guymyer 1 Posted December 18, 2017 Author Posted December 18, 2017 Thanks. I have many files, too many to start going through and converting. I'll keep an eye out for an update.
ebr 16337 Posted December 18, 2017 Posted December 18, 2017 The latest beta should already have a fix. Thanks. Android Open Beta Testing
guymyer 1 Posted December 18, 2017 Author Posted December 18, 2017 What's the version number of the new beta? I wanna check it later.
CBers 7554 Posted December 18, 2017 Posted December 18, 2017 What's the version number of the new beta? I wanna check it later. Join the beta stream and you will get the latest version, which currently is, v1.5.19. The latest beta should already have a fix. Thanks. Android Open Beta Testing
