 UHD Channels Seem a lot more responsive! I'm really not a expert though.....
EODCrafter 181 Posted November 15, 2018 Posted November 15, 2018 steve@steve:~$ ffmpeg ffmpeg version N-47226-gdb4771af81-static https://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2018 the FFmpeg developers built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc-6 --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gray --enable-libaom --enable-libfribidi --enable-libass --enable-libvmaf --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librubberband --enable-libsoxr --enable-libspeex --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg libavutil 56. 19.101 / 56. 19.101 libavcodec 58. 33.101 / 58. 33.101 libavformat 58. 19.100 / 58. 19.100 libavdevice 58. 4.105 / 58. 4.105 libavfilter 7. 33.101 / 7. 33.101 libswscale 5. 2.100 / 5. 2.100 libswresample 3. 2.100 / 3. 2.100 libpostproc 55. 2.100 / 55. 2.100 Hyper fast Audio and Video encoder usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Cybolic 2 Posted November 15, 2018 Posted November 15, 2018 steve@steve:~$ ffmpeg ffmpeg version N-47226-gdb4771af81-static https://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2018 the FFmpeg developers built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc-6 --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gray --enable-libaom --enable-libfribidi --enable-libass --enable-libvmaf --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librubberband --enable-libsoxr --enable-libspeex --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg libavutil 56. 19.101 / 56. 19.101 libavcodec 58. 33.101 / 58. 33.101 libavformat 58. 19.100 / 58. 19.100 libavdevice 58. 4.105 / 58. 4.105 libavfilter 7. 33.101 / 7. 33.101 libswscale 5. 2.100 / 5. 2.100 libswresample 3. 2.100 / 3. 2.100 libpostproc 55. 2.100 / 55. 2.100 Hyper fast Audio and Video encoder usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}... At first glance those configuration options look fine. Is it working for you?
EODCrafter 181 Posted November 15, 2018 Posted November 15, 2018 No, I think this has been reported as some obscure GTK Issue....I'll keep using external Player with ET...
