MisterAngelus 7 Posted December 12, 2017 Posted December 12, 2017 I have an issue with my metadata but only the people metadata it is going in a different location then the rest of the metadata.. I can only guess that I messed up that setting somehow.. so can someone help me find that setting and what is its default location supposed to be?
d00zah 152 Posted December 12, 2017 Posted December 12, 2017 Metadata path set here: http://localhost:8096/web/librarysettings.html (i.e. x:\Emby-Data) People stored here: \metadata\People (i.e. x:\Emby-Data\metadata\People)
MisterAngelus 7 Posted December 12, 2017 Author Posted December 12, 2017 (edited) Any idea why my people metadata is going to a different location then the rest of my metadata? Edited December 12, 2017 by MisterAngelus
d00zah 152 Posted December 12, 2017 Posted December 12, 2017 (edited) I'm assuming you've opted to save metadata with media? My guess would be to avoid the redundancy of storing a copy of a person in every movie/show they've appeared in? If I've assumed incorrectly, could you please describe your configuration in more detail? Edited December 12, 2017 by d00zah
Luke 42204 Posted December 12, 2017 Posted December 12, 2017 My guess would be to avoid the redundancy of storing a copy of a person in every movie/show they've appeared in? Correct.
MisterAngelus 7 Posted December 12, 2017 Author Posted December 12, 2017 All good points but okay.. when I first setup Emby I had the metadata going into a special directory.. I then decided that was unnecessary so I cleared that setting deleted the metadata in that directory.. then I told emby to re download all metadata which it did.. all metadata went to the system folder...except the people metadata it went to the old directory that I used to have set.. however its been fixed I again told it to put the metadata into the Emby system folder and this time it stuck Thanks for the help:)
Happy2Play 9802 Posted December 12, 2017 Posted December 12, 2017 All good points but okay.. when I first setup Emby I had the metadata going into a special directory.. I then decided that was unnecessary so I cleared that setting deleted the metadata in that directory.. then I told emby to re download all metadata which it did.. all metadata went to the system folder...except the people metadata it went to the old directory that I used to have set.. however its been fixed I again told it to put the metadata into the Emby system folder and this time it stuck Thanks for the help:) If you are actually using the Emby SYSTEM folder that is a bad idea as it gets replaced with every update.
MisterAngelus 7 Posted December 13, 2017 Author Posted December 13, 2017 you are correct I meant the Emby directory Program data directory
pju 10 Posted December 13, 2017 Posted December 13, 2017 I'm sorry - but I''m confused. I am of the impression that people metadata, ie. person.xml is not used anymore. At least that changes in these files are not read by Emby. Not much benefit in saving in that case .
d00zah 152 Posted December 13, 2017 Posted December 13, 2017 I'm sorry - but I''m confused. I am of the impression that people metadata, ie. person.xml is not used anymore. At least that changes in these files are not read by Emby. Not much benefit in saving in that case . How 'bout the person image?
d00zah 152 Posted December 13, 2017 Posted December 13, 2017 person images are certainly used. Exactly my point. Poster seemed to imply 'people metadata' was only the 'person.xml'.
