jespermart 5 Posted March 7, 2014 Posted March 7, 2014 Does anyone use Zoom Player as an external player in MBC, and got it to play BD folders. If so, then a guide in this forum will be greeted with great joy
Solution pagali 62 Posted March 7, 2014 Solution Posted March 7, 2014 (edited) Yes, I use ZoomPlayer 8 as my external player for files, DVD folders, and bluray folders. What you need to do is actually enter it 3 times in the MBC configurator. The important thing to note is that the arguments have to be different for each case. Copy them exactly. Sorry... didn't make a screenshot for files... but it just uses the default {0} argument... Edited March 7, 2014 by pagali 1
jespermart 5 Posted March 7, 2014 Author Posted March 7, 2014 Yes, I use ZoomPlayer 8 as my external player for files, DVD folders, and bluray folders. What you need to do is actually enter it 3 times in the MBC configurator. External.JPG External-ZP-BD.JPG External-ZP-DVD.JPG The important thing to note is that the arguments have to be different for each case. Copy them exactly. Sorry... didn't make a screenshot for files... but it just uses the default {0} argument... Thanks a lot, it works like a charm
pagali 62 Posted March 7, 2014 Posted March 7, 2014 Glad to hear that! Would you mark it answered, please?
