chef 3811 Posted December 17, 2017 Posted December 17, 2017 (edited) Hi! Am I correct by updating the FileVersion in the csproj file in order to update the version of the plugin? There is something strange happening when I add the plugin to the catalog. The versions are not updating properly. Emby says it is still running 1.0.0.0 of the plugin, but the file version is 1.0.0.3 and therefore is causing emby to continuously request a restart. Edited December 17, 2017 by chef
Solution chef 3811 Posted December 17, 2017 Author Solution Posted December 17, 2017 The answer here is to make sure that both the 'FileVersion' and the 'AssembyVersion' in the csproj file of the plugin read the same update version before you update it to the catalog.
