rljnc 2 Posted December 2, 2017 Posted December 2, 2017 Okay I’m new with Emby, so trying to figure settings out. Server running on intel nuc i3, when playing video in this case avatar on my fire tv (not new model), it’s killing cpu, it appears that two ffmegs are running I assume one audio one video. If I play this same video with plex it’s only transcoding audio cpu running around 14%, emby is 90% or more. What do I have wrong.
Luke 42245 Posted December 2, 2017 Posted December 2, 2017 Hi there, we're sorry to hear about this. Can we look at an example? Please attach the information requested in how to report a media playback issue. thanks !
rljnc 2 Posted December 2, 2017 Author Posted December 2, 2017 (edited) 2017-12-02 09:05:32.277 Info App: Profile: Android-Exo, Path: \\192.xxx.x.xx\Public\Shared Videos\Movies\Sci Fi\Avatar\Avatar_t01.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: False2017-12-02 09:05:32.277 Info App: Profile: Android-Exo, No direct play profiles found for Path: \\192.xxx.x.xx\Public\Shared Videos\Movies\Sci Fi\Avatar\Avatar_t01.mkv2017-12-02 09:05:32.277 Info App: Bitrate exceeds DirectStream limit: media bitrate: 35537608, max bitrate: 300000002017-12-02 09:05:32.277 Info App: Profile: Android-Exo, Path: \\192.xxx.x.xx\Public\Shared Videos\Movies\Sci Fi\Avatar\Avatar_t01.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: False2017-12-02 09:05:32.277 Info App: Profile: Android-Exo, No direct play profiles found for Path: \\192.xxx.x.xx\Public\Shared Videos\Movies\Sci Fi\Avatar\Avatar_t01.mkv2017-12-02 09:05:32.284 Info HttpServer: HTTP Response 200 to 192.xxx.x.xx. Time: 11ms. http://192.xxx.x.xx/emby/Items/cd7a0b10ad094158074b592d068e97e3/PlaybackInfo?format=json2017-12-02 09:05:32.335 Info HttpServer: HTTP POST http://192.xxx.x.xx/emby/Sessions/Playing. UserAgent: Dalvik/2.1.0 (Linux; U; Android 5.1.1; AFTS Build/LVY48F) 2017-12-02 09:05:32.340 Info HttpServer: HTTP Response 204 to 192.xxx.x.xx. Time: 5ms. http://192.xxx.x.xx/emby/Sessions/Playing Well assume maybe this exceed bitrate might have something to do with it, how would I solve that? Edited December 2, 2017 by rljnc
Luke 42245 Posted December 2, 2017 Posted December 2, 2017 Hi there, can you please attach the complete emby server and ffmpeg logs as requested in the link above? thanks !
rljnc 2 Posted December 2, 2017 Author Posted December 2, 2017 (edited) okay trying to attached log as it says, when I hit attached file get a circle like its down loading then just goes away. Edited December 2, 2017 by rljnc
rljnc 2 Posted December 2, 2017 Author Posted December 2, 2017 serverlog.txt Okay figured that out log attached.
ebr 16337 Posted December 3, 2017 Posted December 3, 2017 You can try setting the max bitrate in the app to 40Mb but that is well outside the spec for the Fire TV so it may not play well. In short, you are trying to play an extremely high-bitrate movie on a device not really designed for such high bitrates so the system is (properly) attempting to convert it to something the device can play.
rljnc 2 Posted December 3, 2017 Author Posted December 3, 2017 Well part of my question is plex has no problem playing same movie on same device,with thecpu is around 15% but with emby 90%and better so why such a difference?
Luke 42245 Posted December 3, 2017 Posted December 3, 2017 Because the files are being played in different ways. Did you try Ebr's suggestion? Let us know, thanks !
Luke 42245 Posted December 3, 2017 Posted December 3, 2017 can you provide a server log from that attempt? thanks.
ebr 16337 Posted December 3, 2017 Posted December 3, 2017 Did you use the plex option to create a lower bitrate copy of the movie? I believe they call it "optimize". You can do the same thing with Emby by using our folder sync feature.
rljnc 2 Posted December 4, 2017 Author Posted December 4, 2017 I did not optimize it with plex, I'm using the exact same file that is on my nas with both systems.
Luke 42245 Posted December 4, 2017 Posted December 4, 2017 Can we look at a new server log after having changed the in-app setting? thanks.
rljnc 2 Posted December 4, 2017 Author Posted December 4, 2017 Not at home currently, will send it later this evening I hope.
rljnc 2 Posted December 4, 2017 Author Posted December 4, 2017 Attached new log server-63648001373.txt
ebr 16337 Posted December 4, 2017 Posted December 4, 2017 Attached new log Transcode log? What did you play and when? Thanks.
rljnc 2 Posted December 4, 2017 Author Posted December 4, 2017 Transcoder log ffmpeg-transcode-21b6bbd4-d9cd-44f9-b25e-cd9ad0097276.txt
Luke 42245 Posted December 5, 2017 Posted December 5, 2017 Thanks for that. Can you check in the app and see if you have the audio downmix setting enabled? thanks.
ebr 16337 Posted December 5, 2017 Posted December 5, 2017 The heavy load here is due to the PGS (graphic) subtitles you have selected and the fact that your system is either configured for or only reports it supports stereo audio. So, the answer to Luke's question above is important.
rljnc 2 Posted December 5, 2017 Author Posted December 5, 2017 Not there currently to check this, but I would say its probably not enabled.
ebr 16337 Posted December 5, 2017 Posted December 5, 2017 What is the Fire TV hooked to (TV/AVR, etc.) and how (what kind of audio connection)?
rljnc 2 Posted December 5, 2017 Author Posted December 5, 2017 Is hooked to LG TV, that has a soundbar and sub connected.
ebr 16337 Posted December 5, 2017 Posted December 5, 2017 Is hooked to LG TV, that has a soundbar and sub connected. Exactly how are those connections made? What type of cables and in what ports on the TV? I'm guessing that your soundbar does not support DTS and, depending on exactly how it is connected, it may not support pass thru of any advanced audio with the way you have things connected. Either that is the case, or you have the app audio setting set to "downmix". Have you tried selecting the Dolby Digital audio track instead of the DTS one?
rljnc 2 Posted December 5, 2017 Author Posted December 5, 2017 This is not a fancy soundbar this is just a secondary TV, I will try selected Dolby Digital and see what happens, Thanks for all the advice, maybe I will just take my son's advice that said if it just works with plex why are you fooling with emby.
