Lamista 3 Posted November 26, 2017 Posted November 26, 2017 If I were to set PC to TV-14..but I tag a movies that is TV-14 to block...Will the tv-14 override the tag or vice versa?
Lamista 3 Posted November 26, 2017 Author Posted November 26, 2017 awesome..yeah..that worked...so tag before rating...unfortunately there are more pg13 I need to block than I thought...but at least this is better than plex in that sense...
Lamista 3 Posted November 26, 2017 Author Posted November 26, 2017 A feature request would be a reverse tag..one that would allow a movie to be played past the rating block..would make it easier to block all movies above pg and only allow a few past that gate.
Luke 42204 Posted November 27, 2017 Posted November 27, 2017 Yes this is a good idea. If you search the community you'll find similar topics that you can lend your support to. Thanks !
