ausvette 2 Posted December 13, 2017 Posted December 13, 2017 I'm using the internal madvr player for 2d video which works fine. I'm wanting to use an external player for 3d video. I've setup an external player and checked iso, bluray, dvd and 3d. But when I try to play the movie which is a iso, it doesn't launch the external player and eventually times out. Seems like its trying to use the madvr player which can't open the iso.
ausvette 2 Posted December 13, 2017 Author Posted December 13, 2017 Ok, I found if I set the 3d flag in the metadata for the video it launches the external player. Still seems a little strange it didn't work checking iso as it is a iso file. But doesn't matter its doing what I want now.
Luke 42243 Posted December 13, 2017 Posted December 13, 2017 Yes it should work for iso. Just checking the iso box alone would be enough. Perhaps you had other filters enabled it that may have narrowed it down too much.
Luke 42243 Posted February 13, 2018 Posted February 13, 2018 Just a heads up the next version of the app will be removing madvr again, but I think you'll find the external player experience will be much better. This will allow you to use MPC-HC with MadVR if you desire. You're welcome to try out a test version here: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/page-1 Thanks !
