Henrie 1 Posted December 11, 2017 Posted December 11, 2017 Hi there, I recently updated to emby premire in my new WIN10 configuration, until now I was using MPC-HC as an external player in the MB3 version. Now I can't configure MPC-HC as the external player. It seems to be so easy but I can't make i works: C:\Program Files\MPC-HC\mpc-hc64.exe in the player path area {path} in the command line arguments area There are no more options, but it doesn't work, always the same error when trying to reproduce any movie... Error launching process: Type error: Cannot read property 'toString' of undefined. Emby works fine with the internal player, there are no problems with the archives which can be opened without problem with the MPC-HC when tried directly. What can I do? Many thanks in advance.
Luke 42242 Posted December 11, 2017 Posted December 11, 2017 hi, did you research the required command line arguments for mpc-hc?
jachin99 88 Posted December 11, 2017 Posted December 11, 2017 Look over in the emby for wmc section. We had the same issue and someone came up with a script to make it work. Out of curiosity why use mpc hc when Emby theater also has madvr?
Henrie 1 Posted December 11, 2017 Author Posted December 11, 2017 hi, did you research the required command line arguments for mpc-hc? Required line arguments? What you mean with that? Until the reinstall I didn't need any arguments, MPC just works fine. Where I can find those arguments? I`m a basic user, can you help me?
Guest asrequested Posted December 12, 2017 Posted December 12, 2017 Required line arguments? What you mean with that? Until the reinstall I didn't need any arguments, MPC just works fine. Where I can find those arguments? I`m a basic user, can you help me? https://gist.github.com/vBm/88abddafd53706439c29 1
Henrie 1 Posted December 12, 2017 Author Posted December 12, 2017 https://gist.github.com/vBm/88abddafd53706439c29 Many thanks!
Luke 42242 Posted December 12, 2017 Posted December 12, 2017 Why not just use the internal player then?
ShoutingMan 101 Posted December 15, 2017 Posted December 15, 2017 I use MPC-HC for 3D movie playback and don't use any additional command line parameters, just the Emby basics: C:\Program Files\MPC-HC\mpc-hc64.exe {path}
lightsout 156 Posted March 18, 2019 Posted March 18, 2019 https://gist.github.com/vBm/88abddafd53706439c29 I'm getting an error on this link. But having the same problem launching mpchc. Anyone know how to solve it?
Luke 42242 Posted March 18, 2019 Posted March 18, 2019 I'm getting an error on this link. But having the same problem launching mpchc. Anyone know how to solve it? Can you please describe your issue in more detail? Thanks.
lightsout 156 Posted March 18, 2019 Posted March 18, 2019 Can you please describe your issue in more detail? Thanks. Sorry I add C:\Program Files\MPC-HC\mpc-hc64.exe in the external player path area. And I get this error "Error launching process: Type error: Cannot read property 'toString' of undefined."
lightsout 156 Posted March 19, 2019 Posted March 19, 2019 Do you have {path} there, too? Negative. Does it need to be? I figured If the box said add the path here it would know what I was entering.
Luke 42242 Posted March 19, 2019 Posted March 19, 2019 you need to research the required command line arguments for your external player and make sure to configure them.
lightsout 156 Posted March 19, 2019 Posted March 19, 2019 you need to research the required command line arguments for your external player and make sure to configure them. Yeah I'm not sure about that. It always worked in the Media Browser days just linking to the .exe. Seems like if anyone is using external players MPC-HC would be the most common. I would have thought this info would be easy to find around here.
lightsout 156 Posted March 19, 2019 Posted March 19, 2019 Do you have {path} there, too? I tried putting {path} before it, with and without a space. Didn't help, same error.
Guest asrequested Posted March 19, 2019 Posted March 19, 2019 I tried putting {path} before it, with and without a space. Didn't help, same error. You don't add it the actual path. It goes on the command line arguments section. Read through that page, again.
lightsout 156 Posted March 19, 2019 Posted March 19, 2019 (edited) You don't add it the actual path. It goes on the command line arguments section. Read through that page, again. Yes I had tried that, just did it again to be sure. No dice. Are you able to get it working like that? When the OP posted the same issue, you posted a git link that is no longer working, any idea what that was for? Edited March 19, 2019 by lightsout
Guest asrequested Posted March 19, 2019 Posted March 19, 2019 Post a screenshot of the config page for the external player.
Guest asrequested Posted March 19, 2019 Posted March 19, 2019 And maybe you will let me help you get mpv dialed in, so you don't need MPC-HC?
lightsout 156 Posted March 19, 2019 Posted March 19, 2019 And maybe you will let me help you get mpv dialed in, so you don't need MPC-HC? Right now it just says {path}, I copied some other peoples settings like /start and stuff like that but same error. The reason I use the HTPC is to watch something knowing I am getting the best quality, not using madvr feels like I am leaving something on the table. Although using MPV would be easier. Does it handle HDR passthough like MadVR?
Guest asrequested Posted March 19, 2019 Posted March 19, 2019 You don't have the full path of the player. You have to add the executable.
Guest asrequested Posted March 19, 2019 Posted March 19, 2019 And here are my results with mpv compared to HDR pass through https://emby.media/community/index.php?/topic/69872-hdr-tone-mapping-with-mpv/page-5&do=findComment&comment=718358
lightsout 156 Posted March 19, 2019 Posted March 19, 2019 You don't have the full path of the player. You have to add the executable. Oh dear I'm sorry. What an idiot, it was buried in two folders with similar naming and I thought that was the exe. Thank you very much. Thanks for the HDR shot, I thought the Shield couldn't pass HDR?
Guest asrequested Posted March 19, 2019 Posted March 19, 2019 Oh dear I'm sorry. What an idiot, it was buried in two folders with similar naming and I thought that was the exe. Thank you very much. Thanks for the HDR shot, I thought the Shield couldn't pass HDR? It can if the video is full frame. That's the bug. If the frame hight is less than 2155, it doesn't enable HDR. So if you feel like trying mpv, I can't pretty much put a starter pack, together
