jasonwilliams 37 Posted November 30, 2017 Posted November 30, 2017 Hi Everyone, I'm struggling to understand how the guides work with the channel map. My provider gives an XMLTV file which I added as a guide and it works perfectly, but they only provide 1 day of data, so I was hoping to map some of the channels using Schedules Direct. I added SD and mapped one of the channels (it is now mapped to both guide sources), but it isn't populating. Are we meant to be able to map multiple guide sources to a single channel? If not, is there a way to in-map the channel from the XMLTV source?
Luke 42243 Posted November 30, 2017 Posted November 30, 2017 You can't use multiple sources for the same channel, so you'll need to pick one or the other. Thanks.
jasonwilliams 37 Posted November 30, 2017 Author Posted November 30, 2017 Thanks Luke. This is probably a silly question, but how to do in-map a channel from an EPG. Right now it shows the channel is mapped to both sources.
Luke 42243 Posted November 30, 2017 Posted November 30, 2017 It's only mapped to whichever guide provider is higher in the list. That whole management interface needs to be redone
jasonwilliams 37 Posted November 30, 2017 Author Posted November 30, 2017 Gotcha. I'll just delete the XMLTV provider and re-add it so it goes to the bottom then. Thanks!
