atropa 10 Posted December 10, 2017 Posted December 10, 2017 (edited) Hello, my Fire Tv stick generation 2 has the specification to play 1080p hevc files. In that other program it does it very well and video direct plays only ac3 sound transcodes. But in emby all files are transcoded with a message that the stick can not direct play. But i know it can. All videos have a low bitrate from 2 to 5 mbit and ac3 sound. Thx Edited December 10, 2017 by atropa
ebr 16337 Posted December 11, 2017 Posted December 11, 2017 Hi. Can you please play one of these and follow the instructions to send a log from the app? Thanks.
atropa 10 Posted December 13, 2017 Author Posted December 13, 2017 (edited) Hey log file sent Another log sent at 11:38 Am Edited December 13, 2017 by atropa
ebr 16337 Posted December 13, 2017 Posted December 13, 2017 Hi. Can you please follow all the instructions so I can find the log and know what to look for? Thanks! Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log The name of the Emby user on the local server that was logged in at the time
ebr 16337 Posted December 13, 2017 Posted December 13, 2017 Also a transcode log will confirm but if these are HEVC 10-bit, that is not supported on the Fire.
atropa 10 Posted December 13, 2017 Author Posted December 13, 2017 Hey. Ok. I want to direct play a 8 bit hevc video on the Amazon Fire Tv Stick 2 generation. Only 1080p with a low bitrate. But the video is transcoded. Name of the video is : 300: Rise of an empire Emby user is : Atropa Time log was sent : 18:26
ebr 16337 Posted December 13, 2017 Posted December 13, 2017 Can I please see the transcode log? It looks like the profile of that video is Main10...
atropa 10 Posted December 13, 2017 Author Posted December 13, 2017 Hey. No it is 4.1 2017-12-13 18:46:33.638 Application version: 3.2.50.0 http://192.168.178.32:8096/emby/videos/841f5c04d89a33782fa0323b78c0c7bd/hls1/main/0.ts?DeviceId=7b7b67df6a6a8138&MediaSourceId=841f5c04d89a33782fa0323b78c0c7bd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=29872000&AudioBitrate=128000&MaxAudioChannels=2&PlaySessionId=57038b0c03164e01a01c4acd9610b409&api_key=55ba99b7343547799d481c5fca6a946a&CopyTimestamps=true&SubtitleMethod=Encode&EnableSubtitlesInManifest=false&Tag=a0f666c278ccc590b7d3c2cae63f21e9&RequireAvc=false&RequireNonAnamorphic=false&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&TranscodeReasons=VideoCodecNotSupported,AudioCodecNotSupported&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&h264-deinterlace=true&mpeg2video-deinterlace=true&hevc-profile=Main10 {"Protocol":"File","Id":"841f5c04d89a33782fa0323b78c0c7bd","Path":"D:\\Filme\\300 Rise of an Empire (2014)\\300 Rise of an Empire (2014)\\Rise.mkv","Type":"Default","Container":"mkv,webm","Name":"Rise.mkv","IsRemote":false,"ETag":"a0f666c278ccc590b7d3c2cae63f21e9","RunTimeTicks":61567360000,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"RequiresLooping":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"hevc","TimeBase":"1/1000","CodecTimeBase":"1001/24000","DisplayTitle":"1080P HEVC","IsInterlaced":false,"BitRate":2912628,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":800,"Width":1920,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"Main","Type":"Video","AspectRatio":"2.40:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":120,"IsAnamorphic":false},{"Codec":"ac3","Language":"ger","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Ger Dolby Digital 5.1 Default","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":384000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":true,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Eng Dolby Digital 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":384000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"DVDSUB","Language":"ger","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Ger","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":2912628,"RequiredHttpHeaders":{}} User policy for atropa: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True C:\Users\moguai\AppData\Roaming\Emby-Server\system\ffmpeg.exe -f matroska,webm -i file:"D:\Filme\300 Rise of an Empire (2014)\300 Rise of an Empire (2014)\Rise.mkv" -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -vf "scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 5825256 -bufsize 11650512 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 128000 -af "volume=2" -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8" -y "C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866%d.ts" ffmpeg version 3.4 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 7.2.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth --enable-libmfx libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 Input #0, matroska,webm, from 'file:D:\Filme\300 Rise of an Empire (2014)\300 Rise of an Empire (2014)\Rise.mkv': Metadata: CREATION_TIME : 2017-02-01T09:12:00Z ENCODER : Lavf55.12.0 Duration: 01:42:36.74, start: 0.000000, bitrate: 2912 kb/s Chapter #0:0: start 0.000000, end 626.459000 Metadata: title : 00:00:00.000 Chapter #0:1: start 626.542000, end 1254.628000 Metadata: title : 00:10:26.376 Chapter #0:2: start 1254.711000, end 1875.290000 Metadata: title : 00:20:54.628 Chapter #0:3: start 1875.373000, end 2458.498000 Metadata: title : 00:31:15.290 Chapter #0:4: start 2458.581000, end 3050.756000 Metadata: title : 00:40:58.498 Chapter #0:5: start 3050.839000, end 3605.435000 Metadata: title : 00:50:50.714 Chapter #0:6: start 3605.518000, end 4191.854000 Metadata: title : 01:00:05.435 Chapter #0:7: start 4191.937000, end 4791.245000 Metadata: title : 01:09:51.813 Chapter #0:8: start 4791.328000, end 5467.420000 Metadata: title : 01:19:51.245 Chapter #0:9: start 5467.503000, end 5637.257000 Metadata: title : 01:31:07.295 Chapter #0:10: start 5637.340000, end 6155.733000 Metadata: title : 01:33:57.131 Stream #0:0: Video: hevc (Main), yuv420p(tv, bt709), 1920x800 [SAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default) Stream #0:1(ger): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default) (forced) Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s Stream #0:3(ger): Subtitle: dvd_subtitle, 1920x1080 Stream mapping: Stream #0:0 -> #0:0 (hevc (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native)) Press [q] to stop, [?] for help [libx264 @ 000001ec679cdd80] using SAR=1/1 [libx264 @ 000001ec679cdd80] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 [libx264 @ 000001ec679cdd80] profile Main, level 4.1 [libx264 @ 000001ec679cdd80] 264 - core 152 r2851 ba24899 - H.264/MPEG-4 AVC codec - Copyleft 2003-2017 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=5825 vbv_bufsize=11650 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce96828660.ts' for writing Output #0, segment, to 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866%d.ts': Metadata: encoder : Lavf57.83.100 Stream #0:0: Video: h264 (libx264), yuv420p, 1920x800 [SAR 1:1 DAR 12:5], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default) Metadata: encoder : Lavc57.107.100 libx264 Side data: cpb: bitrate max/min/avg: 5825000/0/0 buffer size: 11650000 vbv_delay: -1 Stream #0:1: Audio: aac (LC), 48000 Hz, stereo, fltp, 128 kb/s (default) (forced) Metadata: encoder : Lavc57.107.100 aac [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce96828661.ts' for writing frame= 130 fps=0.0 q=28.0 size=N/A time=00:00:05.78 bitrate=N/A speed=11.6x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce96828662.ts' for writing frame= 207 fps=207 q=28.0 size=N/A time=00:00:09.19 bitrate=N/A speed=9.19x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce96828663.ts' for writing frame= 283 fps=187 q=28.0 size=N/A time=00:00:12.11 bitrate=N/A speed=8.01x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce96828664.ts' for writing frame= 352 fps=174 q=28.0 size=N/A time=00:00:15.12 bitrate=N/A speed=7.49x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce96828665.ts' for writing frame= 432 fps=171 q=28.0 size=N/A time=00:00:18.64 bitrate=N/A speed= 7.4x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce96828666.ts' for writing frame= 505 fps=167 q=28.0 size=N/A time=00:00:21.35 bitrate=N/A speed=7.05x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce96828667.ts' for writing frame= 582 fps=164 q=28.0 size=N/A time=00:00:24.55 bitrate=N/A speed=6.91x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce96828668.ts' for writing frame= 664 fps=163 q=25.0 size=N/A time=00:00:28.13 bitrate=N/A speed=6.93x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce96828669.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286610.ts' for writing frame= 749 fps=164 q=28.0 size=N/A time=00:00:31.78 bitrate=N/A speed=6.97x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286611.ts' for writing frame= 841 fps=166 q=28.0 size=N/A time=00:00:35.69 bitrate=N/A speed=7.05x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286612.ts' for writing frame= 936 fps=168 q=28.0 size=N/A time=00:00:39.44 bitrate=N/A speed=7.09x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286613.ts' for writing frame= 1025 fps=169 q=28.0 size=N/A time=00:00:43.15 bitrate=N/A speed=7.12x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286614.ts' for writing frame= 1100 fps=167 q=28.0 size=N/A time=00:00:46.25 bitrate=N/A speed=7.04x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286615.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286616.ts' for writing frame= 1188 fps=168 q=28.0 size=N/A time=00:00:50.00 bitrate=N/A speed=7.07x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286617.ts' for writing frame= 1277 fps=169 q=28.0 size=N/A time=00:00:53.58 bitrate=N/A speed=7.07x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286618.ts' for writing frame= 1367 fps=169 q=28.0 size=N/A time=00:00:57.32 bitrate=N/A speed= 7.1x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286619.ts' for writing frame= 1450 fps=169 q=28.0 size=N/A time=00:01:01.01 bitrate=N/A speed=7.11x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286620.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286621.ts' for writing frame= 1534 fps=169 q=28.0 size=N/A time=00:01:04.36 bitrate=N/A speed=7.08x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286622.ts' for writing frame= 1632 fps=170 q=28.0 size=N/A time=00:01:08.39 bitrate=N/A speed=7.13x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286623.ts' for writing frame= 1732 fps=172 q=28.0 size=N/A time=00:01:12.55 bitrate=N/A speed=7.19x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286624.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286625.ts' for writing frame= 1849 fps=174 q=28.0 size=N/A time=00:01:17.54 bitrate=N/A speed=7.32x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286626.ts' for writing frame= 1939 fps=175 q=28.0 size=N/A time=00:01:21.30 bitrate=N/A speed=7.32x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286627.ts' for writing frame= 2023 fps=174 q=28.0 size=N/A time=00:01:24.65 bitrate=N/A speed=7.29x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286628.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286629.ts' for writing frame= 2109 fps=174 q=28.0 size=N/A time=00:01:28.42 bitrate=N/A speed=7.28x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286630.ts' for writing frame= 2185 fps=173 q=28.0 size=N/A time=00:01:31.56 bitrate=N/A speed=7.24x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286631.ts' for writing frame= 2268 fps=172 q=28.0 size=N/A time=00:01:34.93 bitrate=N/A speed=7.22x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286632.ts' for writing frame= 2329 fps=171 q=28.0 size=N/A time=00:01:37.70 bitrate=N/A speed=7.15x frame= 2395 fps=169 q=28.0 size=N/A time=00:01:40.24 bitrate=N/A speed=7.08x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286633.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286634.ts' for writing frame= 2475 fps=169 q=28.0 size=N/A time=00:01:43.57 bitrate=N/A speed=7.06x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286635.ts' for writing frame= 2555 fps=168 q=28.0 size=N/A time=00:01:46.92 bitrate=N/A speed=7.04x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286636.ts' for writing frame= 2648 fps=169 q=28.0 size=N/A time=00:01:51.01 bitrate=N/A speed=7.08x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286637.ts' for writing frame= 2723 fps=168 q=28.0 size=N/A time=00:01:54.09 bitrate=N/A speed=7.05x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286638.ts' for writing frame= 2796 fps=168 q=28.0 size=N/A time=00:01:57.01 bitrate=N/A speed=7.01x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286639.ts' for writing frame= 2883 fps=168 q=28.0 size=N/A time=00:02:00.55 bitrate=N/A speed=7.01x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286640.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286641.ts' for writing frame= 3040 fps=172 q=25.0 size=N/A time=00:02:07.12 bitrate=N/A speed=7.19x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286642.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286643.ts' for writing frame= 3135 fps=172 q=28.0 size=N/A time=00:02:11.28 bitrate=N/A speed=7.22x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286644.ts' for writing frame= 3229 fps=173 q=28.0 size=N/A time=00:02:15.08 bitrate=N/A speed=7.23x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286645.ts' for writing frame= 3321 fps=173 q=28.0 size=N/A time=00:02:18.92 bitrate=N/A speed=7.23x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286646.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286647.ts' for writing frame= 3405 fps=173 q=28.0 size=N/A time=00:02:22.42 bitrate=N/A speed=7.22x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286648.ts' for writing frame= 3495 fps=173 q=28.0 size=N/A time=00:02:26.13 bitrate=N/A speed=7.23x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286649.ts' for writing frame= 3578 fps=172 q=28.0 size=N/A time=00:02:29.71 bitrate=N/A speed=7.22x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286650.ts' for writing frame= 3662 fps=172 q=28.0 size=N/A time=00:02:33.17 bitrate=N/A speed=7.21x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286651.ts' for writing frame= 3748 fps=172 q=28.0 size=N/A time=00:02:36.82 bitrate=N/A speed=7.21x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286652.ts' for writing frame= 3834 fps=172 q=28.0 size=N/A time=00:02:40.29 bitrate=N/A speed= 7.2x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286653.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286654.ts' for writing frame= 3914 fps=172 q=28.0 size=N/A time=00:02:43.75 bitrate=N/A speed=7.19x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286655.ts' for writing frame= 3998 fps=172 q=28.0 size=N/A time=00:02:47.14 bitrate=N/A speed=7.18x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286656.ts' for writing frame= 4090 fps=172 q=28.0 size=N/A time=00:02:51.09 bitrate=N/A speed= 7.2x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286657.ts' for writing frame= 4185 fps=172 q=28.0 size=N/A time=00:02:55.06 bitrate=N/A speed=7.21x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286658.ts' for writing frame= 4256 fps=172 q=28.0 size=N/A time=00:02:57.96 bitrate=N/A speed=7.18x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286659.ts' for writing frame= 4336 fps=172 q=25.0 size=N/A time=00:03:01.14 bitrate=N/A speed=7.16x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286660.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286661.ts' for writing frame= 4414 fps=171 q=28.0 size=N/A time=00:03:04.40 bitrate=N/A speed=7.15x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286662.ts' for writing frame= 4506 fps=171 q=28.0 size=N/A time=00:03:08.37 bitrate=N/A speed=7.16x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286663.ts' for writing frame= 4582 fps=171 q=28.0 size=N/A time=00:03:11.70 bitrate=N/A speed=7.16x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286664.ts' for writing frame= 4670 fps=171 q=28.0 size=N/A time=00:03:15.22 bitrate=N/A speed=7.15x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286665.ts' for writing frame= 4739 fps=170 q=28.0 size=N/A time=00:03:18.05 bitrate=N/A speed=7.13x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286666.ts' for writing frame= 4819 fps=170 q=28.0 size=N/A time=00:03:21.36 bitrate=N/A speed=7.11x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286667.ts' for writing frame= 4899 fps=170 q=28.0 size=N/A time=00:03:24.69 bitrate=N/A speed= 7.1x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286668.ts' for writing frame= 4973 fps=170 q=28.0 size=N/A time=00:03:27.85 bitrate=N/A speed=7.09x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286669.ts' for writing frame= 5047 fps=169 q=28.0 size=N/A time=00:03:30.77 bitrate=N/A speed=7.06x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286670.ts' for writing frame= 5130 fps=169 q=28.0 size=N/A time=00:03:34.35 bitrate=N/A speed=7.07x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286671.ts' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286672.ts' for writing frame= 5209 fps=169 q=28.0 size=N/A time=00:03:37.68 bitrate=N/A speed=7.06x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286673.ts' for writing frame= 5283 fps=168 q=28.0 size=N/A time=00:03:40.77 bitrate=N/A speed=7.04x frame= 5346 fps=168 q=28.0 size=N/A time=00:03:43.31 bitrate=N/A speed=7.01x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286674.ts' for writing frame= 5413 fps=167 q=28.0 size=N/A time=00:03:46.21 bitrate=N/A speed=6.99x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286675.ts' for writing frame= 5484 fps=167 q=28.0 size=N/A time=00:03:49.03 bitrate=N/A speed=6.96x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286676.ts' for writing frame= 5553 fps=166 q=28.0 size=N/A time=00:03:51.91 bitrate=N/A speed=6.94x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286677.ts' for writing frame= 5619 fps=166 q=28.0 size=N/A time=00:03:54.64 bitrate=N/A speed=6.92x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286678.ts' for writing frame= 5689 fps=165 q=28.0 size=N/A time=00:03:57.71 bitrate=N/A speed=6.91x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286679.ts' for writing frame= 5756 fps=165 q=28.0 size=N/A time=00:04:00.46 bitrate=N/A speed=6.89x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286680.ts' for writing frame= 5827 fps=165 q=28.0 size=N/A time=00:04:03.43 bitrate=N/A speed=6.87x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286681.ts' for writing frame= 5896 fps=164 q=28.0 size=N/A time=00:04:06.44 bitrate=N/A speed=6.86x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286682.ts' for writing frame= 5963 fps=164 q=28.0 size=N/A time=00:04:09.10 bitrate=N/A speed=6.84x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286683.ts' for writing frame= 6028 fps=163 q=28.0 size=N/A time=00:04:11.86 bitrate=N/A speed=6.82x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286684.ts' for writing frame= 6095 fps=163 q=28.0 size=N/A time=00:04:14.50 bitrate=N/A speed= 6.8x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286685.ts' for writing frame= 6159 fps=162 q=28.0 size=N/A time=00:04:17.25 bitrate=N/A speed=6.78x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce968286686.ts' for writing frame= 6222 fps=162 q=28.0 size=N/A time=00:04:19.98 bitrate=N/A speed=6.76x [segment @ 000001ec679c5500] Opening 'C:\Users\moguai\AppData\Roaming\Emby-Server\programdata\transcoding-temp\c30a0eb7426b503bf3b1335ce9682866.m3u8.tmp' for writing frame= 6245 fps=162 q=-1.0 Lsize=N/A time=00:04:21.05 bitrate=N/A speed=6.75x video:97367kB audio:4125kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 000001ec679cdd80] frame I:138 Avg QP:18.22 size: 77607 [libx264 @ 000001ec679cdd80] frame P:1985 Avg QP:21.84 size: 29606 [libx264 @ 000001ec679cdd80] frame B:4122 Avg QP:24.40 size: 7333 [libx264 @ 000001ec679cdd80] consecutive B-frames: 9.1% 6.4% 7.0% 77.6% [libx264 @ 000001ec679cdd80] mb I I16..4: 40.5% 0.0% 59.5% [libx264 @ 000001ec679cdd80] mb P I16..4: 26.7% 0.0% 0.0% P16..4: 51.5% 0.0% 0.0% 0.0% 0.0% skip:21.7% [libx264 @ 000001ec679cdd80] mb B I16..4: 4.5% 0.0% 0.0% B16..8: 21.5% 0.0% 0.0% direct: 7.1% skip:67.0% L0:37.9% L1:47.6% BI:14.6% [libx264 @ 000001ec679cdd80] coded y,uvDC,uvAC intra: 27.7% 36.2% 6.6% inter: 12.8% 11.1% 0.1% [libx264 @ 000001ec679cdd80] i16 v,h,dc,p: 38% 26% 19% 17% [libx264 @ 000001ec679cdd80] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 23% 13% 9% 8% 6% 8% 5% 8% [libx264 @ 000001ec679cdd80] i8c dc,h,v,p: 47% 23% 22% 8% [libx264 @ 000001ec679cdd80] Weighted P-Frames: Y:20.9% UV:9.8% [libx264 @ 000001ec679cdd80] kb/s:3062.28 [aac @ 000001ec679be580] Qavg: 544.266
Luke 42245 Posted December 13, 2017 Posted December 13, 2017 The level is 4.1. The profile is hevc main.
atropa 10 Posted December 13, 2017 Author Posted December 13, 2017 (edited) Oh ok sry. Thought he was talking about the level. I do not know much about that. But it should be played direct on the stick right ? With Plex it is all right and only ac3 sound is transcoding. regards Edited December 13, 2017 by atropa
ebr 16337 Posted December 13, 2017 Posted December 13, 2017 I think the server is misinterpreting an option the app is sending so I am going to change the way the app requests the option to avoid whatever that problem is for now. If you are on the beta version, you can test it with the next beta of the app. Thanks. 1
atropa 10 Posted December 13, 2017 Author Posted December 13, 2017 (edited) Ok that sounds great.If this issue is solved, then i can finally delete Plex. I love emby and love what you are doing. Great work guys. Tomorrow i will test the beta. Oh.I forgot to mention the Firestick only has this issue. Android TV and Mobile are playing the video direct. Edited December 14, 2017 by atropa
Solution atropa 10 Posted December 14, 2017 Author Solution Posted December 14, 2017 Installing latest beta 1.5.17a solved the issue. Thank you very much 2
atropa 10 Posted January 29, 2018 Author Posted January 29, 2018 Hey In stable version 1.5.32a and beta 1.5.35a hevc does not direct play again. regards
ebr 16337 Posted January 29, 2018 Posted January 29, 2018 We will need to see specific information again. Please attach complete files as opposed to pasting into the forum. Thanks.
atropa 10 Posted March 14, 2018 Author Posted March 14, 2018 (edited) Sorry for the late answer. After some testing hevc is not the issue. Hevc is playing fine. Subtitles are the problem. Every subtitle except srt force transcoding. Naming the srt subtitels to default forced is ignored by the app. The app takes by default the first subtitle track and ignore the naming to force or default. This is only a issue of the Amazon fire tv app. On Android Tv app all is playing fine. It would be nice if there were an option to ignore ass or vobsubs. Amzon Fire Tv Stick https://picload.org/view/dalopoww/20180314_085033.jpg.html Chrome https://picload.org/view/daloplgr/20180314_085144.jpg.html So you can see the Amazon Stick choose first track and all other apps choose the forced one. regards Edited March 14, 2018 by atropa
atropa 10 Posted March 14, 2018 Author Posted March 14, 2018 Aww no. It was not the same. So stupid....I am sorry.
