denz 501 Posted December 6, 2017 Posted December 6, 2017 (edited) Nearly all the thumbnails have issues some are stretched some are not an example of recordings screen in other Emby apps the thumbnails are portrait but on roku they are stretched to be landscape. In Android correct orientation I also noticed different thumbnails are being used to other Emby apps in Emby for Android it looks like this On roku it looks like this Edited December 6, 2017 by denz
ebr 16335 Posted December 6, 2017 Posted December 6, 2017 What is the source of your recordings (using an external service)?
ebr 16335 Posted December 7, 2017 Posted December 7, 2017 With Schedules Direct as your guide provider?
denz 501 Posted December 7, 2017 Author Posted December 7, 2017 (edited) No schedules direct in Australia I use icetv. In latest recording all those images are automatically downloaded by emby using tvdb. Having a close look at the thumbnails in roku, the recordings thumbnails could all be from the guide data provider. Edited December 7, 2017 by denz
Luke 42243 Posted December 7, 2017 Posted December 7, 2017 These are recordings though, so at this point they're just regular library items.
denz 501 Posted December 7, 2017 Author Posted December 7, 2017 When you go into the recordings library and click on edit images it has the image that roku displays but I can't see the picture of the ship that I see using web client, ipad, android.
Luke 42243 Posted December 7, 2017 Posted December 7, 2017 because the thumb is inherited from the series or season.
ebr 16335 Posted December 7, 2017 Posted December 7, 2017 The issue is the Roku is preferring thumb images for TV and you don't have any. I'll have to see if anything can be done to adjust to the unexpected shape of the image it ends up with. One thing you could do that may make it look a little better (will still not be perfect) is to enable the "Enhanced Images" option in the app. This will make it stop stretching them.
denz 501 Posted December 7, 2017 Author Posted December 7, 2017 It is better with that option but it is not perfect as you said.
Senna 368 Posted December 7, 2017 Posted December 7, 2017 Something similar is happening on the Apple TV app: https://emby.media/community/index.php?/topic/53585-live-tv-adapt-display-of-program-icons-orientation-to-orientation-of-icons-from-xmltv-guide-provider/
