Guest Posted December 10, 2017 Posted December 10, 2017 Hi, is there a keyboard shortcut that will make Emby Theater go directly to the home screen? Thanks.
Latchmor 584 Posted December 10, 2017 Posted December 10, 2017 Hi, is there a keyboard shortcut that will make Emby Theater go directly to the home screen? Thanks. Hi, all keyboard shortcuts are here https://github.com/MediaBrowser/Wiki/wiki/Keyboard%20and%20Remote%20Support Home is just the Home key
Guest asrequested Posted December 10, 2017 Posted December 10, 2017 (edited) If you are in a library and an item is highlighted, the home key doesn't work. For example, if I'm in 'all movies' and one of the movies is highlighted, home key doesn't work. If you move up to the tabs, then it works. Edited December 10, 2017 by Doofus 1
Latchmor 584 Posted December 10, 2017 Posted December 10, 2017 If you are in a library and an item is highlighted, the home key doesn't work. For example, if I'm in 'all movies' and one of the movies is highlighted, home key doesn't work. If you move up to the tabs, then it works. Yip I just noticed this about 20 mins ago when I was setting up my remote. Thought I was going mad for a start but it does as you say.
Luke 42243 Posted December 11, 2017 Posted December 11, 2017 Historically when a poster is selected we have used the home key to move selection back to the first item. I will just go ahead and deprecate that so that home is always the same everywhere. 1
