PrincessClevage 175 Posted August 25, 2018 Posted August 25, 2018 Oh boy! My Vera edge showed up! Got it setup and updated! Good news is that I got to see my emby plugin work in different ways. Using new images. I always wondered if that worked properly... And it does!good to hear Chef.FYI I have started a thread on the Mios Vera forums for Vera > Emby integration, if your interested it is here: Vera 2 Emby https://r.tapatalk.com/shareLink?share_fid=24007&share_tid=103145&url=http%3A%2F%2Fforum%2Emicasaverde%2Ecom%2Findex%2Ephp%3Ftopic%3D103145&share_type=t
chef 3811 Posted August 27, 2018 Author Posted August 27, 2018 (edited) Well I have taken a good look at vera plugins. I can honestly say it is confusing a hell. The best I can do is write a service in c# that monitors events on the Vera device and can trigger emby http command lines. It has a fancy web configuration UI, but me and luua code don't mix well. On the other hand I almost have a Phillips hue plugin worth testing Edited August 27, 2018 by chef
PrincessClevage 175 Posted August 27, 2018 Posted August 27, 2018 (edited) Well I have taken a good look at vera plugins. I can honestly say it is confusing a hell. The best I can do is write a service in c# that monitors events on the Vera device and can trigger emby http command lines. It has a fancy web configuration UI, but me and luua code don't mix well. On the other hand I almost have a Phillips hue plugin worth testing Can you shed any light on the JavaScript required command that Luke has referenced here:Perhaps cw-kid can look after the vera side once the correct commands have been established Emby Server api https://r.tapatalk.com/shareLink?share_fid=77624&share_tid=62047&url=https%3A%2F%2Femby%2Emedia%2Fcommunity%2Findex%2Ephp%3F%2Ftopic%2F62047-Emby-Server-api&share_type=t Edited August 27, 2018 by PrincessClevage
hstamas 179 Posted August 27, 2018 Posted August 27, 2018 On the other hand I almost have a Phillips hue plugin worth testing Sweet!
hstamas 179 Posted October 9, 2018 Posted October 9, 2018 On the other hand I almost have a Phillips hue plugin worth testing Any progress Chef?
PrincessClevage 175 Posted January 18, 2019 Posted January 18, 2019 Chef your Surveillance and Vera plugin may need an update with the recent emby server update rollout 1
Sammy 791 Posted January 18, 2019 Posted January 18, 2019 On it I'll take a look tonight [emoji3]I don't see either in the beta 4.1.0.0 plugin catalog. I haven't rolled 3.5.3 to 4.0.0.2 yet so IDK about that. Sent from my SM-G960U1 using Tapatalk
chef 3811 Posted January 19, 2019 Author Posted January 19, 2019 The plugin was updated. If there are issues with how it runs let me know. There was at least one change to the IHttpClient, which the Vera plugin relies on heavily. Also, the thumb image should show up now properly.
PrincessClevage 175 Posted January 19, 2019 Posted January 19, 2019 The plugin was updated. If there are issues with how it runs let me know. There was at least one change to the IHttpClient, which the Vera plugin relies on heavily. Also, the thumb image should show up now properly. Thanks Chef, will Check a bit later
chef 3811 Posted January 19, 2019 Author Posted January 19, 2019 (edited) I don't see either in the beta 4.1.0.0 plugin catalog. I haven't rolled 3.5.3 to 4.0.0.2 yet so IDK about that. Sent from my SM-G960U1 using Tapatalk Oh boy you're bleeding edge. I only set it to 4.0.0.2 I can make beta. But first I have to figure out what changed in the Play request object, my Amazon Alexa is currently broken... Edited January 19, 2019 by chef
chef 3811 Posted January 19, 2019 Author Posted January 19, 2019 Okay, I figured out what changed. I love the new plugin architecture!! It is really really awesome! I will update Vera to beta next 1
chef 3811 Posted January 19, 2019 Author Posted January 19, 2019 @@PrincessClevage Here is the Surveillance plugin. Let me know if there is any issues with it Surveillance.zip 3
chef 3811 Posted January 19, 2019 Author Posted January 19, 2019 @@Sammy, I seem to be having an issue with releasing beta version of the plugin. I'm not sure what I'm doing incorrectly, but I'll get it figured out. I'm not sure which MediaBrowser.Core dependency to target, so this might take a moment to figure out! 1
Sammy 791 Posted January 20, 2019 Posted January 20, 2019 (edited) @@PrincessClevage Here is the Surveillance plugin. Let me know if there is any issues with it Surveillance.zip Where to drop it? @@Luke Why can't this be in the Plugin Catalog? Edited January 20, 2019 by Sammy
chef 3811 Posted January 20, 2019 Author Posted January 20, 2019 Put the dll in the Emby-Server/programdata/plugins folder 1
Sammy 791 Posted January 21, 2019 Posted January 21, 2019 (edited) What's the protocol for setting up the cameras? Edited January 21, 2019 by Sammy
Sammy 791 Posted January 21, 2019 Posted January 21, 2019 BTW, this is what I see in the Vera Plugin Settings Screen, making it hard to set up.
chef 3811 Posted January 21, 2019 Author Posted January 21, 2019 BTW, this is what I see in the Vera Plugin Settings Screen, making it hard to set up. Color Issue.JPG Okay, I'll take a look at the style sheets and see what happened there. Thank you. I'll fix it and push a release. 1
chef 3811 Posted January 26, 2019 Author Posted January 26, 2019 @@Sammy do you have custom CSS in emby? Because I went to check on the style issues and I can't reproduce the issue you are seeing.
Sammy 791 Posted January 30, 2019 Posted January 30, 2019 @@Sammy do you have custom CSS in emby? Because I went to check on the style issues and I can't reproduce the issue you are seeing. not seeing the problem.png I don't think so. I've seen that setting in the server but never messed with it before.
Sammy 791 Posted January 30, 2019 Posted January 30, 2019 Also, Still trying to figure out the protocol, the correct string to input, so that my Cameras appear in Emby. TIA
Sammy 791 Posted February 26, 2019 Posted February 26, 2019 Also, Still trying to figure out the protocol, the correct string to input, so that my Cameras appear in Emby. TIA @@chef Any help here? TIA Sent from my SM-G960U1 using Tapatalk
