Nosferatu 2 Posted December 13, 2017 Posted December 13, 2017 (edited) As the title states. I bought a Chromecast for an extra room to play content. It plays all content fine video-wise. Dolby Digital 5.1 is sent and played correctly as 5.1. DTS 5.1 is sent and played as a 2 channel stereo track. How do I get the Chromecast to play DTS 5.1 in 5.1. From what I've gathered it's a limitation of the Chromecast unit so it needs a transcoded audio file to a format it can read on 5.1. I run a Core i7 24/7/365 which is what Emby Server sits on so I don't care if it's something that is processor intensive to get it working. However what I do care about is having the 5.1 (or 7.1) streams of these files to not be transcoded on other devices (that aren't Chromecast). I have dedicated HTPCs in house running Kodi (with Emby as the back end) and I don't want them being transcoded for those rooms given the much better audio equipment. Those machines require the direct stream as some of the 5.1/7.1 are DTS-MA or TrueHD and I don't want to lose the loseless audio. I did some searching and some of the threads were old. Thanks! Edited December 13, 2017 by Nosferatu 1
Luke 42244 Posted December 13, 2017 Posted December 13, 2017 We used to transcode 5.1 DTS to 5.1 AAC but in a recent firmware update Google dropped support for 5.1 AAC claiming that it was a proprietary codec that would require them to license. I then tried to transcode to 5.1 AC3 but recent Chromecast firmware updates are having trouble with this. That is why it currently converts to stereo. There have been numerous firmware updates in recent weeks. I will re-evaluate again in the near future when all the changes have settled down and try 5.1 AC3 again. Thanks ! 1
Nosferatu 2 Posted December 13, 2017 Author Posted December 13, 2017 (edited) We used to transcode 5.1 DTS to 5.1 AAC but in a recent firmware update Google dropped support for 5.1 AAC claiming that it was a proprietary codec that would require them to license. I then tried to transcode to 5.1 AC3 but recent Chromecast firmware updates are having trouble with this. That is why it currently converts to stereo. There have been numerous firmware updates in recent weeks. I will re-evaluate again in the near future when all the changes have settled down and try 5.1 AC3 again. Thanks ! Interesting. Also thank you for the very fast reply! Is there a work around to get it to transcode correctly? My living room has a Sony TV (XBR75X940E) with Android TV built in. I noticed it plays all my 5.1 files in 5.1 however it appears my DTS files are being passed to my receiver thru the TV as Dolby Digital 5.1. Is this Emby or the TV doing the format change? If it's Emby then couldn't the server just send a 5.1 stream in a different format that the Chromecast is happy with? Edited December 13, 2017 by Nosferatu 1
Luke 42244 Posted December 13, 2017 Posted December 13, 2017 Now I think you're just asking the same question in a different way so let's circle back to my previous response. Thanks !
Nosferatu 2 Posted December 13, 2017 Author Posted December 13, 2017 Now I think you're just asking the same question in a different way so let's circle back to my previous response. Thanks ! Haha fair enough. Thanks for the prompt reply regardless!
Guest asrequested Posted December 23, 2017 Posted December 23, 2017 I think this is the same issue, correct me if I'm wrong. I've been experimenting with casting from my phone to my tv, which has the Vizio Smartcast feature. I've raised settings to 4k 120Mb/s, the TV has a very strong wireless connection (high bandwidth), etc. But almost everything I play, transcodes. If I play something that has an AAC stereo track, it direct plays. Everything else does a full transcode.
Luke 42244 Posted December 23, 2017 Posted December 23, 2017 That is transcoding due to video level 50 not being supported. To find out on your own why something is transcoding, you can always use the emby server dashboard. Thanks !
Guest asrequested Posted December 24, 2017 Posted December 24, 2017 Ah, right. I hadn't considered that. What is the maximum level presently supported?
McGregorMX 0 Posted January 26, 2018 Posted January 26, 2018 (edited) So, long story short, I switched from Plex to emby because emby does 99% of what I want and Plex barely does 90% of what I want (and it seems like they want to add unnecessary features instead of fix issues). As I'm reading through the forum posts for Android and Chromecast stuff, this is the closest I've seen to the issue I'm having. If I'm reading this correctly, does this mean that emby won't pass dts audio through the chromecast and instead transcodes it? If emby doesn't pass dts audio to the chromecast, is it something that can be done in a future release? Is this a feature of the purchased version (I'm debating between buying emby or buying plex, but I'm heavily leaning emby)? If this is simply a setting, pointing me in the right direction should be enough, although I haven't been able to find anything on my own yet. I did see a post that suggested restarting the chromecast (I can do that when I get home), but I'm not sure it's related to the issue I'm seeing. I can give the only scenario I've tried (just installed last night). I bring up a video on my android device (google pixel), cast to my basement TV, which is connected to a receiver, and watch glorious streaming tv...and then I realize it's only playing a pro-logic type audio (seems like it's 2.1). I try a few other videos and discover it's only happening on content that is using a dts audio track. The next thing I did was dig through settings to see if I can pass it through. Could it also be a setting with the encoder (like ffmpeg) that I can change? I haven't tried this from my web browser, yet, but I intend to test it out when I get home today. Emby server is running on a windows 10 desktop, with a core-i5, to test out if I want to move it to a production linux server or not. Edited January 26, 2018 by McGregorMX
Luke 42244 Posted January 26, 2018 Posted January 26, 2018 @@McGregorMX, yes because Chromecast does not support DTS, so it has to be converted or you won't get any audio at all. Please let us know if this helps. Thanks.
McGregorMX 0 Posted January 27, 2018 Posted January 27, 2018 (edited) @@Luke Ahh, I see. I loaded it on Plex because I thought it was playing DTS, but it's just being converted from DCA to AC3. For whatever it's worth, it runs quite well on my chromecast ultra. I noticed that you mentioned earlier that it was having a few issues a while back. Edited January 27, 2018 by McGregorMX
Luke 42244 Posted January 29, 2018 Posted January 29, 2018 Ok we might be able to go back to converting dts to ac3 but that will require a server update so it will take a little time. thanks.
Luke 42244 Posted March 3, 2018 Posted March 3, 2018 What issue? Are you not getting audio? Did you read this topic? Thanks.
HaraldBluetooth 22 Posted March 9, 2018 Posted March 9, 2018 (edited) Hi, I thought, that this problem already was solved, but Emby Server (3.3.1.2) is still transcoding DTS 5.1 audio in mkv files to stereo to my Chromecast Ultra placed in my Denon AVR-1611 surround receiver. Why isn't it transcoded to AC3 5.1? Here is mediainfo data: Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1 h 29 min Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 963 MiB (22%) Title : Original Language : English Default : Yes Forced : No Log: 2018-03-08 22:18:17.581 Application version: 3.3.1.2 http://192.168.0.106:8096/emby/videos/73cf676c249a92214a188a89eb8435bb/stream.mkv?DeviceId=204875a764ec8b2b972a1c53c5e8bc099b46b9c0&MediaSourceId=73cf676c249a92214a188a89eb8435bb&VideoCodec=h264,h265,hevc,vp8,vp9&AudioCodec=aac,ac3,eac3,mp3,opus,flac,vorbis&AudioStreamIndex=1&VideoBitrate=119552000&AudioBitrate=448000&StartTimeTicks=53359964327&PlaySessionId=8fdd38d5a0b34784819a49e4c8255e67&api_key=539428dbbf724b64ad411cc63a3661af&TranscodingMaxAudioChannels=2&CopyTimestamps=true&RequireAvc=true&Tag=3ea92f178044681c23cf0f8f6654e9e0&h264-profile=high,main,baseline,constrainedbaseline&h264-level=42&h264-deinterlace=true&audiochannels=2 {"Protocol":"File","Id":"73cf676c249a92214a188a89eb8435bb","Path":"I:\\Film\\Gambit (2012)\\Gambit.2012.720p.BluRay.x264.DTS-WiKi.mkv","Type":"Default","Container":"mkv,webm","Name":"Gambit.2012.720p.BluRay.x264.DTS-WiKi","IsRemote":false,"ETag":"3ea92f178044681c23cf0f8f6654e9e0","RunTimeTicks":53509791744,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"583/27956","VideoRange":"SDR","DisplayTitle":"720P H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":7012892,"BitDepth":8,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":544,"Width":1280,"AverageFrameRate":23.9759865,"RealFrameRate":23.9759865,"Profile":"High","Type":"Video","AspectRatio":"2.35:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"dts","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"英语","DisplayTitle":"Eng DTS 5.1 Default","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":1536000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"srt","Language":"dan","DisplayTitle":"Dan","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"I:\\Film\\Gambit (2012)\\Gambit.2012.720p.BluRay.x264.DTS-WiKi.DAN.srt","IsAnamorphic":true}],"Formats":[],"Bitrate":7012892,"RequiredHttpHeaders":{}} User policy for Per: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: False EnableAudioPlaybackTranscoding: True C:\Users\Per\AppData\Roaming\Emby-Server\system\ffmpeg.exe -ss 01:28:55.996 -f matroska,webm -i file:"I:\Film\Gambit (2012)\Gambit.2012.720p.BluRay.x264.DTS-WiKi.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -copyts -avoid_negative_ts disabled -start_at_zero -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -y "C:\Users\Per\AppData\Roaming\Emby-Server\transcoding-temp\4ed7a3ed594d7b95922c68813ea281c9.mkv" ffmpeg version 3.4.2 Copyright © 2000-2018 the FFmpeg developers built with gcc 7.3.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libmfx --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 Input #0, matroska,webm, from 'file:I:\Film\Gambit (2012)\Gambit.2012.720p.BluRay.x264.DTS-WiKi.mkv': Metadata: encoder : libebml v0.7.7 + libmatroska v0.8.1 creation_time : 2013-03-06T11:52:12.000000Z Duration: 01:29:10.98, start: 0.000000, bitrate: 7012 kb/s Stream #0:0(eng): Video: h264 (High), yuv420p(progressive), 1280x544, SAR 1:1 DAR 40:17, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default) Metadata: title : 英语 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (dts (dca) -> aac (native)) Press [q] to stop, [?] for help Output #0, matroska, to 'C:\Users\Per\AppData\Roaming\Emby-Server\transcoding-temp\4ed7a3ed594d7b95922c68813ea281c9.mkv': Metadata: encoder : Lavf57.83.100 Stream #0:0: Video: h264 (High) (H264 / 0x34363248), yuv420p(progressive), 1280x544 [sAR 1:1 DAR 40:17], q=2-31, 23.98 fps, 23.98 tbr, 1k tbn, 1k tbc (default) Stream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 384 kb/s (default) Metadata: encoder : Lavc57.107.100 aac frame= 165 fps=0.0 q=-1.0 size= 693kB time=01:28:57.74 bitrate= 1.1kbits/s speed=1.06e+004x frame= 211 fps=210 q=-1.0 size= 693kB time=01:28:59.64 bitrate= 1.1kbits/s speed=5.3e+003x frame= 253 fps=167 q=-1.0 size= 1442kB time=01:29:01.39 bitrate= 2.2kbits/s speed=3.53e+003x frame= 294 fps=146 q=-1.0 size= 1442kB time=01:29:03.12 bitrate= 2.2kbits/s speed=2.65e+003x frame= 335 fps=133 q=-1.0 size= 1442kB time=01:29:04.82 bitrate= 2.2kbits/s speed=2.12e+003x frame= 372 fps=123 q=-1.0 size= 1828kB time=01:29:06.57 bitrate= 2.8kbits/s speed=1.77e+003x frame= 421 fps=120 q=-1.0 size= 1828kB time=01:29:08.41 bitrate= 2.8kbits/s speed=1.52e+003x frame= 483 fps=129 q=-1.0 Lsize= 1939kB time=01:29:10.85 bitrate= 3.0kbits/s speed=1.43e+003x video:1488kB audio:442kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.452832% [aac @ 000001fc58b00860] Qavg: 64949.723 Edited March 9, 2018 by HaraldBluetooth
mavs 1 Posted March 10, 2018 Posted March 10, 2018 Hi I think this might be related: https://emby.media/community/index.php?/topic/53783-chromecast-cant-play-51-dts-audio-need-help-transcoding-q/?p=539289 I'm keenly waiting for DTS to once again be transcoded to AC3 5.1 for Chromecast also. Cheers
Luke 42244 Posted March 11, 2018 Posted March 11, 2018 For those running the beta server, please try the next beta server, thanks.
McGregorMX 0 Posted March 15, 2018 Posted March 15, 2018 Is DTS to AAC supposed to be working for chromecast now? I loaded the latest beta version, but it still seems to be converting it to 2.0. I'm probably doing something wrong.
Luke 42244 Posted March 15, 2018 Posted March 15, 2018 Is DTS to AAC supposed to be working for chromecast now? I loaded the latest beta version, but it still seems to be converting it to 2.0. I'm probably doing something wrong. Please attach an ffmpeg log, thanks.
McGregorMX 0 Posted March 18, 2018 Posted March 18, 2018 (edited) I hope this is the log you are wanting (don't judge me on the movie...I needed to test it while my daughter was watching), as some additional info, my receiver is showing, "Format = PCM, Channel = 2/0/---, Sampling = 48kHz, Bitrate = ---, Input = HDMI 1080p, Output = HDMI 1080p" 2018-03-18 14:44:07.111Application version: 3.3.1.5http://192.168.1.18:8096/emby/videos/c1bb4f7c3db3e4d6740bc6c040a05cff/stream.mkv?DeviceId=QmFzZW1lbnQgVFY=&MediaSourceId=c1bb4f7c3db3e4d6740bc6c040a05cff&VideoCodec=h264,h265,hevc,vp8,vp9&AudioCodec=aac,ac3,eac3,mp3,opus,flac,vorbis&AudioStreamIndex=1&VideoBitrate=139616000&AudioBitrate=384000&PlaySessionId=4e1b677f82c94d889639b2e150ef853b&api_key=95cc31d9ba2448a9ba00010ec013ab11&TranscodingMaxAudioChannels=6&CopyTimestamps=true&RequireAvc=true&Tag=813f0500008a570bc0c112d172cbf605&h264-profile=high,main,baseline,constrainedbaseline&h264-level=42&h264-deinterlace=true&aac-audiochannels=2{"Protocol":"File","Id":"c1bb4f7c3db3e4d6740bc6c040a05cff","Path":"/media/yoda/files/media/flicks/My Little Pony (2017) [1080p]/My Little Pony (2017) [1080p].mkv","Type":"Default","Container":"mkv,webm","Name":"My Little Pony (2017) [1080p]","IsRemote":false,"ETag":"813f0500008a570bc0c112d172cbf605","RunTimeTicks":59549900800,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1001/48000","VideoRange":"SDR","DisplayTitle":"1080P H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":38548735,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"dts","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround 5.1","DisplayTitle":"Eng DTS 5.1 Default","IsInterlaced":false,"ChannelLayout":"5.1","BitDepth":24,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":38548735,"RequiredHttpHeaders":{}}User policy for mcgregormx: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True/opt/emby-server/bin/ffmpeg -f matroska,webm -i file:"/media/yoda/files/media/flicks/My Little Pony (2017) [1080p]/My Little Pony (2017) [1080p].mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -copyts -avoid_negative_ts disabled -start_at_zero -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -af "volume=2" -y "/var/lib/emby/transcoding-temp/80cec5a0be1c2598e593216318b3cdf5.mkv"ffmpeg version 3.4.2 Copyright © 2000-2018 the FFmpeg developersbuilt with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0)configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --cc=x86_64-pc-linux-gnu-gcc --cxx=x86_64-pc-linux-gnu-gcc --arch=x86_64 --prefix=/srv/buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-cuda --disable-cuvid --disable-nvenc --disable-doc --disable-ffplay --disable-ffserver --disable-xlib --enable-fontconfig --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --extra-libs='-ldl -lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -lgmp -lhogweed -lnettle -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static --enable-gnutls --enable-libsmbclient --enable-vaapilibavutil 55. 78.100 / 55. 78.100libavcodec 57.107.100 / 57.107.100libavformat 57. 83.100 / 57. 83.100libavdevice 57. 10.100 / 57. 10.100libavfilter 6.107.100 / 6.107.100libswscale 4. 8.100 / 4. 8.100libswresample 2. 9.100 / 2. 9.100libpostproc 54. 7.100 / 54. 7.100Input #0, matroska,webm, from 'file:/media/yoda/files/media/flicks/My Little Pony (2017) [1080p]/My Little Pony (2017) [1080p].mkv':Metadata:title : My Little Pony (2017) [1080p]encoder : libmakemkv v1.10.8 (1.3.5/1.4.7) win(x64-release)creation_time : 2018-01-10T00:31:50.000000ZDuration: 01:39:14.99, start: 0.000000, bitrate: 38548 kb/sChapter #0:0: start 0.000000, end 323.072750Metadata:title : Chapter 01Chapter #0:1: start 323.072750, end 723.139083Metadata:title : Chapter 02Chapter #0:2: start 723.139083, end 1075.532792Metadata:title : Chapter 03Chapter #0:3: start 1075.532792, end 1379.044333Metadata:title : Chapter 04Chapter #0:4: start 1379.044333, end 1824.864708Metadata:title : Chapter 05Chapter #0:5: start 1824.864708, end 2130.336542Metadata:title : Chapter 06Chapter #0:6: start 2130.336542, end 2493.866375Metadata:title : Chapter 07Chapter #0:7: start 2493.866375, end 2783.822708Metadata:title : Chapter 08Chapter #0:8: start 2783.822708, end 3010.841167Metadata:title : Chapter 09Chapter #0:9: start 3010.841167, end 3671.542875Metadata:title : Chapter 10Chapter #0:10: start 3671.542875, end 3863.276083Metadata:title : Chapter 11Chapter #0:11: start 3863.276083, end 4140.886750Metadata:title : Chapter 12Chapter #0:12: start 4140.886750, end 4548.210333Metadata:title : Chapter 13Chapter #0:13: start 4548.210333, end 4824.486333Metadata:title : Chapter 14Chapter #0:14: start 4824.486333, end 5244.072167Metadata:title : Chapter 15Chapter #0:15: start 5244.072167, end 5954.990708Metadata:title : Chapter 16Stream #0:0(eng): Video: h264 (High), yuv420p(progressive), 1920x1080 [sAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbcMetadata:BPS-eng : 34801448DURATION-eng : 01:39:14.990708333NUMBER_OF_FRAMES-eng: 142777NUMBER_OF_BYTES-eng: 25905285037SOURCE_ID-eng : 001011_STATISTICS_WRITING_APP-eng: MakeMKV v1.10.8 win(x64-release)_STATISTICS_WRITING_DATE_UTC-eng: 2018-01-10 00:31:50_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_IDStream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), s32p (24 bit) (default)Metadata:title : Surround 5.1BPS-eng : 3743766DURATION-eng : 01:39:15.008000000NUMBER_OF_FRAMES-eng: 558282NUMBER_OF_BYTES-eng: 2786770044SOURCE_ID-eng : 001100_STATISTICS_WRITING_APP-eng: MakeMKV v1.10.8 win(x64-release)_STATISTICS_WRITING_DATE_UTC-eng: 2018-01-10 00:31:50_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_IDStream mapping:Stream #0:0 -> #0:0 (copy)Stream #0:1 -> #0:1 (dts (dca) -> aac (native))Press [q] to stop, [?] for helpOutput #0, matroska, to '/var/lib/emby/transcoding-temp/80cec5a0be1c2598e593216318b3cdf5.mkv':Metadata:encoder : Lavf57.83.100Stream #0:0: Video: h264 (High) (H264 / 0x34363248), yuv420p(progressive), 1920x1080 [sAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 1k tbn, 1k tbcStream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp (24 bit), 384 kb/s (default)Metadata:encoder : Lavc57.107.100 aacframe= 53 fps=0.0 q=-1.0 size= 579kB time=00:00:02.21 bitrate=2140.2kbits/s speed= 4.4xframe= 92 fps= 91 q=-1.0 size= 4143kB time=00:00:03.79 bitrate=8938.5kbits/s speed=3.78xframe= 127 fps= 84 q=-1.0 size= 12861kB time=00:00:05.24 bitrate=20075.2kbits/s speed=3.49xframe= 162 fps= 81 q=-1.0 size= 17337kB time=00:00:06.72 bitrate=21134.8kbits/s speed=3.34xframe= 163 fps= 44 q=-1.0 size= 17337kB time=00:00:06.76 bitrate=21003.5kbits/s speed=1.84xframe= 173 fps= 41 q=-1.0 size= 21835kB time=00:00:07.16 bitrate=24957.7kbits/s speed=1.72xframe= 198 fps= 42 q=-1.0 size= 26096kB time=00:00:08.19 bitrate=26099.6kbits/s speed=1.75xframe= 232 fps= 45 q=-1.0 size= 30466kB time=00:00:09.62 bitrate=25938.5kbits/s speed=1.86xframe= 261 fps= 46 q=-1.0 size= 34972kB time=00:00:10.90 bitrate=26280.8kbits/s speed=1.92xframe= 310 fps= 50 q=-1.0 size= 43860kB time=00:00:12.88 bitrate=27882.8kbits/s speed=2.08xframe= 312 fps= 46 q=-1.0 size= 43860kB time=00:00:12.99 bitrate=27657.4kbits/s speed=1.93xframe= 346 fps= 48 q=-1.0 size= 52783kB time=00:00:14.35 bitrate=30117.6kbits/s speed=1.98xframe= 382 fps= 49 q=-1.0 size= 57227kB time=00:00:15.87 bitrate=29538.5kbits/s speed=2.05xframe= 449 fps= 54 q=-1.0 size= 70619kB time=00:00:18.73 bitrate=30886.9kbits/s speed=2.27xframe= 558 fps= 64 q=-1.0 size= 82521kB time=00:00:23.25 bitrate=29071.9kbits/s speed=2.66xframe= 606 fps= 66 q=-1.0 size= 88325kB time=00:00:25.32 bitrate=28574.2kbits/s speed=2.74xframe= 720 fps= 74 q=-1.0 size= 97632kB time=00:00:29.99 bitrate=26665.4kbits/s speed=3.08xframe= 733 fps= 68 q=-1.0 size= 97632kB time=00:00:30.50 bitrate=26218.7kbits/s speed=2.84xframe= 838 fps= 74 q=-1.0 size= 98594kB time=00:00:34.94 bitrate=23114.2kbits/s speed= 3.1xframe= 924 fps= 76 q=-1.0 size= 101722kB time=00:00:38.44 bitrate=21677.0kbits/s speed=3.16xframe= 994 fps= 78 q=-1.0 size= 102652kB time=00:00:41.40 bitrate=20308.8kbits/s speed=3.26xframe= 1058 fps= 80 q=-1.0 size= 105755kB time=00:00:44.07 bitrate=19656.5kbits/s speed=3.34xframe= 1163 fps= 85 q=-1.0 size= 121493kB time=00:00:48.51 bitrate=20516.5kbits/s speed=3.54xframe= 1249 fps= 85 q=-1.0 size= 138738kB time=00:00:52.05 bitrate=21834.4kbits/s speed=3.55xframe= 1307 fps= 86 q=-1.0 size= 147258kB time=00:00:54.46 bitrate=22149.7kbits/s speed=3.59xframe= 1391 fps= 89 q=-1.0 size= 160675kB time=00:00:58.00 bitrate=22692.0kbits/s speed=3.71xframe= 1484 fps= 92 q=-1.0 size= 176850kB time=00:01:01.88 bitrate=23410.1kbits/s speed=3.83xframe= 1578 fps= 91 q=-1.0 size= 194784kB time=00:01:05.76 bitrate=24261.8kbits/s speed=3.81xframe= 1636 fps= 92 q=-1.0 size= 208280kB time=00:01:08.15 bitrate=25033.1kbits/s speed=3.84xframe= 1715 fps= 94 q=-1.0 size= 221569kB time=00:01:11.48 bitrate=25390.5kbits/s speed=3.91xframe= 1773 fps= 94 q=-1.0 size= 227686kB time=00:01:13.85 bitrate=25254.9kbits/s speed=3.93xframe= 1775 fps= 92 q=-1.0 size= 227686kB time=00:01:14.00 bitrate=25203.4kbits/s speed=3.83xframe= 1817 fps= 92 q=-1.0 size= 235918kB time=00:01:15.66 bitrate=25540.7kbits/s speed=3.82xframe= 1854 fps= 91 q=-1.0 size= 244800kB time=00:01:17.29 bitrate=25946.5kbits/s speed= 3.8xframe= 1916 fps= 92 q=-1.0 size= 253804kB time=00:01:19.89 bitrate=26024.3kbits/s speed=3.83xframe= 1977 fps= 93 q=-1.0 size= 267292kB time=00:01:22.38 bitrate=26577.0kbits/s speed=3.86xframe= 2024 fps= 93 q=-1.0 size= 276271kB time=00:01:24.45 bitrate=26796.9kbits/s speed=3.87xframe= 2087 fps= 93 q=-1.0 size= 284737kB time=00:01:27.06 bitrate=26792.3kbits/s speed= 3.9xframe= 2159 fps= 94 q=-1.0 size= 298150kB time=00:01:30.02 bitrate=27130.4kbits/s speed=3.94xframe= 2186 fps= 93 q=-1.0 size= 307075kB time=00:01:31.11 bitrate=27609.0kbits/s speed=3.86xframe= 2266 fps= 94 q=-1.0 size= 320019kB time=00:01:34.42 bitrate=27764.9kbits/s speed=3.92xframe= 2351 fps= 95 q=-1.0 size= 333035kB time=00:01:37.98 bitrate=27843.9kbits/s speed=3.98xframe= 2378 fps= 94 q=-1.0 size= 342039kB time=00:01:39.13 bitrate=28264.3kbits/s speed=3.93xframe= 2416 fps= 94 q=-1.0 size= 346553kB time=00:01:40.77 bitrate=28170.5kbits/s speed=3.91xframe= 2473 fps= 94 q=-1.0 size= 360054kB time=00:01:43.10 bitrate=28607.9kbits/s speed=3.92xframe= 2521 fps= 94 q=-1.0 size= 369080kB time=00:01:45.10 bitrate=28765.4kbits/s speed=3.92xframe= 2593 fps= 95 q=-1.0 size= 382589kB time=00:01:48.11 bitrate=28988.7kbits/s speed=3.96xframe= 2642 fps= 95 q=-1.0 size= 391590kB time=00:01:50.14 bitrate=29124.9kbits/s speed=3.95xframe= 2690 fps= 95 q=-1.0 size= 400591kB time=00:01:52.17 bitrate=29256.0kbits/s speed=3.95xframe= 2737 fps= 95 q=-1.0 size= 409599kB time=00:01:54.11 bitrate=29405.0kbits/s speed=3.95xframe= 2810 fps= 96 q=-1.0 size= 423098kB time=00:01:57.18 bitrate=29577.5kbits/s speed=3.98xframe= 2851 fps= 95 q=-1.0 size= 427600kB time=00:01:58.89 bitrate=29463.4kbits/s speed=3.97xframe= 2891 fps= 95 q=-1.0 size= 436604kB time=00:02:00.51 bitrate=29678.8kbits/s speed=3.96xframe= 2936 fps= 95 q=-1.0 size= 445580kB time=00:02:02.49 bitrate=29798.7kbits/s speed=3.96xframe= 3013 fps= 96 q=-1.0 size= 458130kB time=00:02:05.61 bitrate=29878.2kbits/s speed=3.99xframe= 3057 fps= 96 q=-1.0 size= 467109kB time=00:02:07.42 bitrate=30030.3kbits/s speed=3.99xframe= 3114 fps= 96 q=-1.0 size= 476122kB time=00:02:09.85 bitrate=30036.3kbits/s speed= 4xframe= 3190 fps= 97 q=-1.0 size= 493364kB time=00:02:12.99 bitrate=30390.3kbits/s speed=4.03xframe= 3258 fps= 97 q=-1.0 size= 506087kB time=00:02:15.85 bitrate=30518.0kbits/s speed=4.06xframe= 3276 fps= 96 q=-1.0 size= 510613kB time=00:02:16.59 bitrate=30622.5kbits/s speed=4.02xframe= 3349 fps= 97 q=-1.0 size= 523974kB time=00:02:19.64 bitrate=30737.5kbits/s speed=4.04xframe= 3397 fps= 97 q=-1.0 size= 532962kB time=00:02:21.67 bitrate=30817.4kbits/s speed=4.04xframe= 3493 fps= 98 q=-1.0 size= 550927kB time=00:02:25.62 bitrate=30992.7kbits/s speed=4.09xframe= 3565 fps= 99 q=-1.0 size= 564423kB time=00:02:28.63 bitrate=31109.2kbits/s speed=4.12xframe= 3603 fps= 98 q=-1.0 size= 568359kB time=00:02:30.25 bitrate=30988.3kbits/s speed=4.11xframe= 3646 fps= 98 q=-1.0 size= 575822kB time=00:02:32.04 bitrate=31025.2kbits/s speed= 4.1xframe= 3673 fps= 95 q=-1.0 size= 579593kB time=00:02:33.12 bitrate=31006.7kbits/s speed=3.98xframe= 3706 fps= 95 q=-1.0 size= 583358kB time=00:02:34.49 bitrate=30932.2kbits/s speed=3.96xframe= 3746 fps= 95 q=-1.0 size= 593391kB time=00:02:36.22 bitrate=31116.0kbits/s speed=3.96xframe= 3783 fps= 95 q=-1.0 size= 597871kB time=00:02:37.71 bitrate=31053.9kbits/s speed=3.94xframe= 3822 fps= 94 q=-1.0 size= 605721kB time=00:02:39.33 bitrate=31142.0kbits/s speed=3.93xframe= 3831 fps= 92 q=-1.0 size= 609266kB time=00:02:39.72 bitrate=31248.9kbits/s speed=3.85xframe= 3867 fps= 92 q=-1.0 size= 613728kB time=00:02:41.25 bitrate=31177.8kbits/s speed=3.84xframe= 3884 fps= 91 q=-1.0 size= 618197kB time=00:02:41.98 bitrate=31264.0kbits/s speed=3.81xframe= 3923 fps= 91 q=-1.0 size= 622660kB time=00:02:43.56 bitrate=31185.9kbits/s speed=3.81xframe= 3960 fps= 91 q=-1.0 size= 632346kB time=00:02:45.14 bitrate=31368.2kbits/s speed= 3.8xframe= 3999 fps= 91 q=-1.0 size= 636825kB time=00:02:46.78 bitrate=31279.6kbits/s speed=3.79xframe= 4028 fps= 89 q=-1.0 size= 645821kB time=00:02:47.95 bitrate=31499.5kbits/s speed=3.71xframe= 4058 fps= 89 q=-1.0 size= 650295kB time=00:02:49.21 bitrate=31481.8kbits/s speed= 3.7xframe= 4100 fps= 89 q=-1.0 size= 655136kB time=00:02:50.94 bitrate=31395.7kbits/s speed=3.69xframe= 4129 fps= 88 q=-1.0 size= 663574kB time=00:02:52.15 bitrate=31575.4kbits/s speed=3.68xframe= 4164 fps= 88 q=-1.0 size= 668041kB time=00:02:53.67 bitrate=31510.7kbits/s speed=3.67xframe= 4203 fps= 88 q=-1.0 size= 674186kB time=00:02:55.29 bitrate=31506.5kbits/s speed=3.67xframe= 4213 fps= 87 q=-1.0 size= 678577kB time=00:02:55.61 bitrate=31653.9kbits/s speed=3.62xframe= 4237 fps= 86 q=-1.0 size= 682999kB time=00:02:56.70 bitrate=31664.0kbits/s speed= 3.6xframe= 4271 fps= 86 q=-1.0 size= 689556kB time=00:02:58.09 bitrate=31719.0kbits/s speed=3.59xframe= 4291 fps= 86 q=-1.0 size= 693971kB time=00:02:58.96 bitrate=31766.1kbits/s speed=3.57xframe= 4333 fps= 86 q=-1.0 size= 699366kB time=00:03:00.62 bitrate=31718.1kbits/s speed=3.57xframe= 4339 fps= 85 q=-1.0 size= 699366kB time=00:03:00.99 bitrate=31654.7kbits/s speed=3.54xframe= 4366 fps= 85 q=-1.0 size= 707720kB time=00:03:02.07 bitrate=31841.3kbits/s speed=3.53x Edited March 18, 2018 by McGregorMX
Luke 42244 Posted March 22, 2018 Posted March 22, 2018 3.3.1.6+. The latest beta is 3.3.1.7. Thanks. 1
Harbinger1080 3 Posted May 17, 2018 Posted May 17, 2018 Are there any plans to address this soon? 3.3.1.6+. The latest beta is 3.3.1.7. Thanks.
Luke 42244 Posted May 17, 2018 Posted May 17, 2018 I haven't had a chance to respond to your other topic yet but i will just delete that now since we can use this one. Thanks. 1
