Scallica 1 Posted March 8, 2014 Posted March 8, 2014 I am using MB server 3.0.5171.19958. I updated the cover art image (folder.png) for two items in my collection. In both the web interface and MBC, the new image appears in detailed view but not the list view. For example, in the web interface, I can see the old cover art in the list, but when I click on the item to go to the detailed view, the new image is shown. I tried re-scanning the library but the image did not refresh. Has anyone else encountered this issue? Is there a way to manually purge the image cache? Thanks.
GhostRider 49 Posted March 8, 2014 Posted March 8, 2014 Try this to see if it helps. On the Dashboard (server web interface), click the pencil icon to enter edit mode, select one of the items you changed the cover art for, click the refresh icon at the top. Repeat for the second item. Does this fix the list view image?
Scallica 1 Posted March 8, 2014 Author Posted March 8, 2014 Thanks for the suggestion. I tried it and the old image remains in list view.
ebr 16357 Posted March 8, 2014 Posted March 8, 2014 Just so I'm clear here, you are talking about actual images, not images treated by the CoverArt plug-in, right?
Scallica 1 Posted March 12, 2014 Author Posted March 12, 2014 Is there a way to purge the image cache?
