b0mb 36 Posted December 13, 2017 Posted December 13, 2017 Hi! How can I stop playback in Emby on FireTV? If I press return I leave the movie and can resume later but this process doesn't seem to send a real stop command that is recognized by trakt or pushover addon. Thx. ;-) b0mb Gesendet von meinem Redmi Note 3 mit Tapatalk
Luke 42245 Posted December 13, 2017 Posted December 13, 2017 Does it say that you stopped on the emby server dashboard?
b0mb 36 Posted December 13, 2017 Author Posted December 13, 2017 Does it say that you stopped on the emby server dashboard?Yes Gesendet von meinem Redmi Note 3 mit Tapatalk
ebr 16337 Posted December 13, 2017 Posted December 13, 2017 So playback is stopping fine in the app, correct?
b0mb 36 Posted December 13, 2017 Author Posted December 13, 2017 (edited) So playback is stopping fine in the app, correct?Yep But the pushover and trakt Plugin doesn't seem to recognize this stop like it does when I play something using Kodi ;-) Gesendet von meinem Redmi Note 3 mit Tapatalk Edited December 13, 2017 by b0mb
Luke 42245 Posted December 14, 2017 Posted December 14, 2017 Make sure to install the latest version of the trakt plugin. Everyone else seems to be reporting success with it. After installation you'll need to re-do your trakt setup in the configuration page. If there's still an issue after that, please see how to report a problem. thanks !
b0mb 36 Posted December 14, 2017 Author Posted December 14, 2017 (edited) Latest trakt Plugin is installed. Also latest Emby Docker container. Problem only appears when playing from from FireTV. Web, Kodi and Android are running fine. Problem belongs to trakt and pushover Plugin. Gesendet von meinem Redmi Note 3 mit Tapatalk Edited December 14, 2017 by b0mb
Luke 42245 Posted December 14, 2017 Posted December 14, 2017 @@b0mb, please discuss an example and attach the information requested in how to report a problem. thanks !
b0mb 36 Posted December 17, 2017 Author Posted December 17, 2017 I´ve attached a debug.log now... you can find a try with fire tv from today at 10:39 emby_17122017.txt
ebr 16337 Posted December 17, 2017 Posted December 17, 2017 Looks like some sort of error at Trakt: 2017-12-17 10:40:53.655 Error HttpClient: Error ProtocolError getting response from https://api.trakt.tv/scrobble/stop *** Error Report *** Version: 3.2.50.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.14.4.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Sun Oct 1 17:55:43 UTC 2017) Processor count: 4 Program data path: /config Application directory: /usr/lib/emby-server/bin System.Net.WebException: The remote server returned an error: (409) Conflict. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0
b0mb 36 Posted December 17, 2017 Author Posted December 17, 2017 Looks like some sort of error at Trakt: 2017-12-17 10:40:53.655 Error HttpClient: Error ProtocolError getting response from https://api.trakt.tv/scrobble/stop *** Error Report *** Version: 3.2.50.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.14.4.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Sun Oct 1 17:55:43 UTC 2017) Processor count: 4 Program data path: /config Application directory: /usr/lib/emby-server/bin System.Net.WebException: The remote server returned an error: (409) Conflict. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 But the problem only appears when playing from firetv and the pushover plugin has the same problem. Gesendet von meinem Redmi Note 3 mit Tapatalk
J2ghz 11 Posted January 10, 2018 Posted January 10, 2018 (edited) @@b0mb, can you turn on debug logging in the plugin (keep emby's debug logging turned on as well) and try to capture the error again? Edited January 10, 2018 by J2ghz
