breezytm 124 Posted December 14, 2017 Posted December 14, 2017 Hey ebr, Is it by design the Shield TV doesn't select the best audio track? I have two audio tracks on my TV shows. First track is AAC 2.0 and second track is AC3 6 channels. It always selects the first track. It is so annoying that I have to manually switch every time.
breezytm 124 Posted December 14, 2017 Author Posted December 14, 2017 (edited) The first one. But I don't want Emby to pick the default track. I want it to determine which one is the best and supported track by my hardware and use it. Edited December 14, 2017 by breezytm
ebr 16337 Posted December 14, 2017 Posted December 14, 2017 The first one. But I don't want Emby to pick the default track. I want it to determine which one is the best and supported track by my hardware and use it. There really isn't any way for us to know what "best" is because we might select an alternate audio track. That is why we key off the default because you can set that to what you wish. However, once you have selected it for a video once, it will select that track again on subsequent playbacks.
breezytm 124 Posted December 14, 2017 Author Posted December 14, 2017 However, once you have selected it for a video once, it will select that track again on subsequent playbacks. Except it does not. I have to manually select every time. There really isn't any way for us to know what "best" is because we might select an alternate audio track. That is why we key off the default because you can set that to what you wish. I don't know how the AppleTV does it but it has an option to always select the best track and it always actually does chose the best track. I am tired of having to manually selecting. Even Plex and Kodi does the same thing.
ebr 16337 Posted December 14, 2017 Posted December 14, 2017 Except it does not. I have to manually select every time. Do you have the option in your user settings on the web app to always play the default audio track set?
breezytm 124 Posted December 14, 2017 Author Posted December 14, 2017 Do you have the option in your user settings on the web app to always play the default audio track set? It was checked. I just uncheck it and will see if it makes a difference when I get home. How about a setting that allows the user to pick which track to always be used. Default can be selected by default.
