mattyg8 18 Posted December 20, 2017 Posted December 20, 2017 Hi all, I am having an issue when using Kodi and going into some shortcuts. When I go back to the homescreen it just shows a empty screen and connect bring up menu ect. I'm using Emby plugin and Titan skin. I can open Emby movies and tv shortcuts then exit back to Homescreen with no issue. It seems to happen if I use 7, 9, 10 catch up short cuts or the Live tv guide. When I exit it goes back to homescreen but shows nothing and cannot access anything https://pastebin.com/KdGKV5A1 There seems to be a few emby issues in the log Thanks
Angelblue05 4132 Posted December 20, 2017 Posted December 20, 2017 What are the few emby issues in log? Can you give me timestamps because I'm not seeing them.
mattyg8 18 Posted December 20, 2017 Author Posted December 20, 2017 What are the few emby issues in log? Can you give me timestamps because I'm not seeing them. I believe 16:02:33.985 T:7404 WARNING: CPythonInvoker(7, C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\service.py): the python script "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.emby\service.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmc::Player,class XBMCAddon::xbmc::Monitor,class XBMCAddon::xbmc::Monitor,class XBMCAddon::xbmcaddon::Addon,class XBMCAddon::xbmcaddon::Addon,class XBMCAddon::xbmcaddon::Addon,class XBMCAddon::xbmcaddon::Addon
Angelblue05 4132 Posted December 20, 2017 Posted December 20, 2017 (edited) Nope. Those are not errors and can be ignored. What are your shortcuts set to? Can you give me an example with as much details as you can provide? Are you able to access them via launching the Emby add-on, does it crash? Edited December 20, 2017 by Angelblue05
mattyg8 18 Posted December 20, 2017 Author Posted December 20, 2017 (edited) Im not sure if it is emby or the titan theme. Menu is Movies -> Add ons -> video add on -> emby -> Movies -> Movies Tv Series -> Add ons -> video add on -> emby -> Tv Series -> Tv Series Tv Guide 7 Catch Up -> Add ons -> video add on -> 7Plus 9 Catch Up -> Add ons -> video add on -> 9Now 10 Catch Up -> Add ons -> video add on -> tenplay NBA League Pass -> Add ons -> video add on -> NBA League Pass AFL Video -> Add ons -> video add on -> AFL Video Settings -> Common -> Settings Exit -> Kodi Command - Exit It seems to crash when I click on either 7, 9, 10 catch up or Tv guide and then exit back to the homescreen it just comes up blank and cant do anything. With other themes seems not to be an issue Edited December 20, 2017 by mattyg8
Angelblue05 4132 Posted December 20, 2017 Posted December 20, 2017 (edited) I'm sorry but what are 7, 9, 10 catch up? Are they emby shortcuts? If not, then it would be an issue with the add-on they are pointing to, no? Edited December 20, 2017 by Angelblue05
mattyg8 18 Posted December 20, 2017 Author Posted December 20, 2017 (edited) I'm sorry but what are 7, 9, 10 catch up? Are they emby shortcuts? If not, then it would be an issue with the add-on they are pointing to, no? These are the AU tv catch up repo for kodi. I just wasnt sure if the was an emby plug in issue as the log showed the memory clean up issue and constantly saying no video playing. Also happens when coming out of kodi settings some times Edited December 20, 2017 by mattyg8
Angelblue05 4132 Posted December 21, 2017 Posted December 21, 2017 (edited) I'm checking for the EXCEPTION: XBMC is not playing any file But other things you've things you have reported would not be created by this and is definitely not an Emby issue. Edited December 21, 2017 by Angelblue05 1
mattyg8 18 Posted December 21, 2017 Author Posted December 21, 2017 I'm checking for the EXCEPTION: XBMC is not playing any file But other things you've things you have reported would not be created by this and is definitely not an Emby issue. Thanks I believe now it comes down to titan theme
