mercanbobbo 1 Posted March 7, 2014 Posted March 7, 2014 Hi, I have a MKV movie with 2 audio tracks. When I play it, I cannot change the audio track to my favourite one. I have enabled the LAV Audio Decoder system tray icon but, when the movie is playing, the LAV icon does not appear. Can anybody help me?
Solution Koleckai Silvestri 1154 Posted March 8, 2014 Solution Posted March 8, 2014 Pressing I doesn't allow you to select Audio and change the track? 1
mercanbobbo 1 Posted March 9, 2014 Author Posted March 9, 2014 Thanks Wayne Luke. It works!!! I wasn't aware about the I button.
pagali 62 Posted March 9, 2014 Posted March 9, 2014 How does one select or disable subtitles? This dialog seems like the perfect place for it... or have I missed some other control?
Nelcruz 3 Posted March 11, 2014 Posted March 11, 2014 I press * on my mce remote and am able to select or disable subtitles from there...
lorac 119 Posted March 14, 2014 Posted March 14, 2014 If I press * on my harmony remote, it is similar to going back except the video is still playing in the background. Subtitles have mostly been good, but external ones aren't working (at least for the one show i've tried) in MBT. They do show up automatically in MPC & WMP though.
Koleckai Silvestri 1154 Posted March 14, 2014 Posted March 14, 2014 I don't believe that MBT actually supports external subtitles right now. They need to be burned into the video container.
P3ws 0 Posted December 30, 2015 Posted December 30, 2015 CTRL+F3 swaps subltitles. Mine are .srt and it works.
