tdiguy 99 Posted November 26, 2017 Posted November 26, 2017 (edited) I am trying to figure out how to get vaapi working on my system. I recently upgrade to: ASRock J3455B-ITX Intel Quad-Core Processor J3455 (up to 2.3 GHz) Mini ITX Motherboard/CPU Combo Which has a Integrated Intel HD Graphics 500 video card / integrated video. From what i figure there should be vaapi support for this under apollo lake. I was running debian but i read a few places that ubuntu had better support for intel graphics. Thus far i have not done much with the system past saying yes to installing non free drivers during the install. When i enable vaapi in emby i see the following in the transcode log: [AVHWDeviceContext @ 0x1ade560] No VA display found for device: /dev/dri/renderD128. [AVHWDeviceContext @ 0x1ade560] No VA display found for device: /dev/dri/renderD128. libswresample 2. 9.100 / 2. 9.100 Device creation failed: -22. libpostproc 54. 7.100 / 54. 7.100 [mpeg2video @ 0x20d2c40] Invalid frame dimensions 0x0. Failed to set value '/dev/dri/renderD128' for option 'vaapi_device': Invalid argument Error parsing global options: Invalid argument So surely something isnt quite right. Also perhaps of note, when i run lspci i get: 00:02.0 VGA compatible controller: Intel Corporation Device 5a85 (rev 0b) Which to me would mean i am not using the right driver, i would expect this to list the actual card like with my network adapter which shows as: 02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 11) Edited November 26, 2017 by tdiguy
Luke 42239 Posted November 26, 2017 Posted November 26, 2017 Check and make sure that the vaapi device param is correct for your system
tdiguy 99 Posted November 26, 2017 Author Posted November 26, 2017 Something i just noticed, which i suspect might be a problem is this: vainfo: Driver version: Intel i965 driver for Intel(R) Broxton - 1.7.0 Looking at the hardware chart from: https://en.wikipedia.org/wiki/List_of_Intel_graphics_processing_units I think my unit should be apollo lake. Now the question is how do i correct this? Still sifting through google for this, man there are a lot of similar questions.
tdiguy 99 Posted November 26, 2017 Author Posted November 26, 2017 (edited) Check and make sure that the vaapi device param is correct for your system Sorry luke, but how do i do that? is that the contents of: /dev/dri ? If so that directory contains: card0 renderD128 Sorry i just realized the output of vainfo might be more useful. error: XDG_RUNTIME_DIR not set in the environment. error: can't connect to X server! libva info: VA-API version 0.39.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_0_39 libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.39 (libva 1.7.0) vainfo: Driver version: Intel i965 driver for Intel(R) Broxton - 1.7.0 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD Edited November 26, 2017 by tdiguy
tdiguy 99 Posted November 26, 2017 Author Posted November 26, 2017 (edited) I looked through the forums a bit more and found this: https://emby.media/community/index.php?/topic/31174-hardware-encoding-on-ubuntu-server/page-5&do=findComment&comment=369730 I added emby to the video group, rebooted and this is the ffmpeg: Quality / fps wise i am having trouble telling if its using gpu acceleration. But that could easily be because my connection is not so good at work here. I searched for CPU in the log and got no hits so i think its working. Correction, i just found: Stream #0:0: Video: h264 (h264_vaapi) (High), vaapi_vld, 1280x720 [SAR 1:1 DAR 16:9], q=0-31, 15000 kb/s, 59.94 fps, 90k tbn, 59.94 tbc So i am pretty sure the hardware acceleration is now working. I will have to test a bit when i get home and see how its going. ffmpeg.txt Edited November 26, 2017 by tdiguy
lateparty 1 Posted December 27, 2018 Posted December 27, 2018 (edited) For anyone wondering, this fixes it for CentOS 7.6 on Emby Server 3.5.3. To enable Hardware Acceleration from a clean install (+ "yum install intel-gpu-tools" but I question their relevance), I simply had to issue the following command: sudo usermod -aG video emby and all of a sudden it works! holy moly. @@Luke - If this is still relevant in 3.6 please consider making this something that happens automatically during the installation process. Additionally: my system is a 2018 Intel NUC 8i5BEH and it does a stellar job of hwaccel through VAAPI. Edit: updated the command to include the "a" flag Edited December 27, 2018 by lateparty
Luke 42239 Posted December 27, 2018 Posted December 27, 2018 Thanks for the info and feedback ! @@softworkz
softworkz 5133 Posted December 28, 2018 Posted December 28, 2018 @@Luke - If this is still relevant in 3.6 please consider making this something that happens automatically during the installation process. I'm pretty sure that we're doing this automatically with the 3.6 releases. @@alucryd - Can you confirm?
