GTerplan 0 Posted June 22, 2019 Posted June 22, 2019 Can you show an example of the naming the device had? I think that the core emby developers will be interested in this because it would seem to be a bug in the device naming at the core level. I think... I'll also look at the plugin code and see how that character might cause issues.
GTerplan 0 Posted June 22, 2019 Posted June 22, 2019 Can you show an example of the naming the device had? I think that the core emby developers will be interested in this because it would seem to be a bug in the device naming at the core level. I think... I'll also look at the plugin code and see how that character might cause issues. Yes, it was titled George's Fire TV Cube and I removed George's
BillOatman 597 Posted June 22, 2019 Posted June 22, 2019 (edited) Likely the apostrophe there chef Hmmm I should add one to one of my devices and check the Hue plugin Edited June 22, 2019 by BillOatman 1
PrincessClevage 175 Posted June 23, 2019 Posted June 23, 2019 Yeah it is like communication to the Xbox one is.Gents are you able to make any sense of the protocol for sending an on/off command from win 10 os environment?
chef 3811 Posted June 24, 2019 Author Posted June 24, 2019 It's hard to say for sure. I should have bought the thing when they where selling them. They where a little pricey at the time. I'll get back about it.
BillOatman 597 Posted June 24, 2019 Posted June 24, 2019 A protocol like that, it's going t be difficult to do without having one of them to test with.
chef 3811 Posted June 26, 2019 Author Posted June 26, 2019 I'm about to release a new version of Vera again. I added the ability to choose which vera device on your network, instead of using an overrride option and manually typing in the device. This will just scan the network for all of them and then put them in a list to choose from. 1
PrincessClevage 175 Posted June 27, 2019 Posted June 27, 2019 I really want to stop handling UI5 in the Vera plugin. It makes the code extremely messy and hard to deal with Does anyone using the Vera plugin currently run Vera UI 5 on in their hub? I want to delete the code that handles it from the plug-in!! If anyone still uses UI5 for Vera now is the time to say something! {Finger tediously hovering over 'Del'} [emoji12] Not I
chef 3811 Posted June 27, 2019 Author Posted June 27, 2019 (edited) Alright, it's been a day, and I'm going to release a UI7 only version of this. It cuts the code in half if you can believe that! It's much easier to read and maintain. Maybe, just in case, I'll keep a version in beta form for ui5 and people can download that. Edited June 27, 2019 by chef
Sammy 791 Posted June 27, 2019 Posted June 27, 2019 When will we be able to grab this? I have never used UI5, BTW.
chef 3811 Posted June 27, 2019 Author Posted June 27, 2019 Very soon @@Sammy, I just have to erase all the supporting code and check that it all works with UI7. 1
chef 3811 Posted June 27, 2019 Author Posted June 27, 2019 (edited) I released a version for which, it would be great to know works when someone has multiple veras on their network. Also I added security to the Vera Device Info endpoints so that no one can sniff the network and find out our home automation endpoints. If you don;t have Live TV then those options should be disabled. This is the final version which works with UI5, all other version from here on out will not work with UI5. I'll post a version here on this thread in case someone needs to find one that works with UI5, and they should never install new version afterwards. Edited June 27, 2019 by chef
chef 3811 Posted June 28, 2019 Author Posted June 28, 2019 Okay here is a Surveillance plugin version which will not play intro before the stream. Sorry it took so long. Surveillance.zip 2
PrincessClevage 175 Posted June 29, 2019 Posted June 29, 2019 Okay here is a Surveillance plugin version which will not play intro before the stream. Sorry it took so long. Surveillance.zip Thanks Chef works great now
chef 3811 Posted July 1, 2019 Author Posted July 1, 2019 I found a bug in the Vera plugin. I had accidentally left in some jQuery and it was broken. I put up a new release to fix it this morning. Also, version 1.0.1.5 doesn't work with UI5. 1
cw-kid 192 Posted July 22, 2019 Posted July 22, 2019 Hi I take it camera's that have RTSP stream which is h.264 still don't work ? I just updated the "Home Security Camera Channel" plugin using the last .dll file post in this thread, it now show as version 1.0.0.14 When trying to play the camera in the Emby web GUI in Chrome it says; Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details. Thanks
PrincessClevage 175 Posted September 22, 2019 Posted September 22, 2019 Okay here is a Surveillance plugin version which will not play intro before the stream. Sorry it took so long. Surveillance.zip Hi Chef,Cameras are not showing in this plugin any more...
chef 3811 Posted September 22, 2019 Author Posted September 22, 2019 (edited) @@PrincessClevage Do you mean in the configuration, or on the channel? Which emby version are you running? Edited September 22, 2019 by chef
PrincessClevage 175 Posted September 22, 2019 Posted September 22, 2019 @@PrincessClevage Do you mean in the configuration, or on the channel? Which emby version are you running? not showing in the channel. I am running v 1.0.0.14
chef 3811 Posted September 22, 2019 Author Posted September 22, 2019 not showing in the channel. I am running v 1.0.0.14 Ops, sorry I mean which version of the server? Sorry.
PrincessClevage 175 Posted September 22, 2019 Posted September 22, 2019 Ops, sorry I mean which version of the server? Sorry.4.2.1.0
chef 3811 Posted September 22, 2019 Author Posted September 22, 2019 Strange, I can't replicate this. Could you run the schedule task Refresh Internet Channels'? I'm just wondering why it broke all of a sudden.
PrincessClevage 175 Posted September 22, 2019 Posted September 22, 2019 (edited) Strange, I can't replicate this. Could you run the schedule task Refresh Internet Channels'? I'm just wondering why it broke all of a sudden. Thanks that fixed cameras showing in the channel!I had to reload the plugin after a recent reset of emby server. I am trying to get a stream from a foscam R2 1080p Https://www.ispyconnect.com/man.aspx?n=foscam&page=18 Does not seem to load. Edited September 22, 2019 by PrincessClevage
PrincessClevage 175 Posted September 22, 2019 Posted September 22, 2019 Typo in the previous URL Https://www.ispyconnect.com/man.aspx?n=foscam&page=18
