Luke 42245 Posted December 15, 2017 Posted December 15, 2017 Thanks for the feedback. I'm sure @@ebr will be able to work with you to get to the bottom of what's happening with the play button.
ebr 16337 Posted December 15, 2017 Posted December 15, 2017 so i gave the file to my friend to have him put on his emby server (he lives in florida i live in Massachusetts) i try to type in his address to connect to his server from within the emby app doesn't work nothing happens. but i can connect to his server on my pc and phone. so basically my shield can only connect to my local server and thats it We're delving into a completely different area here but, if you are trying to use https on the Shield, your friend would have to have a proper certificate setup (not self-signed) or the device will reject it.
ebr 16337 Posted December 15, 2017 Posted December 15, 2017 Thanks for the sample. I was really hoping somehow it would be related to the content but this item works fine for me. I'm at a bit of a loss as to what is happening here as there are no messages at all related to you hitting that button. It is like the interface simply isn't telling us you're hitting it. Does the system make an audible sound when you hit it? If you use the "play" button on your remote does it work?
provokaz 0 Posted December 15, 2017 Posted December 15, 2017 yeah it makes the normal clicking sound as if eveything was working alright
ebr 16337 Posted December 15, 2017 Posted December 15, 2017 A click? That is usually for simple navigation. When pressing a button, it should be more of a "ba-dump" sound...
provokaz 0 Posted December 15, 2017 Posted December 15, 2017 (edited) yeah its s simple navigation click, i didnt even realize there were two different sounds till noow the sound is more like a snap tiss Edited December 15, 2017 by provokaz
ebr 16337 Posted December 15, 2017 Posted December 15, 2017 You can navigate around that screen normally and press the other buttons?
ebr 16337 Posted December 15, 2017 Posted December 15, 2017 And this is the same for all your media or just certain items? Have you adjusted anything in the device configuration related to font sizes or anything like that?
provokaz 0 Posted December 15, 2017 Posted December 15, 2017 im not sure about the sound i can check when im home. as for the sheild i bought it on monday havent changed a thing. ill try reseting the entire thing
provokaz 0 Posted December 16, 2017 Posted December 16, 2017 (edited) https://www.youtube.com/watch?v=DcSyqPYo28s&feature=youtu.be that's a link to a video showing all the sounds and stuff edit: may have to turn it up a little to hear the clickies loledit: so i did an entire wipe of the shield and restored it didn't touch anything just installed emby and the play button problem still exists Edited December 16, 2017 by provokaz
ebr 16337 Posted December 16, 2017 Posted December 16, 2017 Thanks very much. The interesting thing is - the one that worked appeared to not be properly identified. Do you have external access to your server setup and working? If so, could you invite me as a guest and maybe I can reproduce here attached to your server?
provokaz 0 Posted December 16, 2017 Posted December 16, 2017 (edited) that's neat didn't know linking i could just forum invite you. if you need admin access let me know i'll set you up an account Edited December 16, 2017 by provokaz
ebr 16337 Posted December 16, 2017 Posted December 16, 2017 Okay, I have this fixed for the next release. To make it work now for you you can either: 1) Turn off the option to auto queue next episodes OR 2) Go through that series and be sure that all the episodes have the proper season and episode number. I think it may actually be that duplicate of episode 1 that is not properly identified that is causing the issue. Of course, the app shouldn't just crap out and do nothing in this case and that will be fixed in the next release. Thanks again.
provokaz 0 Posted December 16, 2017 Posted December 16, 2017 thankyou thats awesome appreciate it alot
