corey 317 Posted November 30, 2017 Posted November 30, 2017 (edited) I recently noticed (within the past week or so) that my Guide Data stopped working via Schedules Direct. The Emby server logs contain this entry: 2017-11-29 21:19:30.876 Error HttpClient: {"response":"MAX_LINEUPS","code":4101,"serverID":"20141201.web.3","message":"Exceeded number of lineups for this account.","datetime":"2017-11-30T02:19:29Z"} I understand that Emby is using the SD JSON service but I logged into my Schedules Direct account and removed two old SD-DD lineups I had restarted Emby and I still have the problem. I don't see any way to see registered SD JSON lineups. What steps do I need to take to restore guide data? Edited November 30, 2017 by corey
garyan2 53 Posted November 30, 2017 Posted November 30, 2017 Download EPG123 and use the epg123.exe program to add/remove lineups from your account (http://epg123.garyan2.net). You don't have to install anything if you don't want... just download any of the zip files to extract the program.
