Sammy 791 Posted February 28, 2019 Posted February 28, 2019 I'm BACK! Okay, those were my bullet cameras outside. My WiFi inside Cameras are Armcrest IP2M-841S are not working in Emby and the stream protocol is rtsp://User:Pass@<ip>:<rtsp port>/cam/realmonitor?channel=1&subtype=0 I've deleted and added them several times to try to get them to work and they won't. Thanks.
Sammy 791 Posted February 28, 2019 Posted February 28, 2019 (edited) Ezlo will be the new hardware to replace Vera hardware. Have you tried Rigpapa,s Vera >Emby plugin? You can read one use case combined with Chefs Surveillance plugin here: Emby Server api https://r.tapatalk.com/shareLink?share_fid=77624&share_tid=62047&url=https%3A%2F%2Femby%2Emedia%2Fcommunity%2Findex%2Ephp%3F%2Ftopic%2F62047-Emby-Server-api&share_type=t I just installed rigpapa's Emby plugin on my Vera last week. It is pretty cool but I suppose I need to make some settings? My Devices Dashboard in Vera is cluttered with every single Emby Client which in my case is a lot, at least 20. I see @@chef mentioned in the Vera Forum about getting a notification when playback starts on a specific device. Is this done with a scene? Thanks.. Edited February 28, 2019 by Sammy
PrincessClevage 175 Posted February 28, 2019 Posted February 28, 2019 I just installed rigpapa's Emby plugin on my Vera last week. It is pretty cool but I suppose I need to make some settings? My Devices Dashboard in Vera is cluttered with every single Emby Client which in my case is a lot, at least 20. I see @@chef mentioned in the Vera Forum about getting a notification when playback starts on a specific device. Is this done with a scene? Thanks.. in the parent device created with Vera>Emby you can select which emby clients to hide ( one you may never have automation for) . You can use Rigpapa,s reactor app to set playback condition for a client then in the reactor child device for client playback trigger set normal notifications as you would for any device in the device itself.Btw transitioning scenes and action to reactor devices has stabilised my system 1
chef 3811 Posted February 28, 2019 Author Posted February 28, 2019 in the parent device created with Vera>Emby you can select which emby clients to hide ( one you may never have automation for) . You can use Rigpapa,s reactor app to set playback condition for a client then in the reactor child device for client playback trigger set normal notifications as you would for any device in the device itself. Btw transitioning scenes and action to reactor devices has stabilised my system This is very interesting. I recently started using reactor myself. I didn't realize it was rigpas plugin. Should have known though because the outline is very much his MO.
Sammy 791 Posted February 28, 2019 Posted February 28, 2019 in the parent device created with Vera>Emby you can select which emby clients to hide ( one you may never have automation for) . You can use Rigpapa,s reactor app to set playback condition for a client then in the reactor child device for client playback trigger set normal notifications as you would for any device in the device itself. Btw transitioning scenes and action to reactor devices has stabilised my system This is very interesting. I recently started using reactor myself. I didn't realize it was rigpas plugin. Should have known though because the outline is very much his MO.I installed Reactor a while back in hopes of doing better HVAC automation but like PLEG I have not had the time to set it up. Another project to finish.. Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted February 28, 2019 Posted February 28, 2019 (edited) Ezlo will be the new hardware to replace Vera hardware. Have you tried Rigpapa,s Vera >Emby plugin? You can read one use case combined with Chefs Surveillance plugin here: Emby Server api https://r.tapatalk.com/shareLink?share_fid=77624&share_tid=62047&url=https%3A%2F%2Femby%2Emedia%2Fcommunity%2Findex%2Ephp%3F%2Ftopic%2F62047-Emby-Server-api&share_type=t This?? https://ezlo.com/ Me no likey. The one thing I do not want is having to call a cloud server for everything. I want as much local as possible. I'll stick with my VeraPlus and may go to OpenLuup eventually, given time, but never want all my automation in the cloud. Edited February 28, 2019 by Sammy
PrincessClevage 175 Posted February 28, 2019 Posted February 28, 2019 This?? https://ezlo.com/ Me no likey. The one thing I do not want is having to call a cloud server for everything. I want as much local as possible. I'll stick with my VeraPlus and may go to OpenLuup eventually, given time, but never want all my automation in the cloud. You can find the relevant ces video in this thread Big Announcement https://r.tapatalk.com/shareLink?share_fid=24007&share_tid=119300&url=http%3A%2F%2Fforum%2Emicasaverde%2Ecom%2Findex%2Ephp%3Ftopic%3D119300&share_type=t 1
chef 3811 Posted March 1, 2019 Author Posted March 1, 2019 I have reworked saving options for the surveillance plugin and will post a fix here later tonight. 1
Sammy 791 Posted March 1, 2019 Posted March 1, 2019 I have reworked saving options for the surveillance plugin and will post a fix here later tonight.Sweet! Why doesn't this get in the plugin catalog? Sent from my SM-G960U1 using Tapatalk
chef 3811 Posted March 1, 2019 Author Posted March 1, 2019 Sweet! Why doesn't this get in the plugin catalog? Sent from my SM-G960U1 using Tapatalk The IPTV plugin had quiet a bit more felxabilty, and it was decided that this plugin kind of doubled up on what was already offered. That being said, I have created a new plugin that should be put into the catalog. It is a Movie Roulette channel plugin. It creates a home screen channel which chooses a random movie to watch based on limited AI choice generator. It collects user data and then chooses movies from the library based on what it finds. Likes/favorites, watched status etc. It could go a long way. It could even tally watched status over time and remove choices from the random list that had been watched in the last month, so it doesn't recommend anything repeatedly. So that's what I've been working on: Emby Roulette
Sammy 791 Posted March 1, 2019 Posted March 1, 2019 I Remember that discussion with Luke. I disagree as having this handle a subset of streams makes it more concise. IPTV is for saving URLs of random videos found on the internet and hasn't worked with the chrome add in for some time I believe. Looking forward to Emby Roulette.. looks like fun! Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted March 7, 2019 Posted March 7, 2019 I have reworked saving options for the surveillance plugin and will post a fix here later tonight. How's that coming along? 1
Spaceboy 2573 Posted March 8, 2019 Posted March 8, 2019 Does this handle rtsp? The iptv plugin cannot
chef 3811 Posted March 8, 2019 Author Posted March 8, 2019 Does this handle rtsp? The iptv plugin cannot Yeah, rtsp seems to work best for me when I use this plugin.
Spaceboy 2573 Posted March 8, 2019 Posted March 8, 2019 Yeah, rtsp seems to work best for me when I use this plugin.cool I will take a look then
Sammy 791 Posted March 8, 2019 Posted March 8, 2019 (edited) I'm BACK! Okay, those were my bullet cameras outside. My WiFi inside Cameras are Armcrest IP2M-841S are not working in Emby and the stream protocol is rtsp://User:Pass@<ip>:<rtsp port>/cam/realmonitor?channel=1&subtype=0 I've deleted and added them several times to try to get them to work and they won't. Thanks. @@chef Any help here? rtsp://<ip>:<rtsp port>/cam/realmonitor?channel=1&subtype=0 works in monoclecam.com for use within in Alexa but rtsp://User:Pass@<ip>:<rtsp port>/cam/realmonitor?channel=1&subtype=0 does not seem to work with the surveillance plug-in in Emby. TIA BTW, monoclecam.com has separate input fields for username and password Sent from my SM-G960U1 using Tapatalk Edited March 8, 2019 by Sammy
BillOatman 597 Posted March 8, 2019 Posted March 8, 2019 Pardon the stupid questions, just found this Where is the surveillance plugin and is the source available? 1
chef 3811 Posted March 9, 2019 Author Posted March 9, 2019 (edited) @@BillOatman --->>> Surveillance.zip @ Sammy --->>> So sidetracked lately, very sorry. This is the source for the plugin. The Configuration HTML/Javascript needs some fine tuning. Specifically when the configuration xml is updated. Sorry for my messy code. This was one of my first ever plugins for emby, so it is kinda messy in parts. I seem to get sidetracked with several other code projects when I finally get time. I wish I had more time to code, unfortunately, at some point in my life, I decided that being a chef was a good idea... jokes on me.... LOL. Edited March 9, 2019 by chef 2
Sammy 791 Posted March 9, 2019 Posted March 9, 2019 Where do you chef? Would maybe like to dine there someday! Sent from my SM-G960U1 using Tapatalk
BillOatman 597 Posted March 9, 2019 Posted March 9, 2019 (edited) I wish I had more time to code, unfortunately, at some point in my life, I decided that being a chef was a good idea... jokes on me.... LOL. I am a professional programmer and wish I had more time to become a better cook. So I guess we are even And thanks for the code Edited March 9, 2019 by BillOatman
BillOatman 597 Posted March 9, 2019 Posted March 9, 2019 Looking for recommendations for inexpensive camera that works well with this. Fire away I was looking at Wansview Wireless 1080P Security Camera. It has RTSP. 1
ucjb 14 Posted April 2, 2019 Posted April 2, 2019 I just bought a Wansview Wireless 1080P Security Camera. I haven't gotten it to work with the IPTV plugin. For some reason the plugin takes forever to update. Otherwise, it's seems to be a great cam for the price.
Sammy 791 Posted May 2, 2019 Posted May 2, 2019 Is it possible to have the Vera Plugin trigger a task in Windows? I started a thread here to pose the question. Thanks. Sent from my SM-G960U1 using Tapatalk
PrincessClevage 175 Posted May 3, 2019 Posted May 3, 2019 @@BillOatman --->>> Surveillance.zip @ Sammy --->>> So sidetracked lately, very sorry. This is the source for the plugin. The Configuration HTML/Javascript needs some fine tuning. Specifically when the configuration xml is updated. Sorry for my messy code. This was one of my first ever plugins for emby, so it is kinda messy in parts. I seem to get sidetracked with several other code projects when I finally get time. I wish I had more time to code, unfortunately, at some point in my life, I decided that being a chef was a good idea... jokes on me.... LOL. Hi Chef,With the latest emby server updates your home Surveillance plugin no longer shows up in the emby client but I can see it listed under emby server plugins... 1
Sammy 791 Posted May 3, 2019 Posted May 3, 2019 Luke thought it too closely represented the IPTV plugin so he removed it from the library. You have to install it by dropping the dll. Sent from my SM-T700 using Tapatalk
