japi 0 Posted December 14, 2017 Posted December 14, 2017 Hi I've been using emby server with my odroid-xu4 ubuntu 16.04 for half year and it has been worked fine until month or so after upgrading packets it started to die after couple minutes of streaming. Now service dies ● emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Thu 2017-12-14 17:21:15 EET; 1min 17s ago Process: 18575 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SUCCESS) Process: 18331 ExecStart=/usr/bin/emby-server start (code=exited, status=134) Main PID: 18331 (code=exited, status=134) Dec 14 17:19:58 odroid systemd[1]: Started Emby Media Server. Dec 14 17:19:58 odroid su[18331]: Successful su for emby by root Dec 14 17:19:58 odroid su[18331]: + ??? root:emby Dec 14 17:19:58 odroid su[18331]: pam_unix(su:session): session opened for user emby by (uid=0) Dec 14 17:21:15 odroid systemd[1]: emby-server.service: Main process exited, code=exited, status=134/n/a Dec 14 17:21:15 odroid systemd[1]: emby-server.service: Unit entered failed state. Dec 14 17:21:15 odroid systemd[1]: emby-server.service: Failed with result 'exit-code'. what might be wrong? I'm totally stuck... Thanks Japi
mastrmind11 722 Posted December 14, 2017 Posted December 14, 2017 Hi I've been using emby server with my odroid-xu4 ubuntu 16.04 for half year and it has been worked fine until month or so after upgrading packets it started to die after couple minutes of streaming. Now service dies ● emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Thu 2017-12-14 17:21:15 EET; 1min 17s ago Process: 18575 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SUCCESS) Process: 18331 ExecStart=/usr/bin/emby-server start (code=exited, status=134) Main PID: 18331 (code=exited, status=134) Dec 14 17:19:58 odroid systemd[1]: Started Emby Media Server. Dec 14 17:19:58 odroid su[18331]: Successful su for emby by root Dec 14 17:19:58 odroid su[18331]: + ??? root:emby Dec 14 17:19:58 odroid su[18331]: pam_unix(su:session): session opened for user emby by (uid=0) Dec 14 17:21:15 odroid systemd[1]: emby-server.service: Main process exited, code=exited, status=134/n/a Dec 14 17:21:15 odroid systemd[1]: emby-server.service: Unit entered failed state. Dec 14 17:21:15 odroid systemd[1]: emby-server.service: Failed with result 'exit-code'. what might be wrong? I'm totally stuck... Thanks Japi What is the output of : sudo journalctl -xe | grep -emby
japi 0 Posted December 14, 2017 Author Posted December 14, 2017 What is the output of : sudo journalctl -xe | grep -emby It shows nothing
mastrmind11 722 Posted December 14, 2017 Posted December 14, 2017 It shows nothing what about sudo journalctl -xe | grep emby if nothing, what about sudo journalctl -xe
japi 0 Posted December 14, 2017 Author Posted December 14, 2017 (edited) heres log attached. log.txt Edited December 14, 2017 by japi
Solution Luke 42245 Posted December 14, 2017 Solution Posted December 14, 2017 I notice you're running mono 5.4. Our highest supported version is 4.8.1. We've seen crashes with anything beyond that. Please consider rolling that back. Thanks. 1
mastrmind11 722 Posted December 14, 2017 Posted December 14, 2017 Was just about to say your mono version is no good but @@Luke beat me. Anyway, that should fix it.
japi 0 Posted December 14, 2017 Author Posted December 14, 2017 Thanks downgraded mono to 4.8.1 and now it works
