Pottie 0 Posted December 6, 2017 Posted December 6, 2017 I was going to try emby on Firetv today, I enter my access data correctly The note appears: Server connection error, the credentials are correct, with my Android smartphone the login works without problems Internet connection works Does anyone have an idea?
ebr 16337 Posted December 6, 2017 Posted December 6, 2017 Hi. We need to gather more information on what you are doing and the problem. Is this on a local network or remote? SSL or not? Exactly what message do you receive and where? Thanks. How to Report a Problem
