wp.rauchholz 5 Posted November 30, 2017 Posted November 30, 2017 I run under CENTOS 7, latest updated I got the the page where the path to ffmpg needs to get entered. That is where I am stuck ffmpeg and ffprobe are located in /usr/bin. Here are permissions -rwxr-xr-x. 1 root root 212800 Apr 27 2016 ffmpeg -rwxr-xr-x. 1 root root 132952 Apr 27 2016 ffprobe Install wizard tells me that it cannot find it. What am I doing wrong? Wolfgang
Jdiesel 1437 Posted November 30, 2017 Posted November 30, 2017 Try chmod u+x /usr/bin/ffmpeg chmod u+x /usr/bin/ffprobe
dcrdev 255 Posted November 30, 2017 Posted November 30, 2017 Where did you install emby from? Was it a standalone rpm, or from a repository? What's the contents of: ls -hlpa /opt/emby-server/bin In the latest version of emby, it downloads ffmpeg for you and doesn't allow you to choose a custom location. Also @@Jdiesel , he already has execute permissions for the user on ffmpeg/ffprobe and it wouldn't help anyway since they are owned by root and emby runs as "emby"; it's executable by "other" also, so it really doesn't matter.
wp.rauchholz 5 Posted November 30, 2017 Author Posted November 30, 2017 Thanks for answers. The file was smoehow corrupt. I re-installed and have now a fully working server to explore Thanks again. Wolfgang
Luke 42245 Posted November 30, 2017 Posted November 30, 2017 What architecture? Our new standalone rpms for x64 should be taking care of this so that you never see that screen at all.
wp.rauchholz 5 Posted December 1, 2017 Author Posted December 1, 2017 I hope that help. 3.10.0-693.5.2.el7.x86_64 #1 SMP Fri Oct 20 20:32:50 UTC 2017 x86_64
dcrdev 255 Posted December 1, 2017 Posted December 1, 2017 I hope that help. 3.10.0-693.5.2.el7.x86_64 #1 SMP Fri Oct 20 20:32:50 UTC 2017 x86_64 That's the mono version.
wp.rauchholz 5 Posted December 1, 2017 Author Posted December 1, 2017 Not sure what you mean by that? Need any other info?
