wp.rauchholz 5 Posted December 18, 2017 Posted December 18, 2017 I had a kind of a crisis and had to re-install my home server. emby is up and running and almost back to normal. But.. I can't see the internet radio under play on anymore. Enable DLNA Play To - is check-marked Remote Control setting in user Allow remote control of other users - is check-marked Allow remote control of shared devices - is check-marked What am I missing? It worked before. the loud speakers work fine, I can control them from my iphone Wolfgang
wp.rauchholz 5 Posted December 18, 2017 Author Posted December 18, 2017 (edited) As said above. Before I had been able to play music directly from emby Yamaha WX-030 Yamaha WX-030 Edited December 18, 2017 by wp.rauchholz
Luke 42239 Posted December 19, 2017 Posted December 19, 2017 Can you attach an emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
wp.rauchholz 5 Posted December 19, 2017 Author Posted December 19, 2017 Here are some files. Thanks, Wolfgang server-63649209456.txt server-63649238400.txt
Luke 42239 Posted December 19, 2017 Posted December 19, 2017 There's no mention of yamaha in these logs. can you try restarting those devices while emby server is running and see if that helps? thanks.
wp.rauchholz 5 Posted December 19, 2017 Author Posted December 19, 2017 That did not make the trick. Remind me please which ports have to be open on my firewall. In theory I re-configured exactly as before the crash, but you never know... Wolfgang
wp.rauchholz 5 Posted December 20, 2017 Author Posted December 20, 2017 Shame on me! I forgot the 1900UDP. Thanks
