Jonny67 3 Posted November 30, 2017 Posted November 30, 2017 (edited) Hello, first post here and I've just subscribed to Emby for a month as a trial but liking it very much so far. I have a QNAP NAS TS453-Pro running Emby Server. I have an HTPC, Windows 10 PC, Galaxy S5 phone, Galaxy Tab 2, Fire TV (the wired box) all running Emby client successfully. However my Fire TV stick does not show any thumbnails at all. I noticed it a few weeks back when I first installed it on my previous Fire TV stick and I thought it was hardware related so I purchased the latest Fire TV stick last week but I get the same issue...no thumbnails. I also have Kodi on this Fire TV stick and I have installed the Emby add-on and this does give me thumbnails. So the issue is with the Emby client for the Fire TV stick, any ideas? Edited November 30, 2017 by Jonny67
ebr 16337 Posted November 30, 2017 Posted November 30, 2017 Hi, can you please follow the instructions for how to send a log from the app in the link below and then also post the server log that goes with that same session? Thanks. How to Report a Problem
Jonny67 3 Posted November 30, 2017 Author Posted November 30, 2017 Fire TV log file sent 30th November 16:30pm UK time. Server log attached. Emby.txt
ebr 16337 Posted November 30, 2017 Posted November 30, 2017 I don't see anything unusual on the server side but I cannot find an app log sent at that time. What was the name of the Emby user logged in?
Jonny67 3 Posted November 30, 2017 Author Posted November 30, 2017 The name was "admin", the only account I have. I appreciate you looking into this for me, thank you.
ebr 16337 Posted November 30, 2017 Posted November 30, 2017 Were you logged in and sent the log from the button on the home screen (as opposed to using the button on the login screen)? I cannot find the log on our end - which may actually be related to the issue you are seeing as something may be blocking some network interactions. Did you get a little message pop up saying that the log was sent successfully?
Jonny67 3 Posted November 30, 2017 Author Posted November 30, 2017 I tried again. I clicked the "Send Log" button from both the login screen and the home screen and yes you are correct I got an error message "unable to send log". I do not have anything which can possibly block the Fire TV stick as all our devices are on our LAN and all using the 192.168.0.0/24 range. Amazon Prime video works ok too. How big are the Fire TV logs? I only ask because we do not have fibre broadband here yet (due in January) so we only get 0.6mbps upload if that matters? However I am able to chat here and upload the server logs.
Jonny67 3 Posted December 1, 2017 Author Posted December 1, 2017 I connected my older stick to my works wifi in my office and installed Emby server on my laptop on the same wifi. It connects with thumbnails/cover art so the problem must be at my house with my home wifi. I have no idea what though?
ebr 16337 Posted December 1, 2017 Posted December 1, 2017 Not sure but something is definitely slow or blocked on your home network. Make sure your router isn't restricting traffic for that device. If you are trying to use SSL, try it with plain http.
Jonny67 3 Posted December 1, 2017 Author Posted December 1, 2017 I'm not using any SSL stuff that I know of. I have an update though. I installed Emby server on my PC at home and my Fire TV stick was working great with all thumbnails/cover art showing so my wifi is fine. I sent you a log at exactly 7pm UK time and I got a message saying it was sent, please check. So this leads me to believe there is a problem between the Fire TV stick (both versions, as I have both setup right now) and my QNAP NAS. Sorry to cause you more work but any ideas welcome...thank you.
ebr 16337 Posted December 1, 2017 Posted December 1, 2017 Yes, I received that log but, since everything is working fine, it doesn't tell us anything . I'm not sure how the connection to your server would impact the ability of the device to get out directly to other sites though. I'm stumped...
Jonny67 3 Posted December 1, 2017 Author Posted December 1, 2017 Ok thanks. I'll try some more tests soon, my daughter is hassling me to put up the christmas tree
Jonny67 3 Posted December 1, 2017 Author Posted December 1, 2017 Can you tell me how to retrieve the Fire TV stick's log, other than clicking the Send Log button? If you can give me the fire tv sticks path to the logs for Emby stuff I'm sure I can find a way to get it.
ebr 16337 Posted December 1, 2017 Posted December 1, 2017 We use the standard syslogging on the device. The way to access it is to install the Android Debug Bridge on a computer and then you can monitor it in real time. Thanks.
Jonny67 3 Posted December 2, 2017 Author Posted December 2, 2017 Good news I finally have it working. I still don't know why though. I created a new account both on my NAS with full RW access and on Emby server. I logged in with that account and everything was working. I logged out and back in as admin again and this time it worked. Anyway it's working and that's all that matters. Thanks so much for your help, it's nice to see such quick and helpful responses here
Jonny67 3 Posted February 7, 2018 Author Posted February 7, 2018 I have Sky Q hub and Sky broadband and Wifi. Unfortunately Emby still doesn't work, it did for a day but stopped again. I didn't bother pursuing it as I went away with work then Christmas holidays and on our return I used my hard wired Fire TV box instead of the stick but now I'm a a bit fed up that it doesn't work as I need the Fire Stick for my daughter. I also have a Fire TV box which works over Ethernet hard wired but as soon as I unplug the cable and go into settings and connect via WiFi Emby no longer works correctly as it no longer shows cover art nor plays the media, just like the Fire TV Stick. So I immediately thought WiFi is the problem with Emby, or more specifically Sky Wifi. So tonight I took a drastic action. I connected a second WiFi router to my Sky Q Hub, a Netgear Nighthawk AC1900, model D7000, a fantastic modem/router. I turned off WiFi on the SkyQ hub and after some configuration changes I was able to connect all our devices in the house to the Internet using the Netgear router as thew WiFi hotspot. Emby still did not work. Everything else work though. I have submitted a log before and nothing was found so maybe no point in sending another? I know this is not an easy one but please help. I love Emby
Luke 42245 Posted February 7, 2018 Posted February 7, 2018 @@Jonny67 can you please provide a new log? given that some time has elapsed, can you please provide a new description for what "doesn't work" means? thanks.
Jonny67 3 Posted February 7, 2018 Author Posted February 7, 2018 Will do. Wife is watching TV at the moment but I'll send logs soon
Jonny67 3 Posted February 7, 2018 Author Posted February 7, 2018 (edited) in the meantime what "doesn't work" is that non of my Fire TV's (Stick or box, latest Gen too) works with Emby over Wifi but the Fire TV box does work using wired Ethernet. I thought it was because of my Sky WiFi not coping but my tests with the Netgear router prove it's not. Edited February 7, 2018 by Jonny67
Luke 42245 Posted February 7, 2018 Posted February 7, 2018 Ok, when you submit the log from an example, please make sure to also attach the server and ffmpeg log (if there was one) here. thanks.
Jonny67 3 Posted February 7, 2018 Author Posted February 7, 2018 To also add something which might help before I send the logs, all my other devices (Samsung Galaxy phone, Samsung Galaxy Tablet, Samsung laptop, Asus laptop, Lenovo Tablet) allrun Emby over Wifi perfectly.
Jonny67 3 Posted February 7, 2018 Author Posted February 7, 2018 Ok, when you submit the log from an example, please make sure to also attach the server and ffmpeg log (if there was one) here. thanks. will do
ebr 16337 Posted February 8, 2018 Posted February 8, 2018 To also add something which might help before I send the logs, all my other devices (Samsung Galaxy phone, Samsung Galaxy Tablet, Samsung laptop, Asus laptop, Lenovo Tablet) allrun Emby over Wifi perfectly. They probably don't deal with images at the same size that that the TV app does. It does sound like bad wifi which could be due to interference which would explain why you didn't see a difference when switching hardware.
Jonny67 3 Posted February 8, 2018 Author Posted February 8, 2018 I sent a log at 17:14pm UK time, 2 minutes ago. I was logged in as Jonny
