PrincessClevage 175 Posted December 8, 2019 Posted December 8, 2019 Version 1.0.2.2 went up this afternoon. Perhaps a Server restart might force the update plugin task to runThere used to be a scheduled task that we could run to for a check for app updates, has this been removed?
chef 3811 Posted December 8, 2019 Author Posted December 8, 2019 There used to be a scheduled task that we could run to for a check for app updates, has this been removed? It's a hidden task. It is still there and gets triggered, but it doesn't exist to trigger manually. It will trigger eventually. Where you able to install 1.0.2.2?
PrincessClevage 175 Posted December 8, 2019 Posted December 8, 2019 (edited) It's a hidden task. It is still there and gets triggered, but it doesn't exist to trigger manually. It will trigger eventually. Where you able to install 1.0.2.2? Yes, after a complete restart of server (not ideal) and I fail to understand what they have hidden the check for app updates tasks:-( The Vera interface now load but when I click on my previous set profile it does not display any of the previously selected settings? Edit: Once Vera app is reconfigured, the set settings load correctly each time I exit and load saved profile again. Thanks Chef Edited December 8, 2019 by PrincessClevage
chef 3811 Posted December 8, 2019 Author Posted December 8, 2019 Yes, after a complete restart of server (not ideal) and I fail to understand what they have hidden the check for app updates tasks:-( The Vera interface now load but when I click on my previous set profile it does not display any of the previously selected settings? I check it out. Would you mind clearing the browser data, and then refreshing the plugin page?
PrincessClevage 175 Posted December 8, 2019 Posted December 8, 2019 I check it out. Would you mind clearing the browser data, and then refreshing the plugin page? Edit: Once Vera app is reconfigured, the set settings load correctly each time I exit and load saved profile again. Thanks Chef 1
chef 3811 Posted December 8, 2019 Author Posted December 8, 2019 I should have updated it last week when I saw the bug, then there wouldn't have been issues. I'll definitely keep on it for the next time. 1
PrincessClevage 175 Posted December 8, 2019 Posted December 8, 2019 I should have updated it last week when I saw the bug, then there wouldn't have been issues. I'll definitely keep on it for the next time. I don’t often make changes to it and it just works...But just so happened that I wanted to add in a disable of tts notifications while watching movies and tv.. all done and thanks again
