vmcosco 24 Posted November 28, 2017 Posted November 28, 2017 I seem to get a fair amount of buffering when I am streaming remotely to my iPad. I do not have any issues when I am at home and streaming to my Fire TV. I use my iPhone as a 4G hotspot so I am not relying on poor coffee shop WiFi. I checked the speed and it comes it at 100Mbps Down so I assume I am good there. I have 7Mbps Up on my home connection and I make sure all other traffic is "paused". I am running nginx for reverse proxy and SSL to connect remotely. Is there a way to tell where the bottleneck is occurring? On the iPad app? Upload from home server? Server processor? Nginx? Thanks
ebr 16309 Posted November 28, 2017 Posted November 28, 2017 What do you have the client bitrate/quality set to? With only 7Mb up at the source, I probably wouldn't try to go above about 2Mb on the client end.
vmcosco 24 Posted November 28, 2017 Author Posted November 28, 2017 What do you have the client bitrate/quality set to? With only 7Mb up at the source, I probably wouldn't try to go above about 2Mb on the client end. I have it set to auto. I will try to drop it down the next time I am streaming. Thanks. That should have been blatantly obvious.
pir8radio 1313 Posted December 1, 2017 Posted December 1, 2017 If your proxy is setup wrong, it will act as if you are a local connection.
