Hemaniaco 0 Posted December 10, 2017 Posted December 10, 2017 (edited) Good morning guys Actual situation is im triying to play some 4k content Tried directly from the TV app and from Nvidia Shield and image constatly stops. Its def a problem on my setup but im totally lost. Content: Suicide.Squad.2016.2160p.4K.UltraHD.BluRay.x265.HEVC.10bit.2ch.AC3-Zeus Log for TV is TV-log.txt Log for Nvidia is Nvidia-log.txt Computer: MSI Z97 GAMING 3 (MS-7918) Intel Core i7-4790K NVIDIA GeForce GTX 1080 32Gb RAM I really hope i did properly the post. Thanks in advance TV-Log.txt NVIDIA-Log.txt Edited December 10, 2017 by Hemaniaco
mastrmind11 722 Posted December 10, 2017 Posted December 10, 2017 (edited) Can you attach the server log and transcode log (if any) for the same timeframe? edit: nevermind, those are both transcode logs, and both appear to fail to load the QSV encoder. Try disabling QSV and trying again. The CPU should be beefy enough w/o QSV anyway, but give it a try and then we can figure out why QSV is not working. Edited December 10, 2017 by mastrmind11
Luke 42245 Posted December 10, 2017 Posted December 10, 2017 Also try installing the latest version of Emby Server from the website on top of your existing version. Thanks !
