brianmoranOK 0 Posted December 5, 2017 Posted December 5, 2017 Hello, I have been running 3.2.26 on a Win7 64-bit virtual machine and downloaded the 3.2.40.0 stable installer to upgrade from the website this morning. The setup appears to have downloaded and extracted, but now Emby will not start. Any ideas? Thanks!
brianmoranOK 0 Posted December 5, 2017 Author Posted December 5, 2017 So, I decided to run a system restore point to last night. 3.2.36 will now load again, but nothing is clickable. Cannot play shows, access settings, etc.
Luke 42204 Posted December 5, 2017 Posted December 5, 2017 hi @@brianmoranOK, we need to add this to the website instructions, but going forward on windows 7 you'll need SP1 with windows updates fully up to date. Do that and then you should be able to run the latest version from the website just fine. thanks !
dranderson402 31 Posted December 5, 2017 Posted December 5, 2017 Is 3.2.40 a manual update? I see on the release notes page that 3.2.50 is actually the latest but I'm still on 3.2.36 which is the last version it auto updated to.
Luke 42204 Posted December 5, 2017 Posted December 5, 2017 https://emby.media/community/index.php?/topic/53111-windows-server-update-announcement/&do=findComment&comment=517604
dranderson402 31 Posted December 5, 2017 Posted December 5, 2017 https://emby.media/community/index.php?/topic/53111-windows-server-update-announcement/&do=findComment&comment=517604 Ah, thanks. Missed that thread.
Luke 42204 Posted December 5, 2017 Posted December 5, 2017 It will be on our announcements within the next day so people won't need to dig through the forum to get the message. thanks.
brianmoranOK 0 Posted December 8, 2017 Author Posted December 8, 2017 @@Luke - I updated my Win7 VM with the post-SP1 updates and everything is back to working order. Thank you! hi @@brianmoranOK, we need to add this to the website instructions, but going forward on windows 7 you'll need SP1 with windows updates fully up to date. Do that and then you should be able to run the latest version from the website just fine. thanks !
