PrincessClevage 175 Posted February 28, 2018 Posted February 28, 2018 @@chef I assume these are the Vera API changes you mention? http://forum.micasaverde.com/index.php/topic,56959.0.html They have broken some Vera plugins like the DLNA and Sonos ones, with no fixes looking likely. I used the DLNA one and now TTS no longer seems to work with it and it no longer discovers new DLNA devices on your network. My Sonos and TTS are working fine in Vera
PrincessClevage 175 Posted February 28, 2018 Posted February 28, 2018 (edited) The good news is, if you use the vera plugin you'll be able to piggy back on Embys DLNA server to trigger vera scenes by way of playback. Luke updated the NuGet packages for emby again so Vera plugin will be working again tonight. The only issue I can see regarding any DLNA integration by way of Vera with those issues mentioned above, is that if you use the emby plugin, then you'll have to rely on emby server to initiate any playback, by way of DLNA, to trigger commands, instead of the Vera plugins from micasaverde. In a way it is kind of a good thing for this plugin that they aren't going to fix their plugin issues because it kinda forces the use of our plugin to get the desired control. Chef does this upcoming security update that cw-kid has provided a link for mean that emby Vera plugin in will be required to authenticate with Vera before it can see or run any scenes I.e Vera will be in secure mode that I previously mention to you? Edited February 28, 2018 by PrincessClevage
chef 3811 Posted February 28, 2018 Author Posted February 28, 2018 Well we do use port 3480 so it is possible, but I am wondering because we are on the subnet with the Vera device if we are prone to this. They'll probably incorporate some sort of authentication token for requests. But we'll be ready for it. I'll see about joining their beta team to see about getting early access to the new authentication code.
cw-kid 192 Posted February 28, 2018 Posted February 28, 2018 @PrinessClevage Which TTS engine you using with the Vera Sonos plugin? Transport controls are working on my DLNA devices in Vera but the TTS stopped working and the DLNA plugin no longer discovers new DLNA devices on the network.
chef 3811 Posted February 28, 2018 Author Posted February 28, 2018 I have sent a message to the beta developers explaining our situation over here at emby, and asked how their security implementations will affect us. Gave a quick explanation of how our plugin works, too see if what they have to say about. The part that makes me think we're going to be okay is where they write: "except the local loopback interface (localhost / 127.0.0.1)" But, then they write: This issue affects only requests made by a network device, meaning they are coming to Vera on a LAN or WAN interface. Solution This issue can't be fully fixed by the plugin developers, however, it's necessary that all the data_requests are made on port_3480, and NOT directly on port 3480, or on port 49451, or on port_49451. So, any request that looks like this: http://VERA_IP:3480/data_request?id=SOME_VALUE http://VERA_IP:49451/data_request?id=SOME_VALUE http://VERA_IP/port_49451/data_request?id=SOME_VALUE Must be rewritten to look like this: http://VERA_IP/port_3480/data_request?id=SOME_VALUE Which is exactly what we do in the plugin.... So... some changes are going to be needed. Why change the port number in the request command line (example: "3480") to "port_3480"??? I don't get it... Good, they have security rolling out... I would imagine that currently, it would be kind of easy to brute force attack vera products. Especially since they use a redirect to locate each device.
PrincessClevage 175 Posted February 28, 2018 Posted February 28, 2018 (edited) @PrinessClevage Which TTS engine you using with the Vera Sonos plugin? Transport controls are working on my DLNA devices in Vera but the TTS stopped working and the DLNA plugin no longer discovers new DLNA devices on the network. I use Responsive voice and I made a post below to help others locate the files to manually upload to Vera so you can select responsive voice New TTS engine: Microsoft Translator https://r.tapatalk.com/shareLink?share_fid=24007&share_tid=33223&url=http%3A%2F%2Fforum%2Emicasaverde%2Ecom%2Findex%2Ephp%3Ftopic%3D33223&share_type=t Edited February 28, 2018 by PrincessClevage
cw-kid 192 Posted February 28, 2018 Posted February 28, 2018 @@chef Thats how I read it also, so I changed all my json http commands I use from http://Vera-IP:3480 to be http://Vera-IP/port_3480/ They are working anyway with the new format.
chef 3811 Posted February 28, 2018 Author Posted February 28, 2018 I pushed an update to the Vera app. But it is temporary. I have a new version coming which is all around coded better. 2
chef 3811 Posted March 1, 2018 Author Posted March 1, 2018 New version of Surveillance plugin should delete cameras now. Sorry, javascript had a spelling mistake, and my IDE is sucking! 1
cw-kid 192 Posted March 1, 2018 Posted March 1, 2018 @@chef I can confirm that deleting camera entries now works and they have gone! 1
cw-kid 192 Posted March 1, 2018 Posted March 1, 2018 @@chef Is there any more information I can provide or a log file or something regarding my rtsp stream not working? Thank you. 1
chef 3811 Posted March 1, 2018 Author Posted March 1, 2018 @@chef Is there any more information I can provide or a log file or something regarding my rtsp stream not working? Thank you. Could you post a server log from a time when you attempted to start the stream? The streaming issue is the next priority.
karldonteljames 3 Posted March 3, 2018 Posted March 3, 2018 I'm not sure this is the right place for this post, but how can I change the surveillance plugin image? It doesn't quite look right. lol
chef 3811 Posted March 3, 2018 Author Posted March 3, 2018 Pushed an update for Vera Home Automation this morning. YOu'll find it available in the Dashboard Navigation Area under "Home Automation". I also fixed the Configuration UI and the List of Devices reported in the plugin. It was duplicating device names. It doesn't do that anymore. And the Saved Device has been redrawn to fit with the EMby UI better. Quick Question for those who use it. Does the UI show a picture of your vera unit at the top? I'm trying to get proper images to show. If you happen to not see an image of your vera unit beside your Veras IP please let me know so I can add it to a list of possible devices! If there are any problems with the update, let me know. Thanks!!
chef 3811 Posted March 3, 2018 Author Posted March 3, 2018 (edited) I'm not sure this is the right place for this post, but how can I change the surveillance plugin image? It doesn't quite look right. lol Yep, this is the right place! If you hover over the Surveillance channel image with your mouse, there should be a "slide=up" menu which appears where you can edit the images. let me know how it goes Edited March 3, 2018 by chef 1
karldonteljames 3 Posted March 3, 2018 Posted March 3, 2018 Yep, this is the right place! If you hover over the Surveillance channel image with your mouse, there should be a "slide=up" menu which appears where you can edit the images. let me know how it goes Perfect! Thank you!!!
PrincessClevage 175 Posted March 3, 2018 Posted March 3, 2018 (edited) Pushed an update for Vera Home Automation this morning. YOu'll find it available in the Dashboard Navigation Area under "Home Automation". I also fixed the Configuration UI and the List of Devices reported in the plugin. It was duplicating device names. It doesn't do that anymore. And the Saved Device has been redrawn to fit with the EMby UI better. Quick Question for those who use it. Does the UI show a picture of your vera unit at the top? I'm trying to get proper images to show. If you happen to not see an image of your vera unit beside your Veras IP please let me know so I can add it to a list of possible devices! If there are any problems with the update, let me know. Thanks!! My Vera Edge shows its picture correctly and the movie pause and Unpause functionality is now working again.Thanks again for this great addin for Emby ! Edited March 3, 2018 by PrincessClevage 1
Crestj 68 Posted March 7, 2018 Posted March 7, 2018 (edited) Here's a server log for an attempt to stream a camera I have. Works fine through VLC so the string is correct. Edited March 8, 2018 by Crestj
chef 3811 Posted March 8, 2018 Author Posted March 8, 2018 Here's a server log for an attempt to stream a camera I have. Works fine through VLC so the string is correct. @@Crestj better to pm logs.
chef 3811 Posted March 8, 2018 Author Posted March 8, 2018 @@Crestj and @@cw-kid, you guys are experiencing the same issue with the plugin. Would you guys be interested in installing the IPTV plugin, adding the security camera URL to that plugin and attempt live stream playback? Would it be possible to let me know if you are able to get the stream working? Both these plugins are very similar, so if the IPTV plugin works then I would be able to narrow the issues better.
cw-kid 192 Posted March 8, 2018 Posted March 8, 2018 @@Crestj and @@cw-kid, you guys are experiencing the same issue with the plugin. Would you guys be interested in installing the IPTV plugin, adding the security camera URL to that plugin and attempt live stream playback? Would it be possible to let me know if you are able to get the stream working? Both these plugins are very similar, so if the IPTV plugin works then I would be able to narrow the issues better. I installed the IPTV plugin and added my camera using the RTSP url. It doesn't play either in Chrome web browser, just get a spinning circle also. If I change the url and remove the .h264 from the end of it then I get a play back error same as with the Surveillance plugin. 1
chef 3811 Posted March 8, 2018 Author Posted March 8, 2018 (edited) So it sounds like a codec issue in ffmpeg, so far. We'll see what crestj findings are. Or, there is an issue with authenticating the request for the stream. Which could also be an issue. Edited March 8, 2018 by chef
Crestj 68 Posted March 8, 2018 Posted March 8, 2018 (edited) Black screen with no actual error like the Surveillance plugin. Logs PM'd Edited March 8, 2018 by Crestj
Fratopolis 64 Posted March 11, 2018 Posted March 11, 2018 Love the Surveillance plugin. though will not allow me to delete old cameras. I am on 3.3.1.0, I read there were issues when 3.3.0.0 came out and wonder if they are back. Also changing the address of an existing camera shows that is saved but when going to the gui to watch it shows the old rtsp url and does not work. The plugin config file under the server folder shows the setting is correct so it must be a stored elsewhere?
