jasonwilliams 37 Posted December 2, 2017 Posted December 2, 2017 (edited) EPGerrors.txtHello, I wiped all my guide providers today (was going to start from scratch and manually map the channels), but now the EPG isn't loading. My server log is filled a message for each channel as in the attached sample. Did I do something wrong? Edited December 2, 2017 by jasonwilliams
Luke 42243 Posted December 2, 2017 Posted December 2, 2017 Please attach the information requested in how to report a problem. thanks !
jasonwilliams 37 Posted December 2, 2017 Author Posted December 2, 2017 (edited) Sorry I forgot to upload the attachment! Should be there now. Edited December 2, 2017 by jasonwilliams
Luke 42243 Posted December 3, 2017 Posted December 3, 2017 Is there still an issue? if i take that epg url and punch it in, it seems to work for me. thanks.
jasonwilliams 37 Posted December 3, 2017 Author Posted December 3, 2017 Unfortunately, yes. It doesn't matter what URL I use, it won't load and just gives those errors. The only thing I think is maybe i broke something when I was adding/removing tuners and guide sources. I can't seem to get it working again.
jasonwilliams 37 Posted December 3, 2017 Author Posted December 3, 2017 Hmmm, so it seems its something with M3U. If I switch back to the original M3U, it loads fine. Any suggestions as to what to look for there? The file seems fine.
jasonwilliams 37 Posted December 3, 2017 Author Posted December 3, 2017 It looks like something in the M3U was causing this. I ran it through an M3U editor and now it loads. Not sure what was causing the problem, but its working now!
jasonwilliams 37 Posted December 3, 2017 Author Posted December 3, 2017 Looks like I spoke too soon. It stopped working. When I click on map channels, the list is empty. I reduced my M3U down to 2 channels. Can I send you the links in a PM?
jasonwilliams 37 Posted December 4, 2017 Author Posted December 4, 2017 When you click on map channels does it populate anything? I'm getting this: I just tried uninstalling/reinstalling Emby server, but it didn't help. Is it possible I corrupted the configuration tables with all the mucking around?
jasonwilliams 37 Posted December 4, 2017 Author Posted December 4, 2017 I've attached the log from when I created the XMLTV source and clicked on Map Channels. ServerLog.txt
Luke 42243 Posted December 4, 2017 Posted December 4, 2017 Ok i have a fix for this but we're trying to get a release out and I think the change required carries a little risk. We'll get it into a beta in the next few days. Thanks.
jasonwilliams 37 Posted December 4, 2017 Author Posted December 4, 2017 No problem! I'm just thankful for your help.
jasonwilliams 37 Posted December 14, 2017 Author Posted December 14, 2017 Hi Luke, Did you do something? It is suddenly working with 3.2.50.6.
Luke 42243 Posted December 15, 2017 Posted December 15, 2017 Yes the change I mentioned has been in the last couple betas. Thanks.
