Luke 42255 Posted December 7, 2017 Posted December 7, 2017 @@politby looks like you're having a networking problem that is preventing downloading the plugins from our domain.
Trevor68 70 Posted December 8, 2017 Posted December 8, 2017 Yes the entire login process is separate per user. How do you delete a user from trakt plugin? I have a rarely used Emby account called Mobile. It is always displayed first in the trakt plugin, possibly due to alphabetical listing I think. I do not EVER want this account to sync to Trak, but since this PIN validation method, I cannot get trakt to work, at all, not even scrobbling. I got to my Trakt account and generate a pin, I switch to my default account in the emby plugin and enter the pin, then when I hit save, it displays the mobile account again, and now sync just goes to 1000, gazillion, bazillion per cent, and then fails, almost instantly.
Luke 42255 Posted December 8, 2017 Posted December 8, 2017 I'm not the original developer of the plugin but i would think you can just blank out the credentials.
Trevor68 70 Posted December 8, 2017 Posted December 8, 2017 I'm not the original developer of the plugin but i would think you can just blank out the credentials. Doubtful, I never entered it in the first place, I presume the plugin simply loads however many emby accounts exist.
Luke 42255 Posted December 8, 2017 Posted December 8, 2017 I'm not quite sure what you mean, but i think you can just blank out the trakt username and password and that should be fine.
Trevor68 70 Posted December 8, 2017 Posted December 8, 2017 I'm going to presume you only have one account in Emby then, hence no drop down to choose accounts in the plugin. Will take some screenshots and grab some logs when I get home tonight.
MischaBoender 5 Posted December 11, 2017 Posted December 11, 2017 Also noticed that Trakt had stopped working since November 29. Just entering a PIN didn't help as the logs showed unauthorized errors. So I cleared the PIN, restarted the service and entered a new PIN. After that all was working again.
shred00 13 Posted January 9, 2018 Posted January 9, 2018 (edited) After seemingly having been able to authenticate the Emby Trakt plugin with Trakt, when I play something and Emby sends a scrobble/start for it, it's getting a 404 back from Trakt: 2018-01-09 09:37:18.981 Info HttpClient: HttpClientManager POST: https://api.trakt.tv/scrobble/start 2018-01-09 09:37:19.105 Error HttpClient: Error ProtocolError getting response from https://api.trakt.tv/scrobble/start *** Error Report *** Version: 3.2.60.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.13.0.123 64-Bit OS: False 64-Bit Process: False User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Tue May 2 22:30:49 UTC 2017) Processor count: 2 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, S System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, S 2018-01-09 09:37:19.135 Info HttpServer: HTTP Response 200 to fd31:aeb1:48df:0:3b14:e643:83d8:7017. Time: 246ms. http://pvr:8096/emby/videos/17357ff020df7e6125906e4260ec84ee 2018-01-09 09:37:19.142 Error Trakt: Exception handled sending status update *** Error Report *** Version: 3.2.60.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.13.0.123 64-Bit OS: False 64-Bit Process: False User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Tue May 2 22:30:49 UTC 2017) Processor count: 2 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin MediaBrowser.Model.Net.HttpException: The remote server returned an error: (404) Not Found. ---> System.Net.WebException: The remote server returned an error: (404) at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, S --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00753] in <283e6d64c4f54f1fbcf3f036adb82d8e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsync>c__async1.MoveNext () [0x00096] in <283e6d64c4f54f1fbcf3f036adb82d8e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Trakt.Api.TraktApi+<PostToTrakt>d__30.MoveNext () [0x003b9] in <4bf613fb353f4e1ea29d6948f07a9f6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter`1[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Trakt.Api.TraktApi+<SendEpisodeStatusUpdateAsync>d__9.MoveNext () [0x00354] in <4bf613fb353f4e1ea29d6948f07a9f6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Trakt.ServerMediator+<KernelPlaybackStart>d__17.MoveNext () [0x00307] in <4bf613fb353f4e1ea29d6948f07a9f6b>:0 MediaBrowser.Model.Net.HttpException at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00753] in <283e6d64c4f54f1fbcf3f036adb82d8e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsync>c__async1.MoveNext () [0x00096] in <283e6d64c4f54f1fbcf3f036adb82d8e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Trakt.Api.TraktApi+<PostToTrakt>d__30.MoveNext () [0x003b9] in <4bf613fb353f4e1ea29d6948f07a9f6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter`1[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Trakt.Api.TraktApi+<SendEpisodeStatusUpdateAsync>d__9.MoveNext () [0x00354] in <4bf613fb353f4e1ea29d6948f07a9f6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Trakt.ServerMediator+<KernelPlaybackStart>d__17.MoveNext () [0x00307] in <4bf613fb353f4e1ea29d6948f07a9f6b>:0 InnerException: System.Net.WebException System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, S at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, S Edited January 9, 2018 by shred00
Luke 42255 Posted January 9, 2018 Posted January 9, 2018 @@shred00, what content is being played? if i had to guess, your content has moviedb or imdb id's that are no longer valid and that's why trakt is sending back a 404 response. If that's true then it's not really a problem with the trakt plugin but more of an issue with your metadata. Thanks !
shred00 13 Posted January 9, 2018 Posted January 9, 2018 @@Luke, Television show episodes. So if I go to Edit info for the episodes that are causing this problem the External IDs: for those shows are empty. Shouldn't they have either the IMDB or TVDB id for the show? None of the shows I have looked at have anything in External IDs: in fact. Without actually going through every show in my database, I'd hazard to guess that none of them have External IDs: filled in.
Luke 42255 Posted January 9, 2018 Posted January 9, 2018 @@Luke, Television show episodes. So if I go to Edit info for the episodes that are causing this problem the External IDs: for those shows are empty. Shouldn't they have either the IMDB or TVDB id for the show? No, they don't need it for episodes. The series needs external id's and then the episodes just need season + episode numbers.
J2ghz 11 Posted January 10, 2018 Posted January 10, 2018 @@shred00, can you turn on debug logging in the plugin (keep emby's debug logging turned on as well) and try to capture the error again?
shred00 13 Posted January 10, 2018 Posted January 10, 2018 Thanks all. This issue seems to have gone away now that I have gone through the authorisations, meticulously another time.
Przemek 70 Posted June 19, 2020 Posted June 19, 2020 Hi, I create account on Trakt.tv and try to sync to my Emby server.I try to import my watching library to trakt but have sync error. I install plugin and check sync to trakt. I also set sheduled tasks in Emby and paste PIN. Do I have to register on the same login name on trakt and Emby?
Luke 42255 Posted June 21, 2020 Posted June 21, 2020 On 6/19/2020 at 4:04 PM, Przemek said: Hi, I create account on Trakt.tv and try to sync to my Emby server.I try to import my watching library to trakt but have sync error. I install plugin and check sync to trakt. I also set sheduled tasks in Emby and paste PIN. Do I have to register on the same login name on trakt and Emby? Hi there, what is the error?
Przemek 70 Posted June 22, 2020 Posted June 22, 2020 14 hours ago, Luke said: Hi there, what is the error? Hi Luke, sorry for that. I see now when I click on "I" sign next to error notification I see everything: Unauthorized at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.<>c__DisplayClass34_0.<<posttotrakt>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Trakt.Api.TraktApi.Retry[T](Func`1 function) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.RefreshUserAuth(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SetRequestHeaders(HttpRequestOptions options, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.GetFromTrakt(String url, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendGetAllWatchedMoviesRequest(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.SyncMovies(User user, TraktUser traktUser, ISplittableProgress`1 progress, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.SyncUserLibrary(User user, TraktUser traktUser, ISplittableProgress`1 progress, CancellationToken cancellationToken) at Trakt.ScheduledTasks.SyncLibraryTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)</posttotrakt> When I go to movie on my Emby server and I click Trakt icon on the bottom it sync that movie to trakt. Regards Przemek
Luke 42255 Posted June 23, 2020 Posted June 23, 2020 @vdatanet can you provide the same link you provided in the other Trakt topic? Thanks.
vdatanet 1619 Posted June 23, 2020 Posted June 23, 2020 21 minutes ago, Luke said: @vdatanet can you provide the same link you provided in the other Trakt topic? Thanks.
Przemek 70 Posted June 25, 2020 Posted June 25, 2020 On 6/23/2020 at 11:26 PM, vdatanet said: Hi, I have Emby installed on linux and cannot find trakt.xml. I search everywhere in /opt/emby-server. I don't have /configuration folder in /opt/emby-server/system/plugins.
vdatanet 1619 Posted June 25, 2020 Posted June 25, 2020 3 hours ago, Przemek said: Hi, I have Emby installed on linux and cannot find trakt.xml. I search everywhere in /opt/emby-server. I don't have /configuration folder in /opt/emby-server/system/plugins. Mine is in /var/lib/emby/plugins/configurations 1
Przemek 70 Posted June 25, 2020 Posted June 25, 2020 2 hours ago, vdatanet said: Mine is in /var/lib/emby/plugins/configurations Thank you very much. Now works.
