lightsout 156 Posted March 19, 2019 Posted March 19, 2019 (edited) It can if the video is full frame. That's the bug. If the frame hight is less than 2155, it doesn't enable HDR. So if you feel like trying mpv, I can't pretty much put a starter pack, together Duh thats right, so for the most part a remux should work, because they have the black bars encoded in. I am happy to check out a starter pack That would be great. Heres my relevant specs i5 4570s 8 gb ddr31600 GTX 1060 6GB Connected to: Denon x1400h Samsung 55MU6290 Edited March 19, 2019 by lightsout
Guest asrequested Posted March 19, 2019 Posted March 19, 2019 Groovy. What I'll do is update my thread in testing area with files and a step by step. Quick question, is your windows desktop always in HDR10? If not, you should enable that.
lightsout 156 Posted March 19, 2019 Posted March 19, 2019 Groovy. What I'll do is update my thread in testing area with files and a step by step. Quick question, is your windows desktop always in HDR10? If not, you should enable that. That sounds cool thanks. See thats the thing, Windows HDR implementation stinks, thats why everyone is using madvr to handle passthrough when needed, because HDR always on in windows still has issues.
Guest asrequested Posted March 19, 2019 Posted March 19, 2019 Having Windows in HDR10 won't affect what madVR does, but you'll need that enabled for mpv, of you want the same results.
lightsout 156 Posted March 19, 2019 Posted March 19, 2019 Having Windows in HDR10 won't affect what madVR does, but you'll need that enabled for mpv, of you want the same results. I'll check it out, everytime I have ever messed with it the colors are always messed up, even on high it looks dim and weird. I always read everywhere not to use windows HDR setting.
Guest asrequested Posted March 19, 2019 Posted March 19, 2019 (edited) They fixed that issue, a while ago. But Windows HDR10 is what madVR uses, it's the only possible way. Edited March 19, 2019 by Doofus
lightsout 156 Posted March 19, 2019 Posted March 19, 2019 They fixed that issue, a while ago. But Windows HDR10 is what madVR uses, it's the only possible way. But I believe it is still the only (don't quote me) thing that can turn it on and off when needed.
Guest asrequested Posted March 20, 2019 Posted March 20, 2019 But I believe it is still the only (don't quote me) thing that can turn it on and off when needed. PowerDVD can, too. And I believe madVR can only do it with the new Nvdiia API. And in my case, the switching between SDR and HDR with madVR, is just painful. I'd rather just play my movies, and now I can, with perfect playback And I don't have to adjust my desktop coloring, or any of that silly stuff.
lightsout 156 Posted March 20, 2019 Posted March 20, 2019 PowerDVD can, too. And I believe madVR can only do it with the new Nvdiia API. And in my case, the switching between SDR and HDR with madVR, is just painful. I'd rather just play my movies, and now I can, with perfect playback And I don't have to adjust my desktop coloring, or any of that silly stuff. But is the IQ in the same league.
Guest asrequested Posted March 20, 2019 Posted March 20, 2019 (edited) But is the IQ in the same league. With mpv? Try it and see I'll have the starter pack up in a little while. Edited March 20, 2019 by Doofus
Guest asrequested Posted March 20, 2019 Posted March 20, 2019 Here you go https://emby.media/community/index.php?/topic/69872-hdr-tone-mapping-with-mpv/page-5&do=findComment&comment=718964
