Netbug 26 Posted December 5, 2017 Posted December 5, 2017 I've switched over from an HTPC on my main TV to a Chromecast Ultra. Since I'm now casting from my Samsung Galaxy S7, I've experiencing insane lag on the phone. I'll start playing something and it will be fine. However, after 10 minutes or so, my phone starts to slow down. After 30 minutes, the phone is completely unusable and I have to do a button reset in order to use it again. I'm using the Microsoft Launcher (if that's important). Logs attached. Please advise. Thanks. server-63648028800.txt ffmpeg-remux-b5363acb-82a6-49ca-81f5-a7dda466b752.txt ffmpeg-remux-236ec4b0-ceea-4b96-9ac7-3587df6ae70a.txt ffmpeg-remux-7fa427e9-67f0-4750-8f16-f1cff21b5765.txt ffmpeg-remux-8f83e5ef-b518-45d1-af39-c8ac13af1586.txt ffmpeg-remux-6e90b26d-28bb-4391-bed6-2127151b6445.txt bc9c6e3c-fbf9-43b4-9f9e-3d33d05d33971.log 3cd391be-ea0f-4413-ac18-959a1b769b321.log a0c059ae-280f-4891-a56a-d08058bce6cc1.log
Netbug 26 Posted December 7, 2017 Author Posted December 7, 2017 Anyone have any ideas on where to even start with this one?
Netbug 26 Posted December 9, 2017 Author Posted December 9, 2017 Thank you for your patience. No worries. Any thoughts on this one? Have to reboot my phone every time I watch something longer than 20 minutes If you're still looking into it, I can keep waiting.
Netbug 26 Posted December 13, 2017 Author Posted December 13, 2017 Gonna bump this once more. Also, if anyone has any recommendations for a low-priced tablet to use as a remote control in the mean-time, I'd appreciate it. Thanks.
Netbug 26 Posted December 13, 2017 Author Posted December 13, 2017 Hi, we're looking into it, thanks. Oh great. Thank you, Luke.
Netbug 26 Posted December 28, 2017 Author Posted December 28, 2017 Hey, Luke. Any update on this? Just checking in.
Luke 42244 Posted December 28, 2017 Posted December 28, 2017 We are looking into it. Can you try this version? https://emby.media/community/index.php?/topic/53753-emby-for-android-libmpv-testing/ I wouldn't expect a big difference but still I am curious. Thanks.
Netbug 26 Posted December 28, 2017 Author Posted December 28, 2017 Sure thing. Thanks, Luke. Uh... how do I go about getting that version onto my phone?
Luke 42244 Posted January 25, 2018 Posted January 25, 2018 @@Netbug There are improvements for this in the beta version of the app. If you'd like to try that you can learn how here: https://emby.media/community/index.php?/topic/24350-android-open-beta-testing/ Thanks !
Netbug 26 Posted February 11, 2018 Author Posted February 11, 2018 @@Netbug There are improvements for this in the beta version of the app. If you'd like to try that you can learn how here: https://emby.media/community/index.php?/topic/24350-android-open-beta-testing/ Thanks ! I'll install it today and start using it. thanks.
Netbug 26 Posted February 12, 2018 Author Posted February 12, 2018 How can I confirm that the latest version of the beta has been installed? I attempted to use it this evening, but there was still the overheating and system lag. The beta may not have installed (I did opt in through that link in your previous post though).
Luke 42244 Posted February 12, 2018 Posted February 12, 2018 By now the store will have updated you to the latest.
Netbug 26 Posted February 16, 2018 Author Posted February 16, 2018 Issue persists with latest build. Just FYI.
Luke 42244 Posted February 16, 2018 Posted February 16, 2018 Ok, please try the next release of the app, thanks.
Netbug 26 Posted February 25, 2018 Author Posted February 25, 2018 Device: Samsung Galaxy S7 Android Version: 7 Emby Version 2.9.89 Tested: Saturday, February 24th, 2018 Result: Worked fine on local device. Upon attempting to cast, system lag returned to a point where a hard-reset of the phone was required.
Luke 42244 Posted February 25, 2018 Posted February 25, 2018 I know what's causing it. I'm looking into it, thanks. By the way are you able to play video locally on the device?
Netbug 26 Posted February 26, 2018 Author Posted February 26, 2018 I know what's causing it. I'm looking into it, thanks. By the way are you able to play video locally on the device? That's good to hear Local content seems to be ok. I'm just running a movie now to do a real test (I don't usually watch on my phone; I use it more as a controller).
Netbug 26 Posted February 26, 2018 Author Posted February 26, 2018 After about 40 minutes, it seems decent. A little warm. Some fast battery drain (went from about 78% to 60% in 45 minutes. Minor lag with the rest of the system while Emby is running.
