Have tested streaming to chromecast for a couple of days now and it works great. But I was wondering if 5.1 audio is supposed to work on files that have dts and dolby digital soundtracks?
I got 5.1 audio on one file that had dts soundtrack with chromecast and that was the only file that didn't have mediainfo listed. I only got stereo on files that had mediainfo listed.(see logfiles)
Is it supposed to stream 5.1 audio or if not will it be an option later?
ffmpeg-03b97744-8ffd-4373-aac5-904edd8bec11(5.1 audio).txt
ffmpeg-e65a685a-270c-47ad-b4a5-05af4899fed6(2.0 audio).txt
5.1 is possible on cc as you have discovered but we are being conservative atm. It will likely be added as we test more.
  • 1 month later...
Update on this?
Multichannel audio is important.
Sent from my Nexus 4 using Tapatalk
Okay, okay, I hear you. :)
