mikej135 0 Posted December 9, 2017 Posted December 9, 2017 Hi All, Since I have updated to version 3.2.50, I have noticed that the server crashes when trying to display the Guide or Channels section. I am using the ServerWMC plugin for my TV content. Do you have any idea what would cause this issue? I have version 3.2.40 running on a Windows platform with no issues. Thanks. Mike.
Luke 42241 Posted December 9, 2017 Posted December 9, 2017 Hi there, we're sorry to hear about this. Please attach the information requested in how to report a problem. thanks !
mikej135 0 Posted December 9, 2017 Author Posted December 9, 2017 Hi there. To repeat my problem, I connect to the server's home page. Click "Live TV" and then click "Guide". This brings up the EPG with no channel icons and the server stops. At this point, I have to restart the server. Mike. ServerLog.txt
mikej135 0 Posted December 13, 2017 Author Posted December 13, 2017 If I use the built-in functionality of Emby for Live TV instead of serverwmc, everything works as expected. So at least I can confirm that the plugin is causing me the problem. I'm not sure what to do next.
Luke 42241 Posted December 13, 2017 Posted December 13, 2017 Why not just use the built-in features then?
Melr135@#e 0 Posted December 14, 2017 Posted December 14, 2017 Why not just use the built-in features then?I was considering this option, but currently I use a commercial stripping software on my windows 7 machine that is running serverwmc. Emby server is no longer crashing when accessing the EPG using serverwmc. I removed the spaces from the mounted share name for the recording directory and that fixed my problem. Sent from my Pixel XL using Tapatalk
Luke 42241 Posted December 14, 2017 Posted December 14, 2017 Are you aware the built in option has a post processing feature? you could use that to launch your commercial stripping software on the command line after a recording has completed.
